KrzysieQ Napisano Lipiec 24, 2005 Zgłoszenie Share Napisano Lipiec 24, 2005 Zainstalowałem captive... wpisuje w konsoli captive-install-acquire zeby sie skonfigourowal - mialem juz potrzebne pliki z winxp na partycji linuxowej to jest ntfs.sys i ntoskrnl.exe wskazuje mu je - i zwis... przy skanie partycji rownież . Opcja trzecia download z SP - też zwis na koncu zasysania ale gdy go znowu odpalilem to pokazuje teraz: All needed modules were found in their best preferred versions. Found NTFS disk partitions are prepared in /etc/fstab. You can mount them by commands mount(8) or usermount(1) such as: mount /mnt/captive-LABEL_C Available captive-ntfs partitions: /mnt/captive-noname /mnt/captive-noname2 no to niby OK chce zamontowac partycje: mount -t captive-ntfs /dev/hda1 /mnt/drive-c i otrzymuje: [root@krzysieq usr]# mount -t captive-ntfs /dev/hda1 /mnt/drive-c Captive NTFS v1.1.5. Check a new version at: http://www.jankratochvil.net/ Preparing LUFS kernel module... Run /usr/share/lufs/prepmod if problems occur. lufs module not loaded: Try running /usr/share/lufs/prepmod to see more. at /usr/bin/captive-lufsd line 180 no oki uruchamiama tak jak chcial program: [root@krzysieq usr]# /usr/share/lufs/prepmod + /sbin/modprobe lufs 2>/dev/null Preparing LUFS kernel module... Run /usr/share/lufs/prepmod if problems occur. Running kernel version: 2.6.11-1.1369_FC4 (base version 2.6.11) Destination module directory: /lib/modules/2.6.11-1.1369_FC4/kernel/fs/lufs Using kernel sources: /lib/modules/2.6.11-1.1369_FC4/build + set -e; /bin/mkdir -p `dirname /var/lib/lufs/lufs.ko`; /bin/rm -f /var/lib/lufs/lufs.ko; make -C /lib/modules/2.6.11-1.1369_FC4/build SUBDIRS="/usr/share/lufs/2.6" modules EXTRA_CFLAGS=""; /bin/mv -f /usr/share/lufs/2.6/lufs.ko /var/lib/lufs/lufs.ko; /bin/rm -f /usr/share/lufs/2.6/proc.o /usr/share/lufs/2.6/.proc.o.flags /usr/share/lufs/2.6/.proc.o.cmd /usr/share/lufs/2.6/inode.o /usr/share/lufs/2.6/.inode.o.flags /usr/share/lufs/2.6/.inode.o.cmd /usr/share/lufs/2.6/dir.o /usr/share/lufs/2.6/.dir.o.flags /usr/share/lufs/2.6/.dir.o.cmd /usr/share/lufs/2.6/file.o /usr/share/lufs/2.6/.file.o.flags /usr/share/lufs/2.6/.file.o.cmd /usr/share/lufs/2.6/symlink.o /usr/share/lufs/2.6/.symlink.o.flags /usr/share/lufs/2.6/.symlink.o.cmd /usr/share/lufs/2.6/lufs.mod.o /usr/share/lufs/2.6/.lufs.mod.o.flags /usr/share/lufs/2.6/.lufs.mod.o.cmd /usr/share/lufs/2.6/lufs.o /usr/share/lufs/2.6/.lufs.o.flags /usr/share/lufs/2.6/.lufs.o.cmd /usr/share/lufs/2.6/lufs.mod.c /usr/share/lufs/2.6/.lufs.ko.cmd; make: Entering directory `/usr/src/kernels/2.6.11-1.1369_FC4-i686' CC [M] /usr/share/lufs/2.6/dir.o CC [M] /usr/share/lufs/2.6/file.o CC [M] /usr/share/lufs/2.6/inode.o CC [M] /usr/share/lufs/2.6/proc.o CC [M] /usr/share/lufs/2.6/symlink.o LD [M] /usr/share/lufs/2.6/lufs.o Building modules, stage 2. MODPOST *** Warning: "kill_proc_info" [/usr/share/lufs/2.6/lufs.ko] undefined! CC /usr/share/lufs/2.6/lufs.mod.o LD [M] /usr/share/lufs/2.6/lufs.ko make: Leaving directory `/usr/src/kernels/2.6.11-1.1369_FC4-i686' + /bin/rm -rf /lib/modules/2.6.11-1.1369_FC4/kernel/fs/lufs; /bin/mkdir -p /lib/modules/2.6.11-1.1369_FC4/kernel/fs/lufs; /bin/ln -s /var/lib/lufs/lufs.ko /lib/modules/2.6.11-1.1369_FC4/kernel/fs/lufs/lufs.ko + /sbin/rmmod lufs 2>/dev/null; /sbin/insmod /lib/modules/2.6.11-1.1369_FC4/kernel/fs/lufs/lufs.ko 2>/dev/null Failed to prepare lufs.ko module for your Linux kernel 2.6.11-1.1369_FC4. Detected Linux kernel sources "/lib/modules/2.6.11-1.1369_FC4/build" do not appear to be valid. Please install kernel-source-x.y.z.i386.rpm or kernel-headers_x.y.z_i386.deb. The following directory paths were search (first existing directory used): /lib/modules/2.6.11-1.1369_FC4/build /usr/src/kernel-headers-2.6.11-1.1369_FC4 /usr/src/linux-2.6.11-1.1369_FC4 /usr/src/linux-2.6.11 /usr/src/linux /usr/src/kernel-source-2.6.11-1.1369_FC4 at /usr/share/lufs/prepmod line 181 You have new mail in /var/spool/mail/root POMOCY !! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
