Undeclared Indefiner...
Haborym
Chcialem sobie zainstalowac Lmule.
Sciagnalem najpierw wxWidget
a potem: lmule-1.2.1
Robie
./configure
make
no i make wywala ponizszy blad:
make[4]: Entering directory `/usr/src/redhat/SOURCES/lmule-1.2.1/src/wx/xrc'
g++ -I../.. -c `/usr/local/bin/wx-config --cxxflags` xh_frame.cpp
xh_frame.cpp: In constructor `wxFrameXmlHandler::wxFrameXmlHandler()':
xh_frame.cpp:32: error: `wxDEFAULT_DIALOG_STYLE' undeclared (first use this function)
xh_frame.cpp:32: error: (Each undeclared identifier is reported only once for each function it appears in.)
To wina programistow czy moja???
A moze po prostu dopisac w pliku:
#define wxDEFAULT_DIALOG_STYLE 0
Tylko nie wiem czy defaultowy dialog box ma wartosc zero(wie ktos ile ma), ale co tam:)
Ma ktos jakis pomysl?
PS:
Hmm, moze ktos podac linka do jakis sprawnie dzialajacych mulow, ktore maja dobrze zaprogramowane zassysanie?
Pozdrowienia i dzieki za wszelka pomoc.
  • 2 weeks later...
Initialising aMule
Checking if there is an instance already running...
--------------------------------------------------------------------------------A fatal error has occurred and aMule has crashed.
Please assist us in fixing this problem by posting the backtrace below in our
'aMule Crashes' forum and include as much information as possible regarding the
circumstances of this crash. The forum is located here:
http://forum.amule.org/board.php?boardid=67
If possible, please try to generate a real backtrace of this crash:
http://www.amule.org/wiki/index.php/Backtraces
----------------------------=| BACKTRACE FOLLOWS: |=----------------------------Current version is: aMule 2.0.0 using wxGTK1 v2.4.2
Running on: Linux 2.6.9-1.681_FC3smp i686
[2] wxFatalSignalHandler in /usr/lib/libwx_gtk-2.4.so.0[0xf6ee205d]
[3] ?? in /lib/tls/libpthread.so.0 [0xc6e7c8]
--------------------------------------------------------------------------------Przerwane
Co u diabla?
:(((((( Cos te wx ciagle niedomaga :(
Jest jakas alternatywna wersja mula nieuzywajaca wx,ow?
Gość _PaT
W jaki sposób wgrałeś aMule?
W jaki sposób wgrałeś wxGTK (o ile wgrałeś)?
Co wyświetla Ci polecenie:
rpm -q wxGTK amule
