Berkeley Db :/
Arkadio
Witam! Mam problem z tym czyms przy instalacji dniff wyskakuje mi
checking for Berkeley DB with 1.85 compatibility... configure: error: Berkeley DB with 1.85 compatibility not found
no to próbuje z kompilowac gdzies wyczytalem ze to pomoze:
[Arkadio@mistral dist]$ configure --enable-compat185
bash: configure: command not found
[Arkadio@mistral dist]$ ./configure --enable-compat185
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking if building in the top-level or dist directories... yes
configure: error: Berkeley DB should not be built in the top-level or dist directories.
no niestety nie pomga :/ wiecie moze w czym jest problem ?? prosze o pomoc bo sie juz z tym mecze z 2 tygodnie
pisze przeciez w moim poprzednim poscie ze juz to robilem i nie dziala :)
dobra juz se z tym poradzilem tylko teraz niektorych bibliotek mi brakuje hmm nie moge ich znalezc
loading cache ./config.cache
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking for ranlib... (cached) ranlib
checking how to run the C preprocessor... (cached) gcc -E
checking for X... (cached) libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for dnet_ntoa in -ldnet... (cached) no
checking for dnet_ntoa in -ldnet_stub... (cached) no
checking for gethostbyname... (cached) yes
checking for connect... (cached) yes
checking for remove... (cached) yes
checking for shmat... (cached) yes
checking for IceConnectionNumber in -lICE... (cached) yes
checking for ANSI C header files... (cached) yes
checking for err.h... (cached) yes
checking for fcntl.h... (cached) yes
checking for sys/ioctl.h... (cached) yes
checking for sys/queue.h... (cached) yes
checking for unistd.h... (cached) yes
checking for libgen.h... (cached) yes
checking for net/if_tun.h... (cached) no
checking for MIN and MAX in sys/param.h... yes
checking for working const... (cached) yes
checking for size_t... (cached) yes
checking whether struct tm is in sys/time.h or time.h... (cached) time.h
checking for u_int32_t... (cached) yes
checking for u_int64_t... (cached) yes
checking for in_addr_t... (cached) no
checking whether gcc needs -traditional... (cached) no
checking for 8-bit clean memcmp... (cached) yes
checking return type of signal handlers... (cached) void
checking for strftime... (cached) yes
checking for gethostname... (cached) yes
checking for socket... (cached) yes
checking for strdup... (cached) yes
checking for strstr... (cached) yes
checking for xdr_fhstatus in -lrpcsvc... (cached) yes
checking for socket in -lsocket... (cached) no
checking for gethostbyname in -lnsl... (cached) yes
checking for dn_expand in -lresolv... (cached) yes
checking for dirname... (cached) yes
checking for strlcpy... (cached) no
checking for strlcat... (cached) no
checking for strsep... (cached) yes
checking for MD5Update... (cached) no
checking for warnx... (cached) yes
checking for ether_ntoa... (cached) yes
checking for Berkeley DB with 1.85 compatibility... yes
checking for libpcap... yes
checking for libnet... yes
checking for libnids... yes
checking whether libnids version is good... yes
checking for OpenSSL... yes
creating ./config.status
creating Makefile
creating config.h
config.h is unchanged
potem jjest jakis blad przy make install i lipa co tu ja mam doinstalowac : ( ?
