Konfiguracja (przegladanie) Sieci Lokalnej
Dziobak
Bardzo prosze o pomoc w ustawieniu otoczenia sieciowego gdyz nie moge przegladac zasobow swej sieci...
System
Fedora core 3 kernel 2.6.10-1770_FC3
ifconfig
eth0     Link encap:Ethernet  HWaddr 00:05:5D:4F:90:3F
         inet addr:10.59.2.160  Bcast:10.59.2.255  Mask:255.255.255.0
         UP BROADCAST NOTRAILERS RUNNING MULTICAST  MTU:1500  Metric:1
         RX packets:113549 errors:0 dropped:0 overruns:0 frame:0
         TX packets:138172 errors:0 dropped:0 overruns:12 carrier:0
         collisions:0 txqueuelen:1000
         RX bytes:70043723 (66.7 MiB)  TX bytes:53616688 (51.1 MiB)
         Interrupt:11 Base address:0xe000
lo       Link encap:Local Loopback
         inet addr:127.0.0.1  Mask:255.0.0.0
         UP LOOPBACK RUNNING  MTU:16436  Metric:1
         RX packets:5286 errors:0 dropped:0 overruns:0 frame:0
         TX packets:5286 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:0
         RX bytes:5749383 (5.4 MiB)  TX bytes:5749383 (5.4 MiB)
route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
10.59.2.0       *               255.255.255.0   U     0      0        0 eth0
default         10.59.2.1       0.0.0.0         UG    0      0        0 eth0
smb.conf
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# Any line which starts with a; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not made any basic syntactic errors.
#======================= Global Settings =====================================
[global]
# workgroup = NT-Domain-Name or Workgroup-Name
workgroup = CENTRUM #nazwa grupy roboczej
# server string is the equivalent of the NT Description field
server string = Fedora Core 3 #opis
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page
;   hosts allow = 192.168.1. 192.168.2. 127.
# if you want to automatically load your printer list rather
# than setting them up individually then you'll need this
printcap name = /etc/printcap
# It should not be necessary to spell out the print system type unless
# yours is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx
;   printing = cups
# This option tells cups that the data has already been rasterized
cups options = raw
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
;  guest account = pcguest
# this tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/%m.log
# all log information in one file
#   log file = /var/log/samba/smbd.log
# Put a capping on the size of the log files (in Kb).
max log size = 50
# Security mode. Most people will want user level security. See
# security_level.txt for details.
security = domain
# Use password server option only with security = server
;   password server = <NT-Server-Name>
# Password Level allows matching of _n_ characters of the password for
# all combinations of upper and lower case.
;  password level = 8
;  username level = 8
# You may wish to use password encryption. Please read
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
;  encrypt passwords = yes
;  smb passwd file = /etc/samba/smbpasswd
# The following are needed to allow password changing from Windows to
# update the Linux system password also.
# NOTE: Use these with 'encrypt passwords' and 'smb passwd file' above.
# NOTE2: You do NOT need these to allow workstations to change only
#        the encrypted SMB passwords. They allow the Unix password
#        to be kept in sync with the SMB password.
;  unix password sync = Yes
;  passwd program = /usr/bin/passwd %u
;  passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
# Unix users can map to different SMB User names
;  username map = /etc/samba/smbusers
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /etc/samba/smb.conf.%m
# Most people will find that this option gives better performance.
# See speed.txt and the manual pages for details
socket options = TCP_NODELAY SO_SNDBUF=8192 SO_RCVBUF=8192
# Configure Samba to use multiple interfaces
# If you have multiple network interfaces then you must list them
# here. See the man page for details.
;   interfaces = 192.168.12.2/24 192.168.13.2/24
# Configure remote browse list synchronisation here
#  request announcement to, or browse list sync from:
#    a specific host or from / to a whole subnet (see below)
;   remote browse sync = 192.168.3.25 192.168.5.255
# Cause this host to announce itself to local subnets here
;   remote announce = 192.168.1.255 192.168.2.44
# Browser Control Options:
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
;   local master = no
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
;   os level = 33
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
;   domain master = yes
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
;   preferred master = yes
# Enable this if you want Samba to be a domain logon server for
# Windows95 workstations.
;   domain logons = yes
# if you enable domain logons then you may want a per-machine or
# per user logon script
# run a specific logon batch file per workstation (machine)
;   logon script = %m.bat
# run a specific logon batch file per username
;   logon script = %U.bat
# Where to store roving profiles (only for Win95 and WinNT)
#        %L substitutes for this servers netbios name, %U is username
#        You must uncomment the [Profiles] share below
;   logon path = \\%L\Profiles\%U
# All NetBIOS names must be resolved to IP Addresses
# 'Name Resolve Order' allows the named resolution mechanism to be specified
# the default order is "host lmhosts wins bcast". "host" means use the unix
# system gethostbyname() function call that will use either /etc/hosts OR
# DNS or NIS depending on the settings of /etc/host.config, /etc/nsswitch.conf
# and the /etc/resolv.conf file. "host" therefore is system configuration
# dependant. This parameter is most often of use to prevent DNS lookups
# in order to resolve NetBIOS names to IP Addresses. Use with care!
# The example below excludes use of name resolution for machines that are NOT
# on the local network segment
# - OR - are not deliberately to be known via lmhosts or via WINS.
; name resolve order = wins lmhosts bcast
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
;   wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
#    Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# WINS Proxy - Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one    WINS Server on the network. The default is NO.
;   wins proxy = yes
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups. The built-in default for versions 1.9.17 is yes,
# this has been changed in version 1.9.18 to no.
#dns proxy = no
#winbind uid = 16777216-33554431
#winbind gid = 16777216-33554431
#restrict anonymous = no
#domain master = no
#preferred master = no
#max protocol = NT
#ldap ssl = No
#server signing = Auto
#netbios name = DEBIAN
#netbios name = Dziobak # nazwa pod jaką chcemy być widoczni
#announce version = 5 # wersja systemu
#client code page = 852 # kodowanie
#character set = ISO8859-2 # łączy się z powyższym - polskie kodowanie
#os level = 0
#local master = no
#guest account = adm
#hosts allow =  # podajemy jakie komputery maja dostęp
#hosts deny = ALL # kto nie ma wstepu
#encrypt passwords = no
#domain master = no
#max protocol = NT
#ldap ssl = No
#case sensitive = no
#msdfs proxy = no
[media]
path = /mnt/media
public = yes
writable = no
[work]
path = /mnt/work
public = yes
writable = yes
Z gory dziekuje za pomoc jesli o czyms istotnym nie wspomnialem chetnie uzupelnie potrzebne informacje ...
POZDRAWIAM
ale chcesz byc widziany w sieci windowsowej czy chcesz widziec siec windowsowa.. bo to 2 rozne rzeczy (no mozna tak powiedziec)
jak ty chesz udostepnic to musisz wlaczyc serwer samby. mozliwe ze dobrze skonfigurowales a poprostu on jest nieaktywny.
jest fajne narzedzie do ustawiania samby
konsola polecenie
system-config-samba
a co do przegladania sieci windowsowych jest info w ( istniejacym od niedawna oficjalnym :D ) faqu (coz za reklama hehe)
dokladnie tutaj:
http://faq.fedora.pl/#smbmount
Nie chodzi mi jakim programem mozna przegladac siec i jak wchodzic w zasoby bez hasla tylko o sama konfiguracje samby bo z tym nie moge sobie dac rady
w przegladarce po wpisaniu "smb:/" wyskakuje okienko "Nie mozna znalezc zadnych grup roboczych w twojej sieci lokalnej " co oczywiscie nie mam miejsca ...
Nie rozumiem już o jaką konfigurację z przeglądarką i "smb:/" ci chodzi. Jesli chodzi o przeglądanie i ewentualny upload/download to mam takie swoje metody poniżej pokazane. A jeśli chodzi o przekazywanie zasobów przez Ciebie, to chyba nie od tego jest przeglądarka :)
Oto jak uzywam smb, choc pewnie są prostsze sposoby :)
Skanuję kompy w sieci przez nmap, np
nmap -sS -O 192.168.180.1-255
(only root can do that!), a jak już widzę, gdzie są windowsy, to patrzę, co ciekawego prezentują programem nmblookup, np
nmblookup -A 192.168.180.100
A operacje na plikach zostawiam programikowi xfsamba (jak już wspominałem wyżej, jest to program pod X11). I już :)
Ustawienia systemowe -> ustawienia serwera -> Usługi
pod konfiguratorem samby
Chyba, że brakuje ci pakietów konfiguracyjnych serwera!
Wtedy musisz Wybrać Dodaj/Usuń Applikacje i z grupy serwery wybrać Narzędzia Konfiguracyjne serwera. W detalach upewnić się czy jest system-config-samba i system-config-services
Edytowane przez wklaczynski
Znany błąd; musisz wyłączyć firewalla → http://sunsite.mff.cuni.cz/pub/fedora/3/i3...n.html#id851541
(o dziwo w KDE jak używa się usługi LISA, to firewall może być włączony)
Wywołujesz skrypta, który uruchamia oba demony :):)
[root@localhost ~]# /etc/rc.d/init.d/smb stop
Zatrzymywanie usługi SMB:                                  [  OK  ]
Zatrzymywanie usługi NMB:                                  [  OK  ]
[root@localhost ~]# /etc/rc.d/init.d/smb start
Uruchamianie usługi SMB:                                   [  OK  ]
Uruchamianie usługi NMB:                                   [  OK  ]
[root@localhost ~]#
POZDRAWIAM!!
[root@localhost ~]#
Jwst taki fajny skrypt w /sbin, który trochę ułatwia sprawę
]# service smb restart
no mi też nie działa w przeglądarce smb:///
ponadto smieszne bo nie mam xfsamba :|
rozumiem ze skanowanie portów/ip na lokalu 192.168.0
i na siłe montowanie udosępnionych katalogów jest też rozwiązaniem ale jest sposób idioto odporny ??
tzn otoczenie sieciowe i np Microsoft network ...
kladzenie całego firewalla jest dziwne :huh:
edit:
włączona LISA i używanie smb2k też zawodzi :(
