Sahin Napisano Czerwiec 1, 2005 Zgłoszenie Share Napisano Czerwiec 1, 2005 Witam Mam problem z zainstalowaniem Captive. Podczas pierwszego montowania powinien skompilować się moduł, niestety wyskakuje mi coś takiego: ]# mount /mnt/win_c Captive NTFS v1.1.5. Check a new version at: http://www.jankratochvil.net/ Preparing LUFS kernel module... Run /usr/share/lufs/prepmod if problems occur. lufs module not loaded: Try running /usr/share/lufs/prepmod to see more. at /usr/bin/captive-lufsd line 180 Po uruchomieniu /usr/share/lufs/prepmod: ]# /usr/share/lufs/prepmod + /sbin/modprobe lufs 2>/dev/null Preparing LUFS kernel module... Run /usr/share/lufs/prepmod if problems occur. Running kernel version: 2.6.11-1.27_FC3 (base version 2.6.11) Destination module directory: /lib/modules/2.6.11-1.27_FC3/kernel/fs/lufs Using kernel sources: /lib/modules/2.6.11-1.27_FC3/build + set -e; /bin/mkdir -p `dirname /var/lib/lufs/lufs.ko`; /bin/rm -f /var/lib/lufs/lufs.ko; make -C /lib/modules/2.6.11-1.27_FC3/build SUBDIRS="/usr/share/lufs/2.6" modules EXTRA_CFLAGS=""; /bin/mv -f /usr/share/lufs/2.6/lufs.ko /var/lib/lufs/lufs.ko; /bin/rm -f /usr/share/lufs/2.6/proc.o /usr/share/lufs/2.6/.proc.o.flags /usr/share/lufs/2.6/.proc.o.cmd /usr/share/lufs/2.6/inode.o /usr/share/lufs/2.6/.inode.o.flags /usr/share/lufs/2.6/.inode.o.cmd /usr/share/lufs/2.6/dir.o /usr/share/lufs/2.6/.dir.o.flags /usr/share/lufs/2.6/.dir.o.cmd /usr/share/lufs/2.6/file.o /usr/share/lufs/2.6/.file.o.flags /usr/share/lufs/2.6/.file.o.cmd /usr/share/lufs/2.6/symlink.o /usr/share/lufs/2.6/.symlink.o.flags /usr/share/lufs/2.6/.symlink.o.cmd /usr/share/lufs/2.6/lufs.mod.o /usr/share/lufs/2.6/.lufs.mod.o.flags /usr/share/lufs/2.6/.lufs.mod.o.cmd /usr/share/lufs/2.6/lufs.o /usr/share/lufs/2.6/.lufs.o.flags /usr/share/lufs/2.6/.lufs.o.cmd /usr/share/lufs/2.6/lufs.mod.c /usr/share/lufs/2.6/.lufs.ko.cmd; make: Entering directory `/lib/modules/2.6.11-1.27_FC3/build' CC [M] /usr/share/lufs/2.6/dir.o CC [M] /usr/share/lufs/2.6/file.o CC [M] /usr/share/lufs/2.6/inode.o CC [M] /usr/share/lufs/2.6/proc.o CC [M] /usr/share/lufs/2.6/symlink.o LD [M] /usr/share/lufs/2.6/lufs.o Building modules, stage 2. MODPOST *** Warning: "kill_proc_info" [/usr/share/lufs/2.6/lufs.ko] undefined! CC /usr/share/lufs/2.6/lufs.mod.o LD [M] /usr/share/lufs/2.6/lufs.ko make: Leaving directory `/lib/modules/2.6.11-1.27_FC3/build' + /bin/rm -rf /lib/modules/2.6.11-1.27_FC3/kernel/fs/lufs; /bin/mkdir -p /lib/modules/2.6.11-1.27_FC3/kernel/fs/lufs; /bin/ln -s /var/lib/lufs/lufs.ko /lib/modules/2.6.11-1.27_FC3/kernel/fs/lufs/lufs.ko + /sbin/rmmod lufs 2>/dev/null; /sbin/insmod /lib/modules/2.6.11-1.27_FC3/kernel/fs/lufs/lufs.ko 2>/dev/null Failed to prepare lufs.ko module for your Linux kernel 2.6.11-1.27_FC3. Detected Linux kernel sources "/lib/modules/2.6.11-1.27_FC3/build" do not appear to be valid. Please install kernel-source-x.y.z.i386.rpm or kernel-headers_x.y.z_i386.deb. The following directory paths were search (first existing directory used): /lib/modules/2.6.11-1.27_FC3/build /usr/src/kernel-headers-2.6.11-1.27_FC3 /usr/src/linux-2.6.11-1.27_FC3 /usr/src/linux-2.6.11 /usr/src/linux /usr/src/kernel-source-2.6.11-1.27_FC3 at /usr/share/lufs/prepmod line 181 Oczywiście źródła mam zainstalowane dla jądra 2.6.11-1.27_FC3. Jak poradzić sobie z tym problemem ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
