Kompilacja 2.6.12.4 +fc4+ Problem ?
itlukasz
czesc, mam Fc4 ściagłem z kernel.org kernel 2.6.12.4 przy make xconfig dostaje takie coś, które podam poniżej ale konfiguracja uruchamia sie noramlnie tylko nie wiem czy to nie jest jakiś problem który powinienem rozwiązać przed kompilacją.
A oto co dostałem:
linux-2.6.12.4]# make xconfig
 HOSTCC  scripts/basic/fixdep
scripts/basic/fixdep.c: In function ‘parse_config_file’:
scripts/basic/fixdep.c:245: warning: pointer targets in passing argument 1 of ‘use_config’ differ in signedness
scripts/basic/fixdep.c: In function ‘parse_dep_file’:
scripts/basic/fixdep.c:299: warning: pointer targets in passing argument 1 of ‘__builtin_strchr’ differ in signedness
scripts/basic/fixdep.c:299: warning: pointer targets in assignment differ in signedness
 HOSTCC  scripts/basic/split-include
scripts/basic/split-include.c: In function ‘main’:
scripts/basic/split-include.c:113: warning: pointer targets in assignment differ in signedness
 HOSTCC  scripts/basic/docproc
scripts/basic/docproc.c: In function ‘find_export_symbols’:
scripts/basic/docproc.c:184: warning: pointer targets in assignment differ in signedness
scripts/basic/docproc.c:185: warning: pointer targets in assignment differ in signedness
scripts/basic/docproc.c:202: warning: pointer targets in passing argument 2 of ‘add_new_symbol’ differ in signedness
scripts/basic/docproc.c: In function ‘singfunc’:
scripts/basic/docproc.c:274: warning: pointer targets in assignment differ in signedness
scripts/basic/docproc.c: In function ‘parse_file’:
scripts/basic/docproc.c:296: warning: pointer targets in assignment differ in signedness
 SHIPPED scripts/kconfig/zconf.tab.h
 HOSTCC  scripts/kconfig/conf.o
scripts/kconfig/conf.c: In function ‘strip’:
scripts/kconfig/conf.c:46: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
scripts/kconfig/conf.c: In function ‘conf_askvalue’:
scripts/kconfig/conf.c:94: warning: pointer targets in passing argument 1 of ‘fgets’ differ in signedness
scripts/kconfig/conf.c: In function ‘conf_string’:
scripts/kconfig/conf.c:187: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
scripts/kconfig/conf.c:188: warning: pointer targets in assignment differ in signedness
scripts/kconfig/conf.c: In function ‘conf_sym’:
scripts/kconfig/conf.c:236: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
scripts/kconfig/conf.c:236: warning: pointer targets in passing argument 1 of ‘__builtin_strcmp’ differ in signedness
scripts/kconfig/conf.c:248: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
scripts/kconfig/conf.c:248: warning: pointer targets in passing argument 1 of ‘__builtin_strcmp’ differ in signedness
scripts/kconfig/conf.c: In function ‘conf_choice’:
scripts/kconfig/conf.c:350: warning: pointer targets in passing argument 1 of ‘fgets’ differ in signedness
scripts/kconfig/conf.c:360: warning: pointer targets in passing argument 1 of ‘atoi’ differ in signedness
scripts/kconfig/conf.c:384: warning: pointer targets in passing argument 1 of ‘strlen’ differ in signedness
sed < scripts/kconfig/lkc_proto.h > scripts/kconfig/lkc_defs.h 's/P(\([^,]*\),.*/#define \1 (\*\1_p)/'
 HOSTCC  scripts/kconfig/kconfig_load.o
 HOSTCC  scripts/kconfig/kxgettext.o
 HOSTCC  scripts/kconfig/mconf.o
scripts/kconfig/mconf.c: In function ‘cprint1’:
scripts/kconfig/mconf.c:337: warning: pointer targets in assignment differ in signedness
scripts/kconfig/mconf.c:339: warning: pointer targets in passing argument 1 of ‘vsprintf’ differ in signedness
scripts/kconfig/mconf.c: In function ‘cprint’:
scripts/kconfig/mconf.c:357: warning: pointer targets in assignment differ in signedness
scripts/kconfig/mconf.c:359: warning: pointer targets in passing argument 1 of ‘vsprintf’ differ in signedness
scripts/kconfig/mconf.c: In function ‘search_conf’:
scripts/kconfig/mconf.c:550: warning: pointer targets in passing argument 1 of ‘sym_re_search’ differ in signedness
scripts/kconfig/mconf.c: In function ‘conf’:
scripts/kconfig/mconf.c:761: warning: pointer targets in passing argument 2 of ‘strcpy’ differ in signedness
scripts/kconfig/mconf.c:765: warning: pointer targets in passing argument 1 of ‘sscanf’ differ in signedness
scripts/kconfig/mconf.c: In function ‘conf_choice’:
scripts/kconfig/mconf.c:915: warning: pointer targets in passing argument 1 of ‘sscanf’ differ in signedness
scripts/kconfig/mconf.c:920: warning: pointer targets in passing argument 1 of ‘sscanf’ differ in signedness
scripts/kconfig/mconf.c: In function ‘conf_string’:
scripts/kconfig/mconf.c:961: warning: pointer targets in passing argument 2 of ‘sym_set_string_value’ differ in signedness
scripts/kconfig/mconf.c: In function ‘conf_load’:
scripts/kconfig/mconf.c:990: warning: pointer targets in passing argument 1 of ‘conf_read’ differ in signedness
scripts/kconfig/mconf.c: In function ‘conf_save’:
scripts/kconfig/mconf.c:1019: warning: pointer targets in passing argument 1 of ‘conf_write’ differ in signedness
 SHIPPED scripts/kconfig/zconf.tab.c
 SHIPPED scripts/kconfig/lex.zconf.c
 HOSTCC  scripts/kconfig/zconf.tab.o
In file included from scripts/kconfig/zconf.tab.c:2125:
scripts/kconfig/confdata.c: In function ‘conf_expand_value’:
scripts/kconfig/confdata.c:39: warning: pointer targets in passing argument 1 of ‘__builtin_strchr’ differ in signedness
scripts/kconfig/confdata.c:39: warning: pointer targets in assignment differ in signedness
scripts/kconfig/confdata.c:40: warning: pointer targets in passing argument 2 of ‘__builtin_strncat’ differ in signedness
scripts/kconfig/confdata.c:51: warning: pointer targets in passing argument 2 of ‘strcat’ differ in signedness
scripts/kconfig/confdata.c: In function ‘conf_get_default_confname’:
scripts/kconfig/confdata.c:62: warning: pointer targets in passing argument 1 of ‘conf_expand_value’ differ in signedness
scripts/kconfig/confdata.c: In function ‘conf_read’:
scripts/kconfig/confdata.c:88: warning: pointer targets in passing argument 1 of ‘conf_expand_value’ differ in signedness
/usr/lib/qt-3.3/bin/moc -i scripts/kconfig/qconf.h -o scripts/kconfig/qconf.moc
 HOSTCXX scripts/kconfig/qconf.o
 HOSTLD  scripts/kconfig/qconf
scripts/kconfig/qconf arch/i386/Kconfig
# using defaults found in /boot/config-2.6.11-1.1369_FC4
/boot/config-2.6.11-1.1369_FC4:62: trying to assign nonexistent symbol MODULE_SIG
/boot/config-2.6.11-1.1369_FC4:63: trying to assign nonexistent symbol MODULE_SIG_FORCE
/boot/config-2.6.11-1.1369_FC4:493: trying to assign nonexistent symbol DISKDUMP
/boot/config-2.6.11-1.1369_FC4:518: trying to assign nonexistent symbol BLK_DEV_DELKIN
/boot/config-2.6.11-1.1369_FC4:557: trying to assign nonexistent symbol BLK_DEV_IT821X
/boot/config-2.6.11-1.1369_FC4:1161: trying to assign nonexistent symbol TUX
/boot/config-2.6.11-1.1369_FC4:1166: trying to assign nonexistent symbol TUX_EXTCGI
/boot/config-2.6.11-1.1369_FC4:1167: trying to assign nonexistent symbol TUX_EXTENDED_LOG
/boot/config-2.6.11-1.1369_FC4:1168: trying to assign nonexistent symbol TUX_DEBUG
/boot/config-2.6.11-1.1369_FC4:1335: trying to assign nonexistent symbol IEEE80211
/boot/config-2.6.11-1.1369_FC4:1336: trying to assign nonexistent symbol IEEE80211_DEBUG
/boot/config-2.6.11-1.1369_FC4:1337: trying to assign nonexistent symbol IEEE80211_CRYPT
/boot/config-2.6.11-1.1369_FC4:1338: trying to assign nonexistent symbol IEEE80211_WPA
/boot/config-2.6.11-1.1369_FC4:1339: trying to assign nonexistent symbol IEEE80211_CRYPT_CCMP
/boot/config-2.6.11-1.1369_FC4:1340: trying to assign nonexistent symbol IEEE80211_CRYPT_TKIP
/boot/config-2.6.11-1.1369_FC4:1341: trying to assign nonexistent symbol IPW2100
/boot/config-2.6.11-1.1369_FC4:1342: trying to assign nonexistent symbol IPW_DEBUG
/boot/config-2.6.11-1.1369_FC4:1343: trying to assign nonexistent symbol IPW2100_PROMISC
/boot/config-2.6.11-1.1369_FC4:1344: trying to assign nonexistent symbol IPW2100_LEGACY_FW_LOAD
/boot/config-2.6.11-1.1369_FC4:1345: trying to assign nonexistent symbol IPW2200
/boot/config-2.6.11-1.1369_FC4:1669: trying to assign nonexistent symbol SOUND_GAMEPORT
/boot/config-2.6.11-1.1369_FC4:1720: trying to assign nonexistent symbol CRASH
/boot/config-2.6.11-1.1369_FC4:2769: trying to assign nonexistent symbol DETECT_SOFTLOCKUP
/boot/config-2.6.11-1.1369_FC4:2833: trying to assign nonexistent symbol CRYPTO_SIGNATURE
/boot/config-2.6.11-1.1369_FC4:2834: trying to assign nonexistent symbol CRYPTO_SIGNATURE_DSA
/boot/config-2.6.11-1.1369_FC4:2835: trying to assign nonexistent symbol CRYPTO_MPILIB
no i normalnie przechodzi do konfiguracji tylko nie wiem czy robić konfig czy coś poprawić .
aktualnie mam:
# uname -a
Linux Kacper 2.6.11-1.1369_FC4 #1 Thu Jun 2 22:55:56 EDT 2005 i686 i686 i386 GNU/Linux
za info z góry thx
[edit]
zrobiłem link symboliczny i problem znikł
pozdrawiam
