Komenda: Uncompress
graczu
Setting up Install Process
Setting up repositories
updates-released          100% |=========================|  951 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
base                      100% |=========================| 1.1 kB    00:00
No Match for argument: uncompress
Nothing to do
Nic z tego :(
[y4kk0@X all]$ yum info ncompress
Available Packages
Arch   : i386
Version: 4.2.4
Release: 42
Repo   : base
Summary: Fast compression and decompression utilities.
Description:
The ncompress package contains the compress and uncompress file
compression and decompression utilities, which are compatible with the
original UNIX compress utility (.Z file extensions).  These utilities
can't handle gzipped (.gz file extensions) files, but gzip can handle
compressed files.
Install ncompress if you need compression/decompression utilities
which are compatible with the original UNIX compress utility.
[y4kk0@X all]$
(wcześniej trzeba było wpisać yum provides uncompress)
