Kriss Napisano Czerwiec 17, 2005 Zgłoszenie Share Napisano Czerwiec 17, 2005 Mam problem z update systemu wlasnie zainstalowalem FC4 i chcialbym sobie zaaktualizowac system, jak zawsze najpierw ze starego faq od gajownika sciagnalem sobie yum.conf, a tu nic, nie dziala wyskakuje blad... wiecie moze czemu i jakie teraz repos powinno sie poustawiac? jak macie moze skonfigurowanego yuma to zamiesccie tutaj swoje yum.conf. Pozdrawiam Repository extras already added, not adding again Setting up Update Process Setting up repositories Cannot open/read repomd.xml file for repository: livna-stable failure: repodata/repomd.xml from livna-stable: [Errno 256] No more mirrors to try. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
FC_user Napisano Czerwiec 17, 2005 Zgłoszenie Share Napisano Czerwiec 17, 2005 [main] #cachedir=/var/cache/yum debuglevel=2 logfile=/var/log/yum.log pkgpolicy=newest distroverpkg=redhat-release tolerant=1 exactarch=1 retries=20 obsoletes=1 gpgcheck=1 [base] name=Fedora Core $releasever - $basearch - Base baseurl=http://download.fedora.redhat.com/pub/fedora/linux/core/$releasever/$basearch/os/ mirrorlist=http://fedora.redhat.com/download/mirrors/fedora-core-$releasever enabled=1 gpgcheck=1 [freshrpms] name=Red Hat Linux $releasever - $basearch - freshrpms baseurl=http://ayo.freshrpms.net/fedora/linux/$releasever/$basearch/freshrpms enabled=1 gpgcheck=1 [DAG] name=Dag RPM Repository for Fedora Core baseurl=http://apt.sw.be/fedora/$releasever/en/$basearch/dag [extras] name=Fedora Extras - $releasever - $basearch baseurl=http://download.fedora.redhat.com/pub/fedora/linux/extras/$releasever/$basearch/ gpgcheck=1 gpgkey=http://download.fedora.redhat.com/pub/fedora/linux/extras/RPM-GPG-KEY-Fedora-Extras [extras-debug] name=Fedora Extras - $releasever - $basearch - Debugging packages baseurl=http://download.fedora.redhat.com/pub/fedora/linux/extras/$releasever/$basearch/debug/ gpgcheck=1 gpgkey=http://download.fedora.redhat.com/pub/fedora/linux/extras/RPM-GPG-KEY-Fedora-Extras enabled=0 # PUT YOUR REPOS HERE OR IN separate files named file.repo # in /etc/yum.repos.d U mnie to działa bez zarzutu tylko musisz najpierw uruchomić up2date a on skonfiguruje ci yuma Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Czerwiec 17, 2005 Zgłoszenie Share Napisano Czerwiec 17, 2005 jak zawsze najpierw ze starego faq od gajownika sciagnalem sobie yum.conf FAQ jest do FC3, więc dlatego nie działa. Cannot open/read repomd.xml file for repository: livna-stable failure: repodata/repomd.xml from livna-stable: [Errno 256] No more mirrors to try. http://www.fedora.pl/site/forum/index.php?...indpost&p=30884 [freshrpms] Nie jest kompatybilne z rpm.livna.org i można mieć potem problemy. [DAG] Podmienia paczki z Fedora Core i Extras, więc tez można mieć później problemy. Może i jest tam sporo paczek, ale IMHO lepiej się trzymać Core/Extras/livna Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kriss Napisano Czerwiec 17, 2005 Autor Zgłoszenie Share Napisano Czerwiec 17, 2005 Gajownik to mógłbyś podać Twoją propozycję na yum.conf? co u siebie masz dodane ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Czerwiec 18, 2005 Zgłoszenie Share Napisano Czerwiec 18, 2005 Ja dodałem tylko rpm.livna.org i tyle mi wystarcza (Extras jest już standardowo). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kriss Napisano Czerwiec 18, 2005 Autor Zgłoszenie Share Napisano Czerwiec 18, 2005 Podaje mi treść tego wpisu rpm.livna.org, bo sam nie wiem jak to napisać. Właściwie można mieć polską wersje tej Fedory ?? Bo mam angielską, pytam z ciekawości, bo w sumie mi to nie przeszkadza. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Czerwiec 18, 2005 Zgłoszenie Share Napisano Czerwiec 18, 2005 Podaje mi treść tego wpisu rpm.livna.org, bo sam nie wiem jak to napisać. Przeciez Ci podałem linka z odpowiednim wpisem. Właściwie można mieć polską wersje tej Fedory ?? Oczywiście. Wystarczyło podczas instalacji zaznaczyć, iż chcesz miec interfejs w języku polskim. Teraz spróbuj odpalić system-config-language. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
patpi Napisano Czerwiec 18, 2005 Zgłoszenie Share Napisano Czerwiec 18, 2005 Gajownik to mógłbyś podać Twoją propozycję na yum.conf? co u siebie masz dodane ?? i najlepiej Gajownik stworz nowego posta o tym (Zalecane repozytoria, sredniozalecane, niezalecane , linki informacyjne o yumie itp) i go "przyklej" gdzies. Bo od startu FC4 widzialem juz kilka postow tego typu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
spyro Napisano Czerwiec 18, 2005 Zgłoszenie Share Napisano Czerwiec 18, 2005 witam tak powinno wyglądać repo livny pod FC4 [livna] name=Livna.org Fedora Compatible Packages (stable) baseurl= http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.lvn gpgcheck=1 enabled=1 gpgkey=http://rpm.livna.org/RPM-LIVNA-GPG-KEY-i386 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kriss Napisano Czerwiec 18, 2005 Autor Zgłoszenie Share Napisano Czerwiec 18, 2005 Oki dzieki Wam za pomoc !! Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
