gopher Napisano Kwiecień 10, 2005 Zgłoszenie Share Napisano Kwiecień 10, 2005 Sciagnalem sabie takie źródło umbrello-1.4.0.tar.bz2, wypoakowałem je do katalogu umbrello-1.4.0 następnie cd umbrello-1.4.0 , następnie ./configure i wyskoczyl mi taki komunikat : [root@localhost umbrello-1.4.0]# ./configure checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking target system type... i686-pc-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking for -p flag to install... yes checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for kde-config... /usr/bin/kde-config kde-config: Unknown option '--libsuffix'. kde-config: Use --help to get a list of available command line options. checking where to install... /usr (as returned by kde-config) checking for style of include used by make... GNU checking for gcc... no checking for cc... no checking for cc... no checking for cl... no configure: error: no acceptable C compiler found in $PATH See `config.log' for more details pomocy co mam teraz zrobic, plik config.log wyglada tak: his file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by configure, which was generated by GNU Autoconf 2.59. Invocation command line was $ ./configure ## --------- ## ## Platform. ## ## --------- ## hostname = localhost.localdomain uname -m = i686 uname -r = 2.6.10-1.766_FC3 uname -s = Linux uname -v = #1 Wed Feb 9 23:06:42 EST 2005 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = i686 /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /usr/kerberos/sbin PATH: /usr/kerberos/bin PATH: /usr/local/sbin PATH: /usr/local/bin PATH: /sbin PATH: /bin PATH: /usr/sbin PATH: /usr/bin PATH: /usr/X11R6/bin PATH: /root/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:1563: checking build system type configure:1581: result: i686-pc-linux-gnu configure:1589: checking host system type configure:1603: result: i686-pc-linux-gnu configure:1611: checking target system type configure:1625: result: i686-pc-linux-gnu configure:1672: checking for a BSD-compatible install configure:1727: result: /usr/bin/install -c configure:1742: checking for -p flag to install configure:1755: result: yes configure:1766: checking whether build environment is sane configure:1809: result: yes configure:1861: checking for gawk configure:1877: found /bin/gawk configure:1887: result: gawk configure:1897: checking whether make sets $(MAKE) configure:1917: result: yes configure:2103: checking for kde-config configure:2165: result: /usr/bin/kde-config configure:2261: checking where to install configure:2265: result: /usr (as returned by kde-config) configure:2320: checking for style of include used by make configure:2348: result: GNU configure:2496: checking for gcc configure:2525: result: no configure:2576: checking for cc configure:2605: result: no configure:2618: checking for cc configure:2664: result: no configure:2717: checking for cl configure:2746: result: no configure:2760: error: no acceptable C compiler found in $PATH See `config.log' for more details. ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_build=i686-pc-linux-gnu ac_cv_build_alias=i686-pc-linux-gnu ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_CXXCPP_set= ac_cv_env_CXXCPP_value= ac_cv_env_CXXFLAGS_set= ac_cv_env_CXXFLAGS_value= ac_cv_env_CXX_set= ac_cv_env_CXX_value= ac_cv_env_F77_set= ac_cv_env_F77_value= ac_cv_env_FFLAGS_set= ac_cv_env_FFLAGS_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set= ac_cv_env_host_alias_value= ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_host=i686-pc-linux-gnu ac_cv_host_alias=i686-pc-linux-gnu ac_cv_path_install='/usr/bin/install -c' ac_cv_prog_AWK=gawk ac_cv_prog_make_make_set=yes ac_cv_target=i686-pc-linux-gnu ac_cv_target_alias=i686-pc-linux-gnu kde_cv_path=/usr/bin/kde-config kde_cv_path_kde_config=/usr/bin/kde-config ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /root/umbrello-1.4.0/admin/missing --run aclocal-1.9' AMDEPBACKSLASH='\' AMDEP_FALSE='#' AMDEP_TRUE='' AMTAR='${SHELL} /root/umbrello-1.4.0/admin/missing --run tar' AR='' ARTSCCONFIG='' AUTOCONF='${SHELL} /root/umbrello-1.4.0/admin/missing --run autoconf' AUTODIRS='' AUTOHEADER='${SHELL} /root/umbrello-1.4.0/admin/missing --run autoheader' AUTOMAKE='${SHELL} /root/umbrello-1.4.0/admin/missing --run automake-1.9' AWK='gawk' CC='' CCDEPMODE='' CFLAGS=' ' CONF_FILES=' $(top_srcdir)/./admin/configure.in.min $(top_srcdir)/configure.in.in $(top_srcdir)/./umbrello/configure.in.in' CPP='' CPPFLAGS='' CXX='' CXXCPP='' CXXDEPMODE='' CXXFLAGS='' CYGPATH_W='echo' DCOPIDL2CPP='' DCOPIDL='' DCOPIDLNG='' DCOP_DEPENDENCIES='' DEFS='' DEPDIR='.deps' ECHO='echo' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='' ENABLE_PERMISSIVE_FLAG='' EXEEXT='' F77='' FFLAGS='' FRAMEWORK_COREAUDIO='' GMSGFMT='' HAVE_GCC_VISIBILITY='' INSTALL_DATA='${INSTALL} -m 644' INSTALL_PROGRAM='${INSTALL} $(INSTALL_STRIP_FLAG)' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s' KCFG_DEPENDENCIES='' KCONFIG_COMPILER='' KDECONFIG='/usr/bin/kde-config' KDE_EXTRA_RPATH='' KDE_INCLUDES='' KDE_LDFLAGS='' KDE_MT_LDFLAGS='' KDE_MT_LIBS='' KDE_NO_UNDEFINED='' KDE_PLUGIN='' KDE_RPATH='' KDE_USE_CLOSURE_FALSE='' KDE_USE_CLOSURE_TRUE='' KDE_USE_FINAL_FALSE='' KDE_USE_FINAL_TRUE='' KDE_USE_NMCHECK_FALSE='' KDE_USE_NMCHECK_TRUE='' KDE_XSL_STYLESHEET='' LDFLAGS='' LDFLAGS_AS_NEEDED='' LDFLAGS_NEW_DTAGS='' LIBCOMPAT='' LIBCRYPT='' LIBDL='' LIBJPEG='' LIBOBJS='' LIBPNG='' LIBPTHREAD='' LIBRESOLV='' LIBS='' LIBSM='' LIBSOCKET='' LIBTOOL='' LIBUCB='' LIBUTIL='' LIBZ='' LIB_KAB='' LIB_KABC='' LIB_KDECORE='' LIB_KDEPIM='' LIB_KDEPRINT='' LIB_KDEUI='' LIB_KDNSSD='' LIB_KFILE='' LIB_KFM='' LIB_KHTML='' LIB_KIMPROXY='' LIB_KIO='' LIB_KJS='' LIB_KNEWSTUFF='' LIB_KPARTS='' LIB_KSPELL='' LIB_KSYCOCA='' LIB_KUTILS='' LIB_POLL='' LIB_QPE='' LIB_QT='' LIB_SMB='' LIB_X11='' LIB_XEXT='' LIB_XRENDER='' LN_S='' LTLIBOBJS='' MAKEINFO='${SHELL} /root/umbrello-1.4.0/admin/missing --run makeinfo' MAKEKDEWIDGETS='' MCOPIDL='' MEINPROC='' MOC='' MSGFMT='' NOOPT_CFLAGS='' NOOPT_CXXFLAGS='' OBJEXT='' PACKAGE='umbrello-1.4.0' PACKAGE_BUGREPORT='' PACKAGE_NAME='' PACKAGE_STRING='' PACKAGE_TARNAME='' PACKAGE_VERSION='' PATH_SEPARATOR=':' PERL='' QTE_NORTTI='' QT_INCLUDES='' QT_LDFLAGS='' RANLIB='' SET_MAKE='' SHELL='/bin/sh' STRIP='' TOPSUBDIRS='' UIC='' UIC_TR='' USER_INCLUDES='' USER_LDFLAGS='' USE_EXCEPTIONS='' USE_RTTI='' USE_THREADS='' VERSION='3.3.91' WOVERLOADED_VIRTUAL='' XGETTEXT='' XMLLINT='' X_EXTRA_LIBS='' X_INCLUDES='' X_LDFLAGS='' X_PRE_LIBS='' X_RPATH='' ac_ct_AR='' ac_ct_CC='' ac_ct_CXX='' ac_ct_F77='' ac_ct_RANLIB='' ac_ct_STRIP='' all_includes='' all_libraries='' am__fastdepCC_FALSE='' am__fastdepCC_TRUE='' am__fastdepCXX_FALSE='' am__fastdepCXX_TRUE='' am__include='include' am__leading_dot='.' am__quote='' am__tar='${AMTAR} chof - "$$tardir"' am__untar='${AMTAR} xf -' bindir='${exec_prefix}/bin' build='i686-pc-linux-gnu' build_alias='' build_cpu='i686' build_os='linux-gnu' build_vendor='pc' datadir='${prefix}/share' doc_SUBDIR_included_FALSE='' doc_SUBDIR_included_TRUE='' exec_prefix='NONE' host='i686-pc-linux-gnu' host_alias='' host_cpu='i686' host_os='linux-gnu' host_vendor='pc' include_ARTS_FALSE='' include_ARTS_TRUE='' include_x11_FALSE='' include_x11_TRUE='' includedir='${prefix}/include' infodir='${prefix}/info' install_sh='/root/umbrello-1.4.0/admin/install-sh' kde_appsdir='' kde_bindir='' kde_confdir='' kde_datadir='' kde_htmldir='' kde_icondir='' kde_includes='' kde_kcfgdir='' kde_libraries='' kde_libs_htmldir='/usr/share/doc/HTML' kde_libs_prefix='/usr' kde_locale='' kde_mimedir='' kde_moduledir='' kde_qtver='' kde_servicesdir='' kde_servicetypesdir='' kde_sounddir='' kde_styledir='' kde_templatesdir='' kde_wallpaperdir='' kde_widgetdir='' kdeinitdir='' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localstatedir='${prefix}/var' mandir='${prefix}/man' mkdir_p='mkdir -p --' oldincludedir='/usr/include' prefix='/usr' program_transform_name='s,x,x,' qt_includes='' qt_libraries='' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target='i686-pc-linux-gnu' target_alias='' target_cpu='i686' target_os='linux-gnu' target_vendor='pc' umbrello_SUBDIR_included_FALSE='' umbrello_SUBDIR_included_TRUE='' unsermake_enable_pch_FALSE='' unsermake_enable_pch_TRUE='' x_includes='NONE' x_libraries='NONE' xdg_appsdir='' xdg_directorydir='' xdg_menudir='' ## ----------- ## ## confdefs.h. ## ## ----------- ## #define PACKAGE "umbrello-1.4.0" #define PACKAGE_BUGREPORT "" #define PACKAGE_NAME "" #define PACKAGE_STRING "" #define PACKAGE_TARNAME "" #define PACKAGE_VERSION "" #define VERSION "3.3.91" configure: exit 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Kwiecień 10, 2005 Zgłoszenie Share Napisano Kwiecień 10, 2005 checking for gcc... no Zainstaluj kompilator gcc... apt-get install gcc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
