mounter Napisano Marzec 27, 2005 Zgłoszenie Share Napisano Marzec 27, 2005 Od dluzszego czasu probuje zanistalowac modul do perla, ktorego wymagaja wtyczki do nagiosa. Dokladnie chodzi, o wtyczke check_arping.pl. Tak wiec skonfigurowalem CPAN i kiedy instaluje modul wyplowa mi cos takiego: cpan> install Net::Arping CPAN: Storable loaded ok Going to read /root/.cpan/Metadata Database was generated on Sun, 27 Mar 2005 03:55:34 GMT Running install for module Net::Arping Running make for R/RI/RIIKI/Net-Arping-0.02.tar.gz CPAN: Digest::MD5 loaded ok CPAN: Compress::Zlib loaded ok Checksum for /root/.cpan/sources/authors/id/R/RI/RIIKI/Net-Arping-0.02.tar.gz ok Scanning cache /root/.cpan/build for sizes Net-Arping-0.02/ Net-Arping-0.02/README Net-Arping-0.02/Makefile.PL Net-Arping-0.02/Changes Net-Arping-0.02/Arping.xs Net-Arping-0.02/MANIFEST Net-Arping-0.02/Arping.pm Net-Arping-0.02/test.pl Removing previously used /root/.cpan/build/Net-Arping-0.02 CPAN.pm: Going to build R/RI/RIIKI/Net-Arping-0.02.tar.gz Checking if your kit is complete... Looks good Writing Makefile for Net::Arping cp Arping.pm blib/lib/Net/Arping.pm /usr/bin/perl /usr/lib/perl5/5.8.5/ExtUtils/xsubpp -typemap /usr/lib/perl5/5.8.5/ExtUtils/typemap Arping.xs > Arping.xsc && mv Arping.xsc Arping.c Please specify prototyping behavior for Arping.xs (see perlxs manual) gcc -c -D_REENTRANT -D_GNU_SOURCE -DTHREADS_HAVE_PIDS -DDEBUGGING -fno-strict-aliasing -pipe -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -O2 -g -pipe -m32 -march=i386 -mtune=pentium4 -DVERSION=\"0.02\" -DXS_VERSION=\"0.02\" -fPIC "-I/usr/lib/perl5/5.8.5/i386-linux-thread-multi/CORE" INC Arping.c gcc: INC: Nie ma takiego pliku ani katalogu Arping.xs: In function `XS_Net__Arping_send_arp': Arping.xs:124: warning: passing arg 1 of `libnet_select_device' from incompatible pointer type Arping.xs:124: error: too many arguments to function `libnet_select_device' Arping.xs:130: warning: assignment makes pointer from integer without a cast Arping.xs:140: error: `LIBNET_IP_H' undeclared (first use in this function) Arping.xs:140: error: (Each undeclared identifier is reported only once Arping.xs:140: error: for each function it appears in.) Arping.xs:148: error: too many arguments to function `libnet_get_hwaddr' Arping.xs:148: warning: assignment from incompatible pointer type Arping.xs:153: error: dereferencing pointer to incomplete type Arping.xs:156: warning: passing arg 6 of `libnet_build_ethernet' from incompatible pointer type Arping.xs:156: error: too few arguments to function `libnet_build_ethernet' Arping.xs:161: warning: passing arg 12 of `libnet_build_arp' from incompatible pointer type Arping.xs:161: error: too few arguments to function `libnet_build_arp' make: *** [Arping.o] Błąd 1 /usr/bin/make -- NOT OK Running make test Can't test without successful make Running make install make had returned bad status, install seems impossible Nie wiem jak sobie z tym poradzic, a jest mi to bardzo potrzebne. Spotkal sie moze ktos z takim problemem?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
