Jak Aktualizować?
czatman
W Fedorze do aktualizacji systemu lepiej jest jednak używać programu yum niż up2date.
Nakładka na yuma np: yumex
Dopowiem jeszcze że jest bardzo przyjmena nakładka na yum - kyum.
Daje możliwość instalacji, odinstlowania pakietów + graficzna konfiguracja repozytoriów.
[root@localhost ~]# yum update
Setting up Update Process
Setting up repositories
livna                     100% |=========================|  951 B    00:00
updates-released          100% |=========================|  951 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
base                      100% |=========================| 1.1 kB    00:00
kadu                      100% |=========================|  951 B    00:00
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package kdemultimedia.i386 6:3.4.2-0.fc4.1 set to be updated
---> Package kdeaddons.i386 0:3.4.2-0.fc4.1 set to be updated
---> Package kdenetwork.i386 7:3.4.2-0.fc4.1 set to be updated
---> Package kdesdk-devel.i386 0:3.4.2-0.fc4.1 set to be updated
---> Package kdepim.i386 6:3.4.2-0.fc4.3 set to be updated
---> Package kdepim-devel.i386 6:3.4.2-0.fc4.3 set to be updated
---> Package nvidia-glx.i386 0:1.0.7676-0.lvn.1.4 set to be updated
---> Package kdegraphics-devel.i386 7:3.4.2-0.fc4.1 set to be updated
---> Package kdelibs.i386 6:3.4.2-0.fc4.1 set to be updated
---> Package kdevelop.i386 9:3.2.2-0.fc4.1 set to be updated
---> Package kdeartwork.i386 0:3.4.2-0.fc4.1 set to be updated
---> Package kdebase-devel.i386 6:3.4.2-0.fc4.1 set to be updated
---> Package kdenetwork-devel.i386 7:3.4.2-0.fc4.1 set to be updated
---> Package kdesdk.i386 0:3.4.2-0.fc4.1 set to be updated
---> Package kdeutils.i386 6:3.4.2-0.fc4.1 set to be updated
---> Package kdeutils-devel.i386 6:3.4.2-0.fc4.1 set to be updated
---> Package kdegraphics.i386 7:3.4.2-0.fc4.1 set to be updated
---> Package kdebase.i386 6:3.4.2-0.fc4.1 set to be updated
---> Package kde-i18n-Polish.noarch 1:3.4.2-0.fc4.1 set to be updated
---> Package kdelibs-devel.i386 6:3.4.2-0.fc4.1 set to be updated
--> Running transaction check
--> Processing Dependency: kernel-module-nvidia = 0:1.0.7676 for package: nvidia-glx
--> Processing Dependency: nvidia-glx = 0:1.0.7174 for package: kernel-module-nvidia-2.6.11-1.1369_FC4
--> Restarting Dependency Resolution with new changes.
---> Package kernel-module-nvidia-2.6.12-1.1398_FC4.i686 0:1.0.7676-0.lvn.1.4 set to be updated
--> Finished Dependency Resolution
Error: Missing Dependency: nvidia-glx = 0:1.0.7174 is needed by package kernel-module-nvidia-2.6.11-1.1369_FC4
a co z takim kłopotem poradzic ????
Heh, z aktualizacja modułów jądra zawsze były problemy <_< Musisz odinstalować stare stery (a przynajmniej moduł do jądra), żeby można było je zupgade'ować.
Stef: przeciez ma dodane rpm.livna.org :P
Zaczołem dopiero używać
gnome-yum http://freshmeat.net/projects/gnome-yum/
na początku troche trudna obsługa programu
a zaleta to ze w jednym oknie "All" widzimy co mamy zainstalowane,
a co nie i co możemy uaktualnić
Mnie o taki program zawsze chodziło
ja rowniez poszukiwalem takiej nakladki na yuma, wlasnie tylko dlatego jeszcze na FC3 instaluje pakiety przy pomocy apt/synaptica,
szkoda tylko ze nie ma gotowej paczki gnome-yum dla FC3 :( no trudno bede musial samemu skompilowac ;)
