Yum Update --to Wszystko?
Niemcu.MD
Jakim komunikatem yum kończy pracę? U mnie po pobraniu pakietów po prostu wyświetlił znak zachęty. Sprawdziłem ponownie po ponownym uruchomieniu yum check-update i wyświetlił te same aktualizacje do pobrania. O co tu chodzi?
Oto przebieg wykonania yum update:
[root@MichaniA ~]# yum update
Setting up Update Process
Setting up Repo:  base
repomd.xml                100% |=========================| 1.1 kB    00:00
Setting up Repo:  updates-released
repomd.xml                100% |=========================|  951 B    00:00
base      : ################################################## 2622/2622
primary.xml.gz            100% |=========================| 292 kB    00:15
MD Read   : ################################################## 684/684
updates-re: ################################################## 684/684
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for boost to pack into transaction set.
boost-1.32.0-1.fc3.i386.r 100% |=========================| 6.4 kB    00:00
---> Package boost.i386 0:1.32.0-1.fc3 set to be updated
---> Downloading header for gstreamer to pack into transaction set.
libidn-devel-0.5.6-1.i386 100% |=========================|  13 kB    00:01
---> Package libidn-devel.i386 0:0.5.6-1 set to be installed
--> Running transaction check
Dependencies Resolved
Transaction Listing:
 Install: kernel.i686 0:2.6.10-1.766_FC3
 Update: NetworkManager.i386 0:0.3.3-1.cvs20050119.2.fc3
Update: zip.i386 0:2.3-26.3
Performing the following to resolve dependencies:
 Install: libidn-devel.i386 0:0.5.6-1
Other Transactions:
 Obsoleting: boost.i386 0:1.31.0-9 with boost.i386 0:1.32.0-1.fc3
 Obsoleting: boost-devel.i386 0:1.31.0-9 with boost.i386 0:1.32.0-1.fc3
Is this ok [y/N]: y
Downloading Packages:
boost-1.32.0-1.fc3.i386.r 100% |=========================| 586 kB    00:30
(... tu długa lista pobieranych pakietów..)
libidn-devel-0.5.6-1.i386 100% |=========================| 219 kB    00:21
[root@MichaniA ~]#
Dodam, że nowe pliki leżą pobrane na dysku i zabierają cenne 0,5 GB.
Co z tym dalej zrobić?
[root@MichaniA ~](... tu długa lista pobieranych pakietów..)
[root@MichaniA ~]#
No to nie jest normalne zachowanie. Która wersja yum? Miejsce na dysku jest? Spróbuj najpierw zaktualizować yum, a potem resztę.
A czy po kolejnym zapodaniu yum update będzie ponownie zciągał pliki, czy zanjdzie je w swoim katalogu cache (bo tam są) i tylko zainstaluje?
I juz po bólu;)
Tylko zaskoczyło mnie jedno. W napędzie była płyta muzyczna, chyba ze dwa dni leżała nieużywana. Podczas gdy yum instalował pakiety, nagdle odpalił się odtwarzacz i załączył pytę :shock:
po za tym spoko ! Dzięki;)
I juz po bólu;)
Mógłbyś jeszcze napisać co było przyczyną takiego dziwnego zachowania. Komuś się to może przydać.
yum ma zaszyte funkcje uprzyjemniające czas z nim spędzone ;-) A tak na serio, to przypuszczam, iż podczas aktualizacji udev, hal lub D-BUS została na nowo zrobione wykrywanie sprzętu i odpowiednie informacje poleciały na magistralę D-BUS. gnome-volume-manager to wykrył i wykonał standardowe czynnosci przy wykryciu płyty CD.
To są jednak tylko moje przypuszczenia i moge mijać się z prawdą :P
Zrobiłem jak napisałeś -pomogła sktualizacja yum.
rpm -Uvh /var/cache/yum/updates-released/packages/yum-2.1.12-0.fc3.noarch.rpm
... i dopiero yum update i wszystko poszło jak z płatka.
Co do muzyczki przy apdejcie ;-), słyszałem, że pewien producent komercyjnych systemów "windowsowych" pracuje nad podobnym mechanizmem, który będzie uruchamiał ulubiony film użytkownika, bądź muzykę podczas gdy system się zawiesi, bądź podczas samoczynnych restartów systemu spowodowanych błędem krytycznym;)
Wyobraźcie sobie zamiast BSODa :lammer: uruchamia się Wam Wasz ULUBIONY FILM !!! :)))
Czyż to nie koi nerwów? :rolleyes:
:lol: Jak znam życie tak będzie, ale UWAGA, tu może się zapętlić i znowu odpalić film! hehe..!
I tak w kółko, aż się zjara procesor :)
Ale czego się spodziewać po produktach firmy z Redmont? W końcu windowsy służą do generowania takich błędów jakich nie potrafi wygenerować użytkownik :P.
