bartucha82 Napisano Czerwiec 24, 2005 Zgłoszenie Share Napisano Czerwiec 24, 2005 Witam. Mam pliczek /etc/sysconfig/harddisks , w którym przechowywane są ustawienia hdparm , które powinny być ustawiane na starcie. No to tutaj podaję moje opcje i się okazuje , że są one ignorowane przez system. Jak je podam z konsolki ręcznie to wszystko łapie. Z tego pliku nie che. To na chusteczke ten plik tu jest???? Na google patrzyłem i wszystko dobrze ustawiam tak więc proszę o poradę. Zawartość mojego pliku: # # WARNING !!! # # The kernel will autodetect the correct settings for most drives. # Overriding these settings with hdparm can cause data corruption and/or # data loss. # Leave this file as it is unless you know exactly what you're doing !! # # # # These options are used to tune the hard drives - # read the hdparm man page for more information # Set this to 1 to enable DMA. This might cause some # data corruption on certain chipset / hard drive # combinations. This is used with the "-d" option USE_DMA=1 # Multiple sector I/O. a feature of most modern IDE hard drives, # permitting the transfer of multiple sectors per I/O interrupt, # rather than the usual one sector per interrupt. When this feature # is enabled, it typically reduces operating system overhead for disk # I/O by 30-50%. On many systems, it also provides increased data # throughput of anywhere from 5% to 50%. Some drives, however (most # notably the WD Caviar series), seem to run slower with multiple mode # enabled. Under rare circumstances, such failures can result in # massive filesystem corruption. USE WITH CAUTION AND BACKUP. # This is the sector count for multiple sector I/O - the "-m" option # MULTIPLE_IO=32 # (E)IDE 32-bit I/O support (to interface card) # EIDE_32BIT=3 # Enable drive read-lookahead # # LOOKAHEAD=1 # Add extra parameters here if wanted # On reasonably new hardware, you may want to try -X66, -X67 or -X68 # Other flags you might want to experiment with are -u1, -a and -m # See the hdparm manpage (man hdparm) for details and more options. EXTRA_PARAMS="-u1 -a64 -k1" EDIT1: Dobra wykombinowałem coś. Po szczegółowej analiznie skryptu rc.sysinit dowiedziałem się , że hdparm nie uruchamia się przy starcie. Dodałem go tam i niby się inicjował i korzystał z ustawień tylko , że jest jedno "ale". Po dodaniu hdparm'a audit przestał się ładować. Jak bezpiecznie sprawić żeby hdparm ładował się przy starcie komputera????????????????????? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
