Update Yumem I Jakieś Zależności
spyro
witam
mam problem z updatem systemu
jak wpisuje yum update to wywala coś takiego
[root@assassin spyro]# yum update
Setting up Update Process
Setting up repositories
livna                     100% |=========================|  951 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
updates-released          100% |=========================|  951 B    00:00
base                      100% |=========================| 1.1 kB    00:00
kadu                      100% |=========================|  951 B    00:00
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package libsepol.i386 0:1.5.10-1.1 set to be updated
---> Package libcddb.i386 0:1.1.0-1.fc4 set to be updated
--> Running transaction check
--> Processing Dependency: libcddb.so.0 for package: libcdio
--> Finished Dependency Resolution
Error: Missing Dependency: libcddb.so.0 is needed by package libcdio
i co mam z tymzrobić żeby updateować system ??
No spyro u mnie to byl blad wynikly z zainstalowania paczki do xine i amarok-xine "z palca" a nie z repo. Zainstalowalem te paczki (z livny co prawda) jeszcze zanim pojawily sie w repozytoriach recznie... efekt? Ten blad co mielismy obaj wczesniej + to co dzisiaj mi wyskoczylo jak sprawdzalem aktualizacje:
[patpi@localhost ~]$ su
Password:
[root@localhost ~]# upp
macromedia                100% |=========================|  903 B    00:00
primary.xml.gz            100% |=========================| 475 kB    00:29
extras    : ################################################## 1354/1354
Added 3 new packages, deleted 0 old in 1.64 seconds
---> Package cpp.i386 0:4.0.1-4.fc4 set to be updated
---> Downloading header for libcddb to pack into transaction set.
libcddb-1.2.0-2.fc4.i386. 100% |=========================| 3.9 kB    00:00
---> Package libcddb.i386 0:1.2.0-2.fc4 set to be updated
---> Package libgcj.i386 0:4.0.1-4.fc4 set to be updated
--> Processing Dependency: libcdio.so.5(CDIO_5) for package: vcdimager
--> Processing Dependency: libcdio.so.5 for package: xine-lib
--> Processing Dependency: libcdio.so.5 for package: vcdimager
--> Processing Dependency: libcdio.so.5(CDIO_5) for package: xine-lib
Error: Missing Dependency: libcdio.so.5(CDIO_5) is needed by package vcdimager
Error: Missing Dependency: libcdio.so.5 is needed by package xine-lib
Error: Missing Dependency: libcdio.so.5 is needed by package vcdimager
Error: Missing Dependency: libcdio.so.5(CDIO_5) is needed by package xine-lib
[root@localhost ~]#
to stwierdzilem ze cos musi byc nie tak u mnie w systemie. Najpierw odpalilem
package-cleanup --problems
ale yum(link do WIKI o tym) powiedzial ze nie ma zadnych problemow z zaleznosciami, kombinujemy dalej...
rpm -q vcdimager i rpm -q xine-lib potwierdzilo ze to moga byc wzajemnie klocace sie repozytoria Livna vs. updates-released. Decyzja: wywalam klopotliwe paczki:
rpm -e vcdimager i rpm -e xine-lib, tylko oczywiscie bylo sporo zaleznosci:
       libxine.so.1 jest wymagany przez (zainstalowany) xine-0.99.3-0.lvn.8.4.i386
       libxine.so.1 jest wymagany przez (zainstalowany) amarok-xine-1.2.4-6.1.fc4.kde.i386
       libxine.so.1 jest wymagany przez (zainstalowany) kaffeine-0.6-0.lvn.1.4.i386
       libxine.so.1 jest wymagany przez (zainstalowany) kdemultimedia-extras-3.4.1-0.lvn.1.4.i386
to, zeby sie nie meczyc, bo nie widzialem czy na tym sie skonczy ;) odpalilem yumexa i wywalilem vcdimager i xine-lib wraz z zaleznosciami.
Po tym yum update ruszylo bez problemu czego dowodem zaktualizowany system:
No Packages marked for Update/Obsoletion
prawie :) , prawie bo jeszcze chcialem doinstalowac yumem: xine, amarok-xine, kaffeine i kdemultimedia-extras ktorych potrzebuje ale wyskakuja te same bledy co wczesniej. Czyli to te paczki sa zle, cos z nimi nie tak. Poki co bez nich sie obejde. ale przydaloby sie by to naprawili...
moze podobnie rozwiazesz (czesciowo) swoj problem, ja wole miec dostep do aktualizacji systemu niz do Xine (w koncu w amaroKu moge uzywac innego serweru dzwieku a do filmow to i tak KPlayer :) )
pozdrawiam
a jest jakaś możliwość w yumie żeby podczas aktualizacji ignorował jakieś paczki np. tą co sprawia problemy
biorac pod uwage ze paczki ktore mi sprawialy problem pochodzily z Livny to mozna tak...
# --disablerepo=repoid[/b] - pozwala na tymczasowe wyłączenie repozytorium
Przydatne w przypadku problemów z zależnościami.
Odpowiadająca opcja w pliku konfiguracyjnym: enabled
czyli yum --disablelerepo=livna update powinno pomoc. Lub wylaczenie livny na stale. Ale ja skoro i tak uzywam KPlayera a w amaroKu mam Gstreamer to wolalem zrobic porzadek w systemia....
jak chcesz, powinno zadzialac...
PS. Zajrzyj w ten artykul o yumie na WIKI, warto
http://wiki.stemar.com.pl/wiki/
ha, juz wszystko gra. Teraz zrobilem yum install xine kaffeine i reszte i sie zainstalowalo. Naprawili te paczuszki i wszystko smiga...
Najgorsze jest to że apt-get chyba nie ma takich problemów :/.
ale jezeli te same paczki sa w repozytoriach apta i yuma - a sa te same - to yum jest lepszy bo (_odrazu_ → od razu) ORT wykrywa potencjalne bledy. A nie "w praniu" -> "oo, Xine mi sie sypie" ;)
