Kompilacja Ggbot
Kocurkiewicz
poszło bez -lcom_err w makefile-u
[kocurkiewicz@localhost ggbot]$ ./configure
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for cc_r... gcc
checking for pkg-config... pkg-config
checking for OpenSSL... yes
checking for tgetent... no
checking for tgetent in -ltermcap... no
checking for tgetent in -ltinfo... no
checking for tgetent in -lcurses... no
checking for tgetent in -lncurses... no
checking which library has the termcap functions... using gnutermcap
checking for readline.h... /usr/include/readline/readline.h
checking for rl_get_screen_size... no
checking for python... /usr/bin/python
checking for Python.h... found
checking for libgadu... found
configure: creating ./config.status
config.status: creating Makefile
Konfiguracja zako�zona pomylnie.
Wpisz 'make', aby skompilowa�GGBot'a.
[kocurkiewicz@localhost ggbot]$ make
gcc -I.. -I/usr/kerberos/include   -I/usr/include/readline -I/usr/include/python2.3 -o ggbot src/ggbot.c /usr/lib/libgadu.a   -L/usr/kerberos/lib -lssl -lcrypto -lgssapi_krb5 -lkrb5 -lcom_err -lk5crypto -lresolv -ldl -lz   -ltermcap  -lreadline -L/usr/lib -L/usr/lib/python2.3/config -lpython2.3                        -lpthread -ldl  -lutil           -lm              -Xlinker -export-dynamic -g -O2 -pthread -L./lib/termcap
In file included from /usr/include/python2.3/Python.h:8,
                from src/python.h:43,
                from src/prototypes.h:61,
                from src/ggbot.c:81:
/usr/include/python2.3/pyconfig.h:850:1: warning: "_POSIX_C_SOURCE" redefined
In file included from /usr/include/sys/types.h:27,
                from src/ggbot.c:55:
/usr/include/features.h:190:1: warning: this is the location of the previous definition
/usr/bin/ld: cannot find -lcom_err
collect2: ld returned 1 exit status
make: *** [all] Błąd 1
Co zrobić? Co dograć?
