Snapshot Do Qemu Pod Fc4 ...
MitS
Witam!
Mam kolejny problem z qemu, a mianowicie z snapshotem qemu którego nie moge zainstalować pod FC4 bo wywala mi błąd taki:
[root@ozyrys ~]# cd /root/Desktop/qemu-snapshot-2005-07-21_23
[root@ozyrys qemu-snapshot-2005-07-21_23]# ./configure
Install prefix    /usr/local
BIOS directory    /usr/local/share/qemu
binary directory  /usr/local/bin
Manual directory  /usr/local/share/man
ELF interp prefix /usr/gnemul/qemu-%M
Source path      /root/Desktop/qemu-snapshot-2005-07-21_23
C compiler        gcc
make              make
host CPU          i386
host big endian  no
target list      i386-user arm-user armeb-user sparc-user ppc-user i386-softmmu ppc-softmmu sparc-softmmu x86_64-softmmu mips-softmmu
gprof enabled    no
static build      no
SDL support      yes
SDL static link  yes
mingw32 support  no
Adlib support    no
FMOD support      no
kqemu support    no
[root@ozyrys qemu-snapshot-2005-07-21_23]# make clean
rm -f config.mak config.h op-i386.h opc-i386.h gen-op-i386.h op-arm.h opc-arm.h gen-op-arm.h
rm -f *.o *.a qemu-img dyngen TAGS *.pod *~ */*~
make -C tests clean
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/tests'
rm -f *~ *.o test-i386.out test-i386.ref \
          test-x86_64.log test-x86_64.ref qruncom linux-test testthread sha1-i386 test-i386 runcom sha1
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/tests'
for d in i386-user arm-user armeb-user sparc-user ppc-user i386-softmmu ppc-softmmu sparc-softmmu x86_64-softmmu mips-softmmu; do \
make -C $d clean || exit 1 ; \
        done
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/i386-user'
rm -f *.o  *.a *~ qemu-i386 gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/i386-user'make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/arm-user'rm -f *.o  *.a *~ qemu-arm gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/arm-user'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/armeb-user'
rm -f *.o  *.a *~ qemu-armeb gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/armeb-user'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/sparc-user'
rm -f *.o  *.a *~ qemu-sparc gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/sparc-user'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/ppc-user'rm -f *.o  *.a *~ qemu-ppc gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/ppc-user'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/i386-softmmu'
rm -f *.o  *.a *~ qemu gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/i386-softmmu'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/ppc-softmmu'
rm -f *.o  *.a *~ qemu-system-ppc gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/ppc-softmmu'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/sparc-softmmu'
rm -f *.o  *.a *~ qemu-system-sparc gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/sparc-softmmu'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/x86_64-softmmu'
rm -f *.o  *.a *~ qemu-system-x86_64 gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/x86_64-softmmu'
make[1]: Entering directory `/root/Desktop/qemu-snapshot-2005-07-21_23/mips-softmmu'
rm -f *.o  *.a *~ qemu-system-mips gen-op.h opc.h op.h nwfpe/*.o slirp/*.o fpu/*.o
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/mips-softmmu'
gcc -Wall -O2 -g -fno-strict-aliasing  -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -o dyngen dyngen.c
dyngen.c: In function ‘load_object’:
dyngen.c:508: warning: pointer targets in assignment differ in signedness
dyngen.c:544: warning: pointer targets in assignment differ in signedness
gcc -DQEMU_TOOL -Wall -O2 -g -fno-strict-aliasing  -g -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -o qemu-img qemu-img.c block.c block-cow.c block-qcow.c aes.c block-vmdk.c block-cloop.c block-dmg.c block-bochs.c block-vpc.c block-vvfat.c -lz
block-cloop.c: In function ‘cloop_read_block’:
block-cloop.c:116: warning: pointer targets in assignment differ in signedness
block-cloop.c:118: warning: pointer targets in assignment differ in signedness
block-dmg.c: In function ‘dmg_read_chunk’:
block-dmg.c:231: warning: pointer targets in assignment differ in signedness
block-dmg.c:233: warning: pointer targets in assignment differ in signedness
block-vpc.c: In function ‘vpc_probe’:
block-vpc.c:84: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
block-vpc.c:84: warning: pointer targets in passing argument 1 of ‘__builtin_strcmp’ differ in signedness
block-vpc.c:84: warning: pointer targets in passing argument 1 of ‘strncmp’ differ in signedness
block-vvfat.c: In function ‘create_long_filename’:
block-vvfat.c:325: warning: pointer targets in passing argument 1 of ‘short2long_name’ differ in signedness
block-vvfat.c: In function ‘fat_get’:
block-vvfat.c:393: warning: pointer targets in initialization differ in signedness
block-vvfat.c: In function ‘long2unix_name’:
block-vvfat.c:446: warning: pointer targets in passing argument 1 of ‘__builtin_strncpy’ differ in signedness
block-vvfat.c:446: warning: pointer targets in passing argument 2 of ‘__builtin_strncpy’ differ in signedness
block-vvfat.c:453: warning: pointer targets in passing argument 1 of ‘__builtin_strncpy’ differ in signedness
block-vvfat.c:453: warning: pointer targets in passing argument 2 of ‘__builtin_strncpy’ differ in signedness
block-vvfat.c: In function ‘create_short_filename’:
block-vvfat.c:492: warning: pointer targets in passing argument 1 of ‘__builtin_strncpy’ differ in signedness
block-vvfat.c: In function ‘init_directory’:
block-vvfat.c:719: warning: pointer targets in passing argument 1 of ‘snprintf’ differ in signedness
block-vvfat.c: In function ‘vvfat_write’:
block-vvfat.c:1620: warning: pointer targets in passing argument 1 of ‘long2unix_name’ differ in signedness
texi2html -monolithic -number qemu-doc.texi
** `QEMU PC System emulator invocation' is up for `disk_images', but has no menu entry for this node
** `qemu_img_invocation' doesn't appear in menus
** `disk_images' is up for `qemu_img_invocation', but has no menu entry for this node
** `direct_linux_boot' doesn't appear in menus
** `QEMU PC System emulator invocation' is up for `direct_linux_boot', but has no menu entry for this node
** `gdb_usage' doesn't appear in menus
** `QEMU PC System emulator invocation' is up for `gdb_usage', but has no menu entry for this node
** `compilation' doesn't appear in menus
*** @end ignore without corresponding opening (l. 428)
** Unknown command `@voyager.localdomain)' (left as is) (l. 710)
** Unknown command `@scyld.com)' (left as is) (l. 747)
** Unknown command `@voyager.localdomain)' (left as is) (l. 770)
texi2html -monolithic -number qemu-tech.texi
*** @end itemize without corresponding opening (l. 68)
./texi2pod.pl qemu-doc.texi qemu.pod
pod2man --section=1 --center=" " --release=" " qemu.pod > qemu.1
./texi2pod.pl qemu-img.texi qemu-img.pod
pod2man --section=1 --center=" " --release=" " qemu-img.pod > qemu-img.1
make -C $d all || exit 1 ; \
        done
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o elfload.o /root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c: In function ‘load_elf_binary’:
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c:950: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c:950: warning: pointer targets in passing argument 1 of ‘__builtin_strcmp’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c:950: warning: pointer targets in passing argument 1 of ‘strncmp’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c:1088: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c:1088: warning: pointer targets in passing argument 1 of ‘__builtin_strcmp’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/elfload.c:1088: warning: pointer targets in passing argument 1 of ‘strncmp’ differ in signedness
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o main.o /root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/main.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o syscall.o /root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c: In function ‘do_getsockopt’:
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:627: warning: pointer targets in passing argument 5 of ‘getsockopt’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c: In function ‘do_syscall’:
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:1686: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:1720: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:1806: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:1807: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2237: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2238: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2239: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2240: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2241: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2242: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2243: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2244: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2245: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2246: warning: pointer targets in passing argument 1 of ‘tswap32s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2566: warning: pointer targets in passing argument 1 of ‘tswap64s’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2868: warning: pointer targets in passing argument 1 of ‘getresuid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2868: warning: pointer targets in passing argument 2 of ‘getresuid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2868: warning: pointer targets in passing argument 3 of ‘getresuid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2888: warning: pointer targets in passing argument 1 of ‘getresgid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2888: warning: pointer targets in passing argument 2 of ‘getresgid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2888: warning: pointer targets in passing argument 3 of ‘getresgid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2995: warning: pointer targets in passing argument 1 of ‘getresuid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2995: warning: pointer targets in passing argument 2 of ‘getresuid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:2995: warning: pointer targets in passing argument 3 of ‘getresuid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:3013: warning: pointer targets in passing argument 1 of ‘getresgid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:3013: warning: pointer targets in passing argument 2 of ‘getresgid’ differ in signedness
/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/syscall.c:3013: warning: pointer targets in passing argument 3 of ‘getresgid’ differ in signedness
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o mmap.o /root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/mmap.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o signal.o /root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/signal.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o path.o /root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/path.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o osdep.o /root/Desktop/qemu-snapshot-2005-07-21_23/osdep.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o thunk.o /root/Desktop/qemu-snapshot-2005-07-21_23/thunk.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o vm86.o /root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/vm86.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o exec.o /root/Desktop/qemu-snapshot-2005-07-21_23/exec.c
/root/Desktop/qemu-snapshot-2005-07-21_23/exec.c: In function ‘cpu_set_log’:
/root/Desktop/qemu-snapshot-2005-07-21_23/exec.c:1162: warning: pointer targets in passing argument 2 of ‘setvbuf’ differ in signedness
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o kqemu.o /root/Desktop/qemu-snapshot-2005-07-21_23/kqemu.c
gcc -Wall -O2 -g -fno-strict-aliasing -fomit-frame-pointer -mpreferred-stack-boundary=2 -falign-functions=0 -fno-gcse -fno-reorder-blocks -fno-optimize-sibling-calls -I. -I/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386 -I/root/Desktop/qemu-snapshot-2005-07-21_23 -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user -I/root/Desktop/qemu-snapshot-2005-07-21_23/linux-user/i386 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I/root/Desktop/qemu-snapshot-2005-07-21_23/fpu -I/root/Desktop/qemu-snapshot-2005-07-21_23/slirp -c -o op.o /root/Desktop/qemu-snapshot-2005-07-21_23/target-i386/op.c
/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386/ops_sse.h: In function ‘op_pshufw_mmx’:
/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386/ops_sse.h:574: error: unable to find a register to spill in class ‘GENERAL_REGS’
/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386/ops_sse.h:574: error: this is the insn:
(insn:HI 18 17 19 0 /root/Desktop/qemu-snapshot-2005-07-21_23/target-i386/ops_sse.h:569 (set (strict_low_part (subreg:HI (reg/v:DI 63 [ r ]) 0))
        (mem/s/j:HI (plus:SI (mult:SI (reg:SI 64)
                    (const_int 2 [0x2]))
                (reg/v/f:SI 59 [ s ])) [0 <variable>._w S2 A16])) 41 {*movstricthi_1} (insn_list:REG_DEP_TRUE 16 (insn_list:REG_DEP_TRUE 12 (insn_list:REG_DEP_TRUE 53 (nil))))
    (expr_list:REG_DEAD (reg:SI 64)
        (nil)))
/root/Desktop/qemu-snapshot-2005-07-21_23/target-i386/ops_sse.h:574: confused by earlier errors, bailing out
make[1]: *** [op.o] Błąd 1
make[1]: Leaving directory `/root/Desktop/qemu-snapshot-2005-07-21_23/i386-user'make: *** [all] Błąd 1
i co ja mam z tym zrobić ???
Może ktoś zna jakiegoś nowego snapshota pod FC4 ???
Byłbym wwdzięczny za linki oraz pomoc.
