Nie Moge Zainstalować Checkinstall
cildo
No właśnie nie moge, robie tak:
[root@localhost checkinstall-1.5.3]# make
make -C installwatch-0.6.3
make[1]: Entering directory `/home/adam/Instalki/checkinstall-1.5.3/installwatch-0.6.3'
make[1]: Nie nic do roboty w `all'.
make[1]: Leaving directory `/home/adam/Instalki/checkinstall-1.5.3/installwatch-0.6.3'
[root@localhost checkinstall-1.5.3]# make install
cp checkinstall makepak /usr/local/sbin
make -C installwatch-0.6.3 install
if [ -r /usr/local/lib/installwatch.so ]; then rm  /usr/local/lib/installwatch.so; export LD_PRELOAD=""; cp installwatch.so /usr/local/lib; LD_PRELOAD=/usr/local/lib/installwatch.so; else cp installwatch.so /usr/local/lib; fi
sed -e "s|#PREFIX#|/usr/local|" < installwatch > /usr/local/bin/installwatch
chmod 755 /usr/local/bin/installwatch
mkdir -p /usr/local/lib/checkinstall
cp checkinstallrc /usr/local/lib/checkinstall
[root@localhost checkinstall-1.5.3]# ./checkinstall
checkinstall 1.5.3, Copyright 2001 Felipe Eduardo Sanchez Diaz Duran
          This software is released under the GNU GPL.
Installing with "make install"...
========================= Installation results ===========================
Copying documentation directory...
/var/tmp/XPaJNdrPAJdfIRATXGnC/installscript.sh: line 13:  3453 Naruszenie ochrony pamięci   mkdir -p "/usr/doc/checkinstall-1.5.3"
****  Installation failed. Aborting package creation.
Cleaning up...OK
Bye.
a w pliku : INSTALL pisze:
[root@localhost checkinstall-1.5.3]# cat INSTALL
INSTALLATION INSTRUCTIONS
Simple enough:
make
su
make install
checkinstall
"make install" goes first because we have no checkinstall installed yet :)
"checkinstall" goes latter so we can have a properly installed (and removable)
              package for checkinstall-1.5.3
              (Be sure to read the README if you're planning on building RPM or
               Debian binary packages)
This will install checkinstall-1.5.3, makepak (modified makepkg) and
installwatch-0.6.3.
$Id: INSTALL,v 1.5.3.1 2002/09/11 05:26:29 izto Exp $
Zamieniałem tą ostatnią linijke na : ./checkinstall
bo jak wpisywalem saqmo checkinstall to pisalo:
[root@localhost checkinstall-1.5.3]# checkinstall
bash: checkinstall: command not found
CZemu ? :(
aha.... Fedora Core 2 :)
Gość _PaT
Wygląda na to, że chceckinstall zainstalował się poprawie, a jedynie nie może odnaleźć pliku wejściowego przy wpisaniu checkinstall.
Spróbuj takie polecenie
ln -s /usr/local/sbin/checkinstall /usr/bin
Powinno to utworzyć odpowieniego symlinka i rozwiązać problem.
Gość _PaT
Ok, stworzyło jakis plik, dzięki _PAT :)... narazie nie sprawdze czy dobrze działą checkinstall bo nie mam żadnych źródeł.
Btw, czemu Twój pingwin _PAT chodzi do góry nogami ? :)
Nie musisz mieć źródeł. Sprawdź, czy polecenie checkinstall w konsoli uruchamia program czy znowu wyskakuje komunikat z błędem. A co do pingwina to przedstawia mój dziwny sposób patrzenia na świat (największe potęgi - umysł i głupota - patrz podpis). Zauważ, że nie łatwo temu pingwinowi egzystować w ten sposób (to nie wańka-wstańka).
no niby jak wpiuje samo checkinstall tak normalnie to sie pojawia jakies tam info
ale jak chcem cos konkretnego zdzialac to:
[root@localhost kadu]# checkinstall
The package documentation directory ./doc-pak does not exist.
Should I create a default set of package docs? [y]: y
Preparing package documentation...OK
/var/tmp/hgrLnJUhQYQBYNcFTYES/installscript.sh: line 13: 22184 Naruszenie ochrony pamięci mkdir -p "/usr/doc/kadu"
Cleaning up...OK
Bye.
:( i tak na wszystkich źródłach jets ? :(
FC2
Wywal tą wersje checkinstall, ściągnij pakiet źródłowy np.stąd:
http://apt.sw.be/fedora/2/en/i386/SRPMS.dag/
przebuduj paiet:
rpmbuild --rebuild paiet_z_powyższego_źródła
i może będzie oki ;)
PS. widzę że "kombinujesz z kadu... możesz użyć do instalacji (upgrade) apt`a. Dopisz do /etc/apt/sources.list te repozytorium:
### Kadu
rpm http://kadu.net/~nastian/ apt-kadu/fedora/2 kadu dodatki modules
i będzie łatwo i przyjemnie ;)
pozdr
