Patt Napisano Sierpień 27, 2005 Zgłoszenie Share Napisano Sierpień 27, 2005 Mam problem z kompilacja (a wlasciwie juz z konfiguracja) kadu, oto co wyswietla: [patt@localhost kadu]$ ./configure *************************************** * Configuring Kadu, please wait . . . * *************************************** checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking target system type... i686-pc-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for g++... g++ checking for C++ compiler default output file name... a.out checking whether the C++ compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking for style of include used by make... GNU checking dependency style of g++... gcc3 checking for gcc... gcc checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking dependency style of gcc... gcc3 checking for a BSD-compatible install... /usr/bin/install -c checking for gawk... (cached) gawk checking how to run the C preprocessor... gcc -E checking for egrep... grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking execinfo.h usability... yes checking execinfo.h presence... yes checking for execinfo.h... yes checking if execinfo is in libc... yes checking for pthread_create in -lpthread... yes checking if libpng is in system directories... yes checking if qwidget.h header is in system directories... no checking for qwidget.h in specified directiories... found in /usr/lib/qt-3.3/include checking if libqt-mt is in system directories... no checking if libqt-mt is in specified directories: /usr/lib/qt-3.3/lib /usr/lib/qt3/lib /usr/lib/qt/lib /usr/local/qt/lib /usr/local/lib /usr/lib /usr/lib/qt /usr/share/qt3/lib /usr/X11R6/lib /sw/lib /usr/lib/qt3 /usr/X11R6/lib/qt /usr/X11R6/lib/qt3 /usr/lib/qt3/lib64... found in /usr/lib/qt-3.3/lib checking for moc in specified directiories... found in /usr/lib/qt-3.3/bin checking for ANSI C header files... (cached) yes checking fcntl.h usability... yes checking fcntl.h presence... yes checking for fcntl.h... yes checking limits.h usability... yes checking limits.h presence... yes checking for limits.h... yes checking netinet/in.h usability... yes checking netinet/in.h presence... yes checking for netinet/in.h... yes checking for stdlib.h... (cached) yes checking for string.h... (cached) yes checking sys/ioctl.h usability... yes checking sys/ioctl.h presence... yes checking for sys/ioctl.h... yes checking sys/socket.h usability... yes checking sys/socket.h presence... yes checking for sys/socket.h... yes checking for unistd.h... (cached) yes checking for stdbool.h that conforms to C99... yes checking for _Bool... yes checking for an ANSI C-conforming const... yes checking for error_at_line... yes checking whether gcc needs -traditional... no checking for stdlib.h... (cached) yes checking for GNU libc compatible malloc... yes checking whether lstat dereferences a symlink specified with a trailing slash... yes checking whether stat accepts an empty string... no checking for vprintf... yes checking for _doprnt... no checking for memset... yes checking for mkdir... yes checking for sqrt... no checking for strdup... yes checking for stdint types... stdint.h (shortcircuit) make use of stdint.h in kadu-stdint.h (assuming C99 compatible system) ****************************************** * Configuring modules, please wait . . . * ****************************************** >>> Configuring docking module... MODULE_LIBS: MODULE_LIBS_PATH: MODULE_INCLUDES: MODULE_INCLUDES_PATH: MODULE_TOOLS: MODULE_CONFIGURE_CMD: >>> Configuring notify module... MODULE_LIBS: MODULE_LIBS_PATH: MODULE_INCLUDES: MODULE_INCLUDES_PATH: MODULE_TOOLS: MODULE_CONFIGURE_CMD: >>> Configuring sound module... MODULE_LIBS: sndfile MODULE_LIBS_PATH: /usr/local/lib /usr/lib MODULE_INCLUDES: sndfile.h MODULE_INCLUDES_PATH: /usr/local/include /usr/include MODULE_TOOLS: MODULE_CONFIGURE_CMD: echo -e "#include <sndfile.h>\nint main(){\n#ifdef SNDFILE_1\nprintf(\"1\\\n\");\n#else\nprintf(\"0\\\n\");\n#endif\nreturn 0;}\n" > sndfiletest.c $CC $MODULE_CXXFLAGS sndfiletest.c -o sndfiletest ret=`./sndfiletest` rm -f sndfiletest sndfiletest.c if [ "$ret" != "1" ]; then echo "your libsndfile headers are too OLD, get libsndfile >= 1.0" exit 1 fi checking if libsndfile is in system directories... no checking if libsndfile is in specified directories: /usr/local/lib /usr/lib... not found configure: error: libsndfile not found! Poczatkowo myslalem, ze brakuje mi libsndfile, ale ja posiadam, w najnowszej wersji: [patt@localhost kadu]$ rpm -q libsndfile libsndfile-1.0.11-3.fc4 pozniej, iz nie posiadam najnowszej wersji qt, ale okazalo sie, ze jednak ja mam: [patt@localhost kadu]$ rpm -q qt qt-3.3.4-15.1 ...a wiec co jest nie tak ? Pozdrawiam... Patt P.S Mam w systemie juz mam zainstalowane dzialajace kadu (z rpm`u), lecz musze to zrobic ze zrodla, gdyz chce miec Kadu Pro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Sierpień 27, 2005 Zgłoszenie Share Napisano Sierpień 27, 2005 musze to zrobic ze zrodla, gdyz chce miec Kadu Pro A was ist das to kadu pro? ____________________ Doinstaluj paczki z devel w nazwie → libsndfile-devel. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Patt Napisano Sierpień 27, 2005 Autor Zgłoszenie Share Napisano Sierpień 27, 2005 ok... dzieki wszystko dziala... musialem jeszcze sie wspomoc lektura: http://sources.redhat.com/automake/automake.html ...ale dziwne, narazie nie moge znalezc ustawien dotyczacych profili w kadu... Pozdrawiam... Patt Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Zuk87 Napisano Sierpień 27, 2005 Zgłoszenie Share Napisano Sierpień 27, 2005 Nie rozumiem po co kompilowałeś ze źródeł kadu pro skoro jest w rpm'ie i repo kadu... kadu-tcl_scripting (Moduł do Kadu, który pozwala uruchamiać skrypty TCL. Paczka zawiera również skrypt KaduPro.) @lszk: takie różne bajerki do kadu, kiedys to miałem ale zrezygnowałem z tego. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Sierpień 27, 2005 Zgłoszenie Share Napisano Sierpień 27, 2005 Nie rozumiem po co kompilowałeś ze źródeł kadu pro skoro jest w rpm'ie i repo kadu... moze dlatego ze jeszcze nie ma w rpmach najnowszej wersji Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość Zuk87 Napisano Sierpień 27, 2005 Zgłoszenie Share Napisano Sierpień 27, 2005 moze dlatego ze jeszcze nie ma w rpmach najnowszej wersji Przyznam,że po kilku piwach nie brałem tego pod uwage Zwracam honor Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
