Samba + Drukarka
CoooL
otorz problem mam nastepujacy: Kombinuje juz od dluzszego czasu, jak udostepnic drukarke lexmark z12 podlaczona do komputera z fc3 na windows 98. Czytajac roznego rodzaju opisy doszedlem do mometu w ktorym windows widzi drukarke. I wlasnie gdzies czytalem ze trzeba wtedy podmapowac port z (_linuxa_ → Linuksa) ORT i zainstalowac jako lokalna na zmapowanym porcie, jednak podczas proby drukowania dostaje komunikat o odmowie dostepu do drukarki.... Wklejam moj plik smb.conf
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not made any basic syntactic errors.
#======================= Global Settings =====================================
[global]
# workgroup = NT-Domain-Name or Workgroup-Name
        workgroup = MSHOME
# server string is the equivalent of the NT Description field
        server string = Dom1
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page
;  hosts allow = 192.168.1. 192.168.2. 127.
# if you want to automatically load your printer list rather
# than setting them up individually then you'll need this
        printcap name = cups
# It should not be necessary to spell out the print system type unless
# yours is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx
  printing = cups
# This option tells cups that the data has already been rasterized
        cups options = raw
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
;  guest account = pcguest
# this tells Samba to use a separate log file for each machine
# that connects
        log file = /var/log/samba/%m.log
# all log information in one file
#  log file = /var/log/samba/smbd.log
# Put a capping on the size of the log files (in Kb).
        max log size = 50
# Security mode. Most people will want user level security. See
# security_level.txt for details.
        security = share
# Use password server option only with security = server
;  password server = <NT-Server-Name>
# Password Level allows matching of _n_ characters of the password for
# all combinations of upper and lower case.
;  password level = 8
;  username level = 8
# You may wish to use password encryption. Please read
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
;  encrypt passwords = yes
;  smb passwd file = /etc/samba/smbpasswd
# The following are needed to allow password changing from Windows to
# update the Linux system password also.
# NOTE: Use these with 'encrypt passwords' and 'smb passwd file' above.
# NOTE2: You do NOT need these to allow workstations to change only
#        the encrypted SMB passwords. They allow the Unix password
#        to be kept in sync with the SMB password.
;  unix password sync = Yes
;  passwd program = /usr/bin/passwd %u
;  passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
# Unix users can map to different SMB User names
;  username map = /etc/samba/smbusers
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;  include = /etc/samba/smb.conf.%m
# Most people will find that this option gives better performance.
# See speed.txt and the manual pages for details
        socket options = TCP_NODELAY SO_SNDBUF=8192 SO_RCVBUF=8192
# Configure Samba to use multiple interfaces
# If you have multiple network interfaces then you must list them
# here. See the man page for details.
;  interfaces = 192.168.12.2/24 192.168.13.2/24
# Configure remote browse list synchronisation here
#  request announcement to, or browse list sync from:
#      a specific host or from / to a whole subnet (see below)
;  remote browse sync = 192.168.3.25 192.168.5.255
# Cause this host to announce itself to local subnets here
;  remote announce = 192.168.1.255 192.168.2.44
# Browser Control Options:
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
;  local master = no
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
;  os level = 33
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
;  domain master = yes
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
;  preferred master = yes
# Enable this if you want Samba to be a domain logon server for
# Windows95 workstations.
;  domain logons = yes
# if you enable domain logons then you may want a per-machine or
# per user logon script
# run a specific logon batch file per workstation (machine)
;  logon script = %m.bat
# run a specific logon batch file per username
;  logon script = %U.bat
# Where to store roving profiles (only for Win95 and WinNT)
#        %L substitutes for this servers netbios name, %U is username
#        You must uncomment the [Profiles] share below
;  logon path = \\%L\Profiles\%U
# All NetBIOS names must be resolved to IP Addresses
# 'Name Resolve Order' allows the named resolution mechanism to be specified
# the default order is "host lmhosts wins bcast". "host" means use the unix
# system gethostbyname() function call that will use either /etc/hosts OR
# DNS or NIS depending on the settings of /etc/host.config, /etc/nsswitch.conf
# and the /etc/resolv.conf file. "host" therefore is system configuration
# dependant. This parameter is most often of use to prevent DNS lookups
# in order to resolve NetBIOS names to IP Addresses. Use with care!
# The example below excludes use of name resolution for machines that are NOT
# on the local network segment
# - OR - are not deliberately to be known via lmhosts or via WINS.
; name resolve order = wins lmhosts bcast
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
;  wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
#      Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;  wins server = w.x.y.z
# WINS Proxy - Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one  WINS Server on the network. The default is NO.
;  wins proxy = yes
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups. The built-in default for versions 1.9.17 is yes,
# this has been changed in version 1.9.18 to no.
        dns proxy = no
        idmap uid = 16777216-33554431
        idmap gid = 16777216-33554431
        restrict anonymous = no
        domain master = no
        preferred master = no
        netbios name = Dom1
        max protocol = NT
        ldap ssl = No
        server signing = Auto
        map to guest = Bad User
        guest ok = yes
[homes]
        comment = Home Directories
        browseable = no
        case sensitive = no
        guest only = yes
        msdfs proxy = no
        hosts allow = 192.168.0.2
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
;  comment = Network Logon Service
;  path = /home/netlogon
;  guest ok = yes
;  writable = no
;  share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
;    path = /home/profiles
;    browseable = no
;    guest ok = yes
# NOTE: If you have a BSD-style print system there is no need to
# specifically define each individual printer
[printers]
        comment = All Printers
        path = /tmp
        browseable = no
# Set public = yes to allow user 'guest account' to print
        guest ok = yes
        printable = yes
        printer name = Lexmark
        writable = no
        create mode = 0700
[Lexmark]
        printable = yes
        force user = nobody
