rudzi Napisano Kwiecień 4, 2004 Zgłoszenie Share Napisano Kwiecień 4, 2004 Gdy wpisuje w konsoli: apt-get install gcc wyswietla mi komunikat: Reading Package Lists... Done Building Dependency Tree... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. Since you only requested a single operation it is extremely likely that the package is simply not installable and a bug report against that package should be filed. The following information may help to resolve the situation: The following packages have unmet dependencies: gcc: Depends: cpp (= 3.2.2-5) but 3.3.2-1 is to be installed E: Broken packages Jakies sugestie? Prosze o pomoc ;-) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rudzi Napisano Kwiecień 4, 2004 Autor Zgłoszenie Share Napisano Kwiecień 4, 2004 Zaczalem grzebac i szukac - myslalem ze nie mam czegos doinstalowanego. Sami ocencie: [root@localhost root]# rpm -ivh gcc gcc3-3.0.4-1.i386.rpm gcc-3.3.3-3.i386.rpm [root@localhost root]# rpm -ivh gcc-3.3.3-3.i386.rpm warning: gcc-3.3.3-3.i386.rpm: V3 DSA signature: NOKEY, key ID 30c9ecf8 error: Failed dependencies: binutils >= 2.14.90.0.4-4 is needed by gcc-3.3.3-3 cpp = 3.3.3-3 is needed by gcc-3.3.3-3 libgcc >= 3.3.3-3 is needed by gcc-3.3.3-3 [root@localhost root]# apt-get install libgcc Reading Package Lists... Done Building Dependency Tree... Done libgcc is already the newest version. 0 packages upgraded, 0 newly installed, 0 removed and 0 not upgraded. [root@localhost root]# apt-get install cpp Reading Package Lists... Done Building Dependency Tree... Done cpp is already the newest version. 0 packages upgraded, 0 newly installed, 0 removed and 0 not upgraded. [root@localhost root]# apt-get install binutils Reading Package Lists... Done Building Dependency Tree... Done binutils is already the newest version. 0 packages upgraded, 0 newly installed, 0 removed and 0 not upgraded. [root@localhost root]# Pisze mi ze ze czegos nie mam(lub nie mam nowej wersjii) a przy uzyciu apt pisze ze mam w najnowszej wersji te pakiety. Ktos cos z tego rozumie? ;] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rudzi Napisano Kwiecień 4, 2004 Autor Zgłoszenie Share Napisano Kwiecień 4, 2004 Juz doszedlem o co chodzilo. Jednak jak czlowiek jest zmuszony, to jest to najlepszy bodziec do odkrycia rozwiazania problemu ;-) Wystarczylo poszukac najnowszych wersji pakietow o ktore "krzyczala" Fedora, i zainstalowac je uzywajac komendy: rpm -Uhv nazwa_pakietu.rpm czyli je upgrejdowac a nie instalowac "na chama" tak jak to robilem wczesniej ;-) (rpm -ivh nazwa_pakietu.rpm) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
