Sane ,xsane
blazej
Witam chodzi mi o podlaczenie skanera przez port rownolegly LTP gdyz takowy posiadam Plustek P12 znalazlem pare opisow w necie i nimi sie sugerowalem sciagnalem sane-backends sane-frontends w wersji kompatybilnej z plustek-module. 2 pierwsze zrodla skompilowalem bez problemu natomiast ten najwazniejszy w ktorym znajduje sie potrzebyny modul pt_drv wywalil mi przy kompilacji bledy :
[root@localhost plustek_driver]# make all
gcc -Wall -Wstrict-prototypes -fomit-frame-pointer -D_PTDRV_V1=0 -D_PTDRV_V0=42 -D_PTDRV_BUILD=10 -D__KERNEL__ -I/lib/modules/2.6.5-1.358/build/include -I./h -I./.. -O2 -DMODULE -c src/dac.c -o obj/dac.o
In file included from /lib/modules/2.6.5-1.358/build/include/asm/processor.h:18,                 from /lib/modules/2.6.5-1.358/build/include/linux/prefetch.h:14,
                from /lib/modules/2.6.5-1.358/build/include/linux/list.h:7,
                from /lib/modules/2.6.5-1.358/build/include/linux/wait.h:14,
                from /lib/modules/2.6.5-1.358/build/include/linux/poll.h:8,
                from h/plustek_sysdep.h:92,
                from h/plustek_scan.h:60,
                from src/dac.c:48:
/lib/modules/2.6.5-1.358/build/include/asm/system.h: In function `__set_64bit_var':
/lib/modules/2.6.5-1.358/build/include/asm/system.h:193: warning: dereferencing type-punned pointer will break strict-aliasing rules
In file included from /lib/modules/2.6.5-1.358/build/include/linux/irq.h:20,
                from /lib/modules/2.6.5-1.358/build/include/asm/hardirq.h:6,
                from /lib/modules/2.6.5-1.358/build/include/linux/delay.h:13,
                from h/plustek_scan.h:61,
                from src/dac.c:48:
/lib/modules/2.6.5-1.358/build/include/asm/irq.h:16:25: irq_vectors.h: Nie ma takiego pliku ani katalogu
In file included from /lib/modules/2.6.5-1.358/build/include/asm/hardirq.h:6,
                from src/dac.c:48:
/lib/modules/2.6.5-1.358/build/include/linux/irq.h: At top level:
/lib/modules/2.6.5-1.358/build/include/linux/irq.h:70: error: `NR_IRQS' undeclared here (not in a function)
In file included from /lib/modules/2.6.5-1.358/build/include/linux/irq.h:72,
                from src/dac.c:48:
/lib/modules/2.6.5-1.358/build/include/asm/hw_irq.h:28: error: `NR_IRQ_VECTORS' undeclared here (not in a function)
/lib/modules/2.6.5-1.358/build/include/asm/hw_irq.h:32: error: `NR_IRQS' undeclared here (not in a function)
make: *** [obj/dac.o] Błąd 1
Jak to naprawic ?
