Profesjonalny Serwer
tedew
witam
ostatnio postanowiłem postawić sobie serwer na Apache który będzie widziany z zewnątrza - nie jako localhost. Poczytałem, poszukałem i prawie zrobiłem :) . Prawie bo mam problem z SSL - nie działa :(
oto listing z httpd.conf ważnych żeczyrzeczy z tym związanych
ServerRoot "/usr/local/apache2"
Listen 12.34.56.78:80
Listen 12.34.56.78:443
User nobody
Group #-1
ServerAdmin [email protected]
ServerName 12.34.56.78
DocumentRoot "/home/www/"
<Directory "/home/www/">
   AllowOverride None
</Directory>
UserDir public_html
#<Directory /home/*/public_html>
#    AllowOverride FileInfo AuthConfig Limit Indexes
#    Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
#    <Limit GET POST OPTIONS PROPFIND>
#        Order allow,deny
#        Allow from all
#    </Limit>
#    <LimitExcept GET POST OPTIONS PROPFIND>
#        Order deny,allow
#        Deny from all
#    </LimitExcept>
#</Directory>
DirectoryIndex index.html index.html.var
AccessFileName .htaccess
AddDefaultCharset ISO-8859-2
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ~ "^\.ht">
   Order allow,deny
   Deny from all
</Files>
<IfModule mod_ssl.c>
   Include conf/ssl.conf
</IfModule>
NameVirtualHost 12.34.56.78:80
NameVirtualHost 12.34.56.78:443
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for requests without a known
# server name.
<VirtualHost 12.34.56.78:80>
   DocumentRoot /home/wwww/
   ErrorLog logs/dummy-host.example.com-error_log
   CustomLog logs/dummy-host.example.com-access_log common
</VirtualHost>
<VirtualHost 12.34.56.78:443>
ServerName 12.34.56.78:443
ErrorLog logs/localhost-error_log
CustomLog logs/localhost-access_log common
SSLEngine on
SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL
SSLCertificateFile /usr/local/apache2/conf/ssl.crt/server.crt
SSLCertificateKeyFile /usr/local/apache2/conf/ssl.key/server.key
SetEnvIf User-Agent "."MSIE.*" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
</VirtualHost>
jak wpisze
http://12.34.56.78:80 to działa -zgłasza sie apache:)
jak pisze
https://12.34.56.78:443 nie działa :(
wywala
Not Found
The requested URL / was not found on this server.
Apache/2.0.54 (Unix) mod_ssl/2.0.54 OpenSSL/0.9.7f Server at 12.34.56.78  Port 443
startowałem apache jako zwykły i jako ssl ,czyli :
apachectl start
apachectl startssl
certyfikaty generowałem ,prawa sprawdzałem na kat (dałem naraznie 777 wszędzie dla testu ) , czytałem gdzie tylko sie da - ale nie mogę sobie poradzić :(
pozdr.
Eeee każdy apacz odpalony jest widziany z sieci (domyślnie nasłuchuje na porcie 80).
Ja nie wiem po co sobie ustawiłeś nazwę serwera na 12.34.56.78. Zostaw to w spokoju, albo wpisz swoje ip. Tak samo z Lizten - wpisz po prostu porty, czyli
Listen 80
Listen 443
W dyrektywie VirtualHost zrób sobie
<VirtualHost *:80> i analogicznie dla SSL
A Co do Twojego błędu to w dyrektywie VirtualHost:
ServerName 12.34.56.78:443 winno być ServerName 12.34.56.78 i powinno działać.
Bergo
@bergo
Dzięki za pomoc :) - pomogło :)
mam teraz inny problem ( trzeba rozbudować serwer :D ) a php 4
użyłem takiej konfiguracji
/configure --prefix=/usr/local/php4 --with-config-file-path=/usr/local/php4 --sysconfdir=/usr/local/php4 --with-apxs2=/usr/local/apache2/bin/apxs --with-mysql=/usr/local/mysql --with-openssl=/usr/local/openssl --enable-discard-path --enable-debug --enable-track-vars --enable-versioning --with-openssl=/usr/local/openssl --with-xml --enable-bcmath --with-bz2 --enable-calendar --with-ttf=/usr/lib --with-curl --with-db --with-dbase --with-pear --enable-exif --enable-ftp --with-gettext --with-iconv  --enable-mbstring   --with-zlib --with-gd --with-gd-native-ttf   --with-kerberos --with-ncurses
potem make i make install
wszytsko OKI
jak chce przeprowadzić test lub włączyć apache dostaje to
[root@localhost bin]# ./apachectl -t
Syntax error on line 234 of /usr/local/apache2/conf/httpd.conf:
Cannot load /usr/local/apache2/modules/libphp4.so into server: /usr/local/apache2/modules/libphp4.so: cannot restore segment prot after reloc: Permission denied
a jestem zalogowany na Root
linie o które się czepia to
234: LoadModule php4_module modules/libphp4.so
235: AddType application/x-httpd-php .php
236: AddType application/x-httpd-php .php4
nie mam pojęcia o co mu chodzi :(
pozd.
--enable-debug
Masz zamiar modyfikować kod php i go debugować?
Brakuje opcji --with-pic → http://cvs.fedora.redhat.com/viewcvs/rpms/...r1=1.65&r2=1.66
Jesli już samemu wszystko kompilujesz i nie używasz dystrybucyjnych paczek, to mam nadzieję, że zapiszesz się na grupy mailingowe informujące o nowych błędach bezpieczeńśtwa, a potem będziesz na bieżaco łatał ten serwer. Jak widzę jak niektórzy skompilują raz serwer i potem resztę olewają, to sie nóź w kieszeni otwiera...
ta cała konfiguracja co podałem to znaleziona na necie .
Te opisy czesto robią ludzie nieznający się na rzeczy i wprowadzają tylko w błąd <_< Np. ta opcja debugowania - przez nią przecież php będzie chodziło wolniej.
Najprościej jest zainstalować gotowe paczki. Polityki bezpieczeństwa SELinux są do nich dostosowane, a deweloperzy dbają o szybkie łatanie.. Jeśli chodzi o aplikacje serwerowe w Fedorze, to głównie backportuje się patche, więc prawdopodobieństwo, że coś po aktualizacji nie będzie działać, spada do minimum.
yum install httpd mysql mysql-server php-mysql php-gd php-mbstring php
/edit/
Widzę, że chcesz PHP4. z PHP 5 nie działa dobrze? Jeśli koniecznie potrzeba Ci PHP4, to przekompiluj paczki srpm z FC3 (weź z repo updates). W yumie potem dodaj opcję exlude, by Ci się potem nie aktualizowały do php-5.
hey:)
tylko tak generalnie chodzi o to że ja to wszystko robię tak z palca w celach edukacyjnych :)
sam sobie postawiłem apache , mysql , dodałem obsługę CGI i teraz przyszła pora na PHP 4 i 5 ( narazie 4 :) )
wyrzuciłem trochę z configure - tyle zostawiłem :)
/configure --prefix=/usr/local/php4 --with-config-file-path=/usr/local/php4 --sysconfdir=/usr/local/php4 --with-apxs2=/usr/local/apache2/bin/apxs --with-mysql=/usr/local/mysql --with-openssl=/usr/local/openssl  --enable-track-vars --with-xml
ale dalej mam to samo :(
Syntax error on line 235 of /usr/local/apache2/conf/httpd.conf:
już naprawdę nie wiem co jest nie tak :(
DZIS :)
witam
niestety nie duało sie jako moduł - rózne wersjie PHP , HTTPD brałem - nie dało się ( możę w FC4 jest jakiś bug :blink:)
zainstalowałem PHP normalnie - tzn nie jako moduł tylko kompilowałem statycznie :) i działa :)
mam to co chciałem
Apache + SSL + PHP + MYSQL + CGI
ale to nie wszystko :) teraz żeby wbić sie na serwer musze wpisać sowje ip
http://my_ip
https://my_ip
czy można tak ustawić zebym nie musał wpisywać ip tylko jakiś adres np : www.tedew.wz dla http i www.tedew2.wz dla https ???
do czego jest moduł rewrite ? - bo trochę go nie za bardzo rozumiem
i najważniejsze - jak zabezpieczyć server APACHE - nie chodzi mi o info krok po kroku tylko wskazówki - reszte poszukam :)
pozd.
To na pewno nie będzie profesjonalny serwer :P Jakbyś to robił na poważnie, to robiłbyś pakiety RPM albo przerabiałabyś już gotowe.
Nie wiem po co chcesz instalować ręcznie. Nic na tym w ogóle nie zyskasz. Jak chcesz się nauczyć kompilowania programów to zacznij od czegoś prostszego.
Mówiłem przecież, że brakuje opcji --with-pic.
SELinux blokuje dostęp do takich bibliotek, gdyż stanowią zagrożenie dla systemu:
http://www.redhat.com/archives/fedora-seli...e/msg00255.html
Jak skompilujesz z opcją --with-pic to powinno ruszyć bez problemów (najwyżej trzeba nadać poprawny kontekst modułowi).
Programy kompilowane statycznie zużywają więcej RAMu.
Dodać odpowiedni wpisy do serwera nazw ;-)
Przepisuje URLe na inną postać. Przydatne, gdy przenosisz jakieś pliki pod inny adres lub chcesz osiągnąć taki efekt jak tutaj → http://pmwiki.org/wiki/Cookbook/CleanUrls
http://httpd.apache.org/docs/2.0/misc/secu...urity_tips.html
http://fedora.redhat.com/docs/selinux-apache-fc3/
Nie wiem czy SELinux będzie Ci chronił ręcznie kompilowane mysql, php i apache :/
hey:)
@gajownik
skompilowałem php z opcją --with-pic ,
./configure --prefix=/usr/local/php4_1 --with-config-file-path=/usr/local/php4_1 --sysconfdir=/usr/local/php4_1 --with-apxs2=/usr/local/apache2/bin/apxs --with-mysql=/usr/local/mysql --with-openssl=/usr/local/ssl --enable-discard-path --enable-debug --enable-track-vars --enable-versioning --with-openssl=/usr/local/ssl --with-xml --enable-bcmath --with-bz2 --enable-calendar --with-ttf=/usr/lib --with-curl --with-db --with-dbase --with-pear --enable-exif --enable-ftp --with-gettext --with-iconv  --enable-mbstring   --with-zlib --with-gd --with-gd-native-ttf   --with-kerberos --with-ncurses --with-pic
ale dalej jest to samo .
Syntax error on line 232 of /usr/local/apache2/conf/httpd.conf:
Pisałeś coś o nadaniu poprawnego kontekstu modułowi - nie za bardzo wiem o co chodzi :blink:
pozdr
Hmmm, to może w php4 jakos inaczej się nazywa :/ Odpal ./configure --help i zobacz co tam jest dostępnego.
Wywal opcję --enable-debug. Przeciez pisałem, że nie jest ona Ci potrzena. Jak chcesz zobaczyć jakich używać opcji, to zerknij do speca z Fedory → http://cvs.fedora.redhat.com/viewcvs/*chec...p/FC-4/php.spec
U mnie ma taki:
[rpm-build@X i386]$ ls -Z /usr/lib/httpd/modules/libphp5.so
-rwxr-xr-x  root     root     system_u:object_r:texrel_shlib_t /usr/lib/httpd/modules/libphp5.so
[rpm-build@X i386]$
Chyba będziesz musiał u siebie zrobić coś takiego:
chcon -t texrel_shlib_t /ściezka/do/modułu/php
