Nagrywanie K3b Na Koncie Usera
bartucha82
Witam.
Problem mój polega na tym , że nie mogę nagrywać płytek z konta usera. Mam najnowsze k3b i cdrecord i cdrdao. Na koncie root wszystko chula cacy , ale kiedy chce nagrywać z usera otrzymuję coś takiego :
Devices
LITE-ON DVDRW SOHW-1673S JS05 (/dev/hdc, ) at /media/cdrecorder [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-R; DVD-RW; DVD+R; DVD+RW] [DVD-ROM; DVD-R Sequential; DVD-RW Restricted Overwrite; DVD-RW Sequential; DVD+RW; DVD+R; DVD+R Double Layer; CD-ROM; CD-R; CD-RW] [sAO; TAO; RAW; SAO/R16; RAW/R96P; RAW/R96R]
System
K3b Version: 0.11.23
KDE Version: 3.4.0-0.fc3.0 Red Hat
QT Version:  3.3.4
Kernel:      2.6.9-1.667
cdrecord
/usr/bin/cdrecord: Cannot allocate memory. WARNING: Cannot do mlockall(2).
/usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns.
/usr/bin/cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler
/usr/bin/cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
scsidev: '/dev/hdc'
devname: '/dev/hdc'
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
/usr/bin/cdrecord: Warning: using inofficial libscg transport code version (schily - Red Hat-scsi-linux-sg.c-1.83-RH '@(#)scsi-linux-sg.c 1.83 04/05/20 Copyright 1997 J. Schilling').
SCSI buffer size: 64512
Cdrecord-Clone 2.01-dvd (i686-pc-linux-gnu) Copyright © 1995-2004 Jörg Schilling
Note: This version is an unofficial (modified) version with DVD support
Note: and therefore may have bugs that are not present in the original.
Note: Please send bug reports or support requests to http://bugzilla.redhat.com/bugzilla
Note: The author of cdrecord should not be bothered with problems in this version.
TOC Type: 1 = CD-ROM
Using libscg version 'schily-0.8'.
Driveropts: 'burnfree'
atapi: 1
Device type    : Removable CD-ROM
Version        : 0
Response Format: 2
Capabilities  :
Vendor_info    : 'LITE-ON '
Identifikation : 'DVDRW SOHW-1673S'
Revision      : 'JS05'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x000A
Profile: 0x002B
Profile: 0x001B
Profile: 0x001A
Profile: 0x0014
Profile: 0x0013
Profile: 0x0011
Profile: 0x0010
Profile: 0x000A (current)
Profile: 0x0009
Profile: 0x0008
Using generic SCSI-3/mmc  CD-R/CD-RW driver (mmc_cdr).
Driver flags  : MMC-3 SWABAUDIO BURNFREE FORCESPEED
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
FIFO size      : 4194304 = 4096 KB
/usr/bin/cdrecord: No such file or directory. Cannot open 'suidroot'.
cdrecord comand:
/usr/bin/cdrecord -v gracetime=2 dev=/dev/hdc speed=24 -dao driveropts=burnfree -eject -overburn suidroot -data -tsize=17937s -
mkisofs
17937
Unknown file type (unallocated) /home/bartucha82/.kde/share/apps/k3b/temp/dummydir0/.. - ignoring and continuing.
INFO: UTF-8 character encoding detected by locale settings.
Assuming UTF-8 encoded filenames on source filesystem,
use -input-charset to override.
/usr/bin/mkisofs: Connection reset by peer. cannot fwrite 32768*1
mkisofs comand:
/usr/bin/mkisofs -gui -graft-points -volid K3b data project -volset  -appid K3B THE CD KREATOR VERSION 0.11.23 © 2003 SEBASTIAN TRUEG AND THE K3B TEAM -publisher  -preparer K3b - Version 0.11.23 -sysid LINUX -volset-size 1 -volset-seqno 1 -sort /tmp/kde-bartucha82/k3bpgMrZb.tmp -rational-rock -hide-list /tmp/kde-bartucha82/k3bcGUOAa.tmp -full-iso9660-filenames -iso-level 2 -path-list /tmp/kde-bartucha82/k3bfRiwOb.tmp /home/bartucha82/.kde/share/apps/k3b/temp/dummydir0/
Przeczytałem Faq do tego programu. K3bsetup2 niby ustawia pozwolenia , ale nadal nie można nagrywać. Próbowałem rozwiązania opisanego tutaj.Niestety nadal to nie pomaga. Pomocy.Niby pierdoła , ale potrafi umęczyć równie skutecznie jak katar ;)
A może najpierw zaktualizować system?
K3bsetup2 nie zsuidował Ci przypadkiem cdrecord? Lepiej wyłącz ten bit.
Aktualizacja jest przeprowadzona, a używam tego kernela bo mi bardziej odpowiada niż ten najnowszy. Co do suidroot to jak mam to wyłączyć???Bo widzę to w ustawieniach cdrecord i cdrdao w trybie roota w k3b , ale nie mogę tego modyfikować.
Można wiedziec co Ci nie pasowało? To jajko jest dziurawe jak ser szwajcarski... Jak już nie chcesz 2.6.11-1.14_FC3, to weź zainstaluj sobie kernel-2.6.10-1.770_FC3 (ten też jest dziurawy :P ). O ile pamiętam, to w nowszych jądrach poprawiono sporo rzeczy związanych z nagrywaniem.
chmod 0755 /usr/bin/cdrecord
K3bsetup2 nie bez powodu nie jest dodawany do Fedory.
Brak akceleracji na karcie ati pomimo stosowania przeróżnych patch trików itp. :)
K3bsetup2 jest dołaczany do fedorki bo właśnie z wersji aktualizowanej yumem go mam. Co do uprawnień pliku , które podałeś to takie już były ustawione przez k3bsetup2.
witam
sproboj jak poradzil @waldis
U mnie zadziałało, jak zaznaczyłem w "users and groups" userowi w grupach "disc". Oczywiście w trybie graficznym (teraz dostanę od fanów konsoli).
hm..dla jasnosci wpierw odznaczyc filtrowanie
pozniej odszukac grupe disc
na koniec dodac do niej uzytkownika na ktorym chesz kozystac z nagrywary
a co do fanow konsoli
w /etc
edytowac plik group
i dopisac do grupy disc danego usera
oczywiscie oddzielamy userow kropkami :)
Na jądrze 2.6.10 chyba działało bez problemów.
Nie jest. Przeczytaj sobie Release Notes → http://sunsite.mff.cuni.cz/pub/fedora/3/i3...E-NOTES-en.html Najprawdopodobniej zainstalowałeś jakąś wersję z innego repozytorium. Radziłbym używac wersji z Fedory, bo ma kilka patchy, które mogą być odpowiedzialne za nagrywanie na zwykłym koncie (np. ten → http://cvs.fedora.redhat.com/viewcvs/rpms/...1.14-rdrw.patch )
Ja nic nie musiałem zmieniać w ustawieniach grup i wszystko działa bez problemów. Mam tylko całkowice zaktualizowany system + k3b dystrybucyjne :P
Prawie bez problemów. Sterowniki ATI są bardzo niedopracowane. Potrafią zrobić dziwne rzeczy, jak: zawieszenie kompa (mysz i klawiatura nie reagują, system pracuje), przycinanie (nawet przy oglądaniu filmu regularnie co jakieś 20 minut miałem 5fps), czasem zaczynają "żreć" HDD przez 2 minuty, po czym zamykają aplikacje takie jak gry (Tux Racer, ET) albo odtwarzacze filmów (MPlayer). Opisane problemy dotyczą tylko niektórych układów kart graficznych, na większości powinno działać w miarę OK.
no pewnie tak..
po instalacji z plytek ten problem byl.. jak multum innych np. udev.. itp
wpierw poustawialem co sie dalo :) a dopiero pozniej zrobilem update :P
zciagalo sie cos kolo 700 mega
wiec do zakonczenia sciagania rozwiazalem np. (nie)dzialanie nagrywarki :D
Wersja k3b 0.11.23 z repozytorium rawhide fedorki (development). I tam jest k3bsetup2.
A to ciekawe. Pokaż co pokazuje:
rpm -qf `which k3bsetup2`
rpm -q k3b
Właśnie ściągnąłem paczkę k3b-0.11.23-3.i386.rpm i tam nie ma takiego pliku:
[y4kk0@X ~]$ rpm -qpl k3b-0.11.23-3.i386.rpm | grep k3bsetup2
/usr/share/apps/k3b/pics/73lab/k3bsetup2_guy.png
/usr/share/apps/k3b/pics/crystal/k3bsetup2_guy.png
[y4kk0@X ~]$
Jeśli chodzi o Rawhide'a i sterowniki ATI: testowanie w ten sposób testowego wydania Fedory nie ma w ogóle sensu. Jeśli zgłosisz jakikolwiek błąd w kernelu, to developerzy to oleją, bo kernel będzie 'tainted'. Podobnie z innymi programami -- zamknięte sterowniki powodują zwiechy systemu i dziwne zachowania, więc takie testowanie nie będzie za bardzo wiarygodne.
