Samba - W98
butek
Komputer z linuxem to Stacjpnarny
a z W98 to laptop
W otoczeniu sieciowym widać nazwę ale nie można nigdzie się dostać
smbclient -L laptop
Password:
Domain=[sTACJONARNY] OS=[unix] Server=[samba 3.0.8pre1-0.pre1.3]
        Sharename      Type      Comment
        public          Disk      Public Stuff
        IPC$            IPC      IPC Service (Samba Server)
        ADMIN$          IPC      IPC Service (Samba Server)
        usblp0          Printer  Created by redhat-config-printer 0.6.x
        fedora          Disk      Home Directories
        Server              Comment
        Workgroup            Master
        FEDORA              STACJONARNY
Mój smb.conf
[global]
# workgroup = NT-Domain-Name or Workgroup-Name
  workgroup = Fedora
  netbios name= STACJONARNY
# server string is the equivalent of the NT Description field
  server string = Samba Server
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page
  hosts allow = 192.168.0. 192.168.2. 127.
# if you want to automatically load your printer list rather
# than setting them up individually then you'll need this
  printcap name = /etc/printcap
  load printers = yes
# It should not be necessary to spell out the print system type unless
# yours is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx
;  printing = cups
# This option tells cups that the data has already been rasterized
cups options = raw
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
  guest account = pcguest
# this tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/%m.log
# all log information in one file
#  log file = /var/log/samba/smbd.log
# Put a capping on the size of the log files (in Kb).
  max log size = 50
# Security mode. Most people will want user level security. See
# security_level.txt for details.
  security = user
# Use password server option only with security = server
;  password server = <NT-Server-Name>
# Password Level allows matching of _n_ characters of the password for
# all combinations of upper and lower case.
;  password level = 8
;  username level = 8
# You may wish to use password encryption. Please read
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
  encrypt passwords = yes
  smb passwd file = /etc/samba/smbpasswd
# The following are needed to allow password changing from Windows to
# update the Linux system password also.
# NOTE: Use these with 'encrypt passwords' and 'smb passwd file' above.
# NOTE2: You do NOT need these to allow workstations to change only
#        the encrypted SMB passwords. They allow the Unix password
#        to be kept in sync with the SMB password.
#  unix password sync = Yes
# passwd program = /usr/bin/passwd %u
;  passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
# Unix users can map to different SMB User names
  username map = /etc/samba/smbusers
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
#  include = /etc/samba/smb.conf.%m
# Most people will find that this option gives better performance.
# See speed.txt and the manual pages for details
  socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
# Configure Samba to use multiple interfaces
# If you have multiple network interfaces then you must list them
# here. See the man page for details.
;  interfaces = 192.168.12.2/24 192.168.13.2/24
interfaces=eth0
# Configure remote browse list synchronisation here
#  request announcement to, or browse list sync from:
#      a specific host or from / to a whole subnet (see below)
;  remote browse sync = 192.168.3.25 192.168.5.255
# Cause this host to announce itself to local subnets here
;  remote announce = 192.168.1.255 192.168.2.44
# Browser Control Options:
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
;  local master = no
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
;  os level = 33
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
;  domain master = yes
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
;  preferred master = yes
# Enable this if you want Samba to be a domain logon server for
# Windows95 workstations.
;  domain logons = yes
# if you enable domain logons then you may want a per-machine or
# per user logon script
# run a specific logon batch file per workstation (machine)
;  logon script = %m.bat
# run a specific logon batch file per username
;  logon script = %U.bat
# Where to store roving profiles (only for Win95 and WinNT)
#        %L substitutes for this servers netbios name, %U is username
#        You must uncomment the [Profiles] share below
;  logon path = \\%L\Profiles\%U
# All NetBIOS names must be resolved to IP Addresses
# 'Name Resolve Order' allows the named resolution mechanism to be specified
# the default order is "host lmhosts wins bcast". "host" means use the unix
# system gethostbyname() function call that will use either /etc/hosts OR
# DNS or NIS depending on the settings of /etc/host.config, /etc/nsswitch.conf
# and the /etc/resolv.conf file. "host" therefore is system configuration
# dependant. This parameter is most often of use to prevent DNS lookups
# in order to resolve NetBIOS names to IP Addresses. Use with care!
# The example below excludes use of name resolution for machines that are NOT
# on the local network segment
# - OR - are not deliberately to be known via lmhosts or via WINS.
; name resolve order = wins lmhosts bcast
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
;  wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
#      Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;  wins server = w.x.y.z
# WINS Proxy - Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one  WINS Server on the network. The default is NO.
;  wins proxy = yes
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups. The built-in default for versions 1.9.17 is yes,
# this has been changed in version 1.9.18 to no.
  dns proxy = no
# Case Preservation can be handy - system default is _no_
# NOTE: These can be set on a per share basis
;  preserve case = no
;  short preserve case = no
# Default case is normally upper case for all DOS files
;  default case = lower
# Be very careful with case sensitivity - it can break things!
;  case sensitive = no
#============================ Share Definitions ==============================
  idmap uid = 16777216-33554431
  idmap gid = 16777216-33554431
  template shell = /bin/false
  winbind use default domain = no
[homes]
  comment = Home Directories
  browseable = no
  writable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
;  comment = Network Logon Service
;  path = /home/netlogon
;  guest ok = yes
;  writable = no
;  share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
;    path = /home/profiles
;    browseable = no
;    guest ok = yes
# NOTE: If you have a BSD-style print system there is no need to
# specifically define each individual printer
[printers]
  comment = All Printers
  path = /var/spool/samba
  browseable = no
# Set public = yes to allow user 'guest account' to print
  guest ok = no
  writable = no
  printable = yes
# This one is useful for people to share files
;[tmp]
;  comment = Temporary file space
;  path = /tmp
;  read only = no
;  public = yes
# A publicly accessible directory, but read only, except for people in
# the "staff" group
[public]
  comment = Public Stuff
  path = /home/fedora/
  public = yes
  read only = yes
  write list = @staff
# Other examples.
# A private printer, usable only by fred. Spool data will be placed in fred's
# home directory. Note that fred must have write access to the spool directory,
# wherever it is.
;[fredsprn]
;  comment = Fred's Printer
;  valid users = fred
;  path = /homes/fred
;  printer = freds_printer
;  public = no
;  writable = no
;  printable = yes
# A private directory, usable only by fred. Note that fred requires write
# access to the directory.
;[fredsdir]
;  comment = Fred's Service
;  path = /usr/somewhere/private
;  public = no
;  writable = yes
;  printable = no
# a service which has a different directory for each machine that connects
# this allows you to tailor configurations to incoming machines. You could
# also use the %u option to tailor it by user name.
# The %m gets replaced with the machine name that is connecting.
;[pchome]
;  comment = PC Directories
;  path = /usr/pc/%m
;  public = no
;  writable = yes
# A publicly accessible directory, read/write to all users. Note that all files
# created in the directory by users will be owned by the default user, so
# any user with access can delete any other user's files. Obviously this
# directory must be writable by the default user. Another user could of course
# be specified, in which case all files would be owned by that user instead.
;[public]
;  path = /usr/somewhere/else/public
;  public = yes
;  only guest = yes
;  writable = yes
;  printable = no
# The following two entries demonstrate how to share a directory so that two
# users can place files there that will be owned by the specific users. In this
# setup, the directory should be writable by both users and should have the
# sticky bit set on it to prevent abuse. Obviously this could be extended to
# as many users as required.
;[myshare]
;  comment = Mary's and Fred's stuff
;  path = /usr/somewhere/shared
;  valid users = mary fred
;  public = no
;  writable = yes
;  printable = no
;  create mask = 0765
[root@stacjonarny samba]#
Bez zmian
Zainstalowałem webmina i mój smb.conf wygląda tak (wyżej żle wstawiłem i się pokaszaniło)
[global]
        load printers = yes
        socket options = TCP_NODELAY SO_SNDBUF=8192 SO_RCVBUF=8192
        guest ok = yes
        null passwords = yes
        dns proxy = no
        netbios name = STACJONARNY
        cups options = raw
        printing = cups
        password server = None
        default = fedora
        workgroup = Fedora
        os level = 20
        max log size = 50
        security=share
[homes]
        browseable = no
        writeable = yes
; [netlogon]
;  guest ok = yes
;  writable = no
;  share modes = no
;[Profiles]
;    browseable = no
;    guest ok = yes
[printers]
        browseable = no
        printable = yes
;[tmp]
;  path = /tmp
;  read only = no
;  public = yes
# the "staff" group
[public]
        guest ok = yes
        write list = @staff
# Other examples.
# wherever it is.
;[fredsprn]
;  public = no
;  writable = no
;  printable = yes
;[fredsdir]
;  public = no
;  writable = yes
;  printable = no
;[pchome]
;  path = /usr/pc/%m
;  public = no
;  writable = yes
;[public]
;  public = yes
;  only guest = yes
;  writable = yes
;  printable = no
;[myshare]
;  public = no
;  writable = yes
;  printable = no
[fedora]
        path = /home/fedora
[hp]
        printer = usblp0
        printable = yes
A trzeba coś na Windowsie z rejestrami szaleć
W konquerorze jak wpisze smb://l192.168.0.2 (jest to adres Win98) to widzę zasoby na laptopie
ale smbclient -L laptop nic nie zmienia
Wyłączyłem firewall-a
A jak dodać te porty ?
Na windzie gdy chce dostać się do (_linuxa_ → Linuksa) ORT dostaję czerwony komunikat że coś tam jest niedostępne
Po dwóch godzinach
Widać zasoby na Windzie
Ale dlaczego mogę wchodzić w konquerorze do Winda po IP a nie po nazwie
Po nazwie jest lepiej
W /etc/hosts mam wpisaną nazwę winda i pinguję z (_linuxa_ → Linuksa) ORT do winda po nazwie
  • 2 weeks later...
Ave!
zainstalowałem sobie prog Smb4k iiiii...
wbijając się do siostry kompa (OLGA, znaleziona przez szukanie IP. 192.168.0.2) pyta mnie o uwierzytelnianie :|
co mam mu wpisać by mi uwierzył?
dodam że żadnych hasęłm nie ustawiałem :)
a może ustawić? tylko jak....
siostra ma win 2k
i prawie pełny dysk (dać komyś eMule to szaleje, a dysk mały ... :)
Pozdrawiam!
San
