grzgar Napisano Czerwiec 2, 2004 Zgłoszenie Share Napisano Czerwiec 2, 2004 ściagnąłem wersję .bz2 i .gz xmule'a, tak więc muszę rozpakować (tak też zrobiłem) później "./configure", "make" i na końcu "make install" ale gdy tylko chcę skonfigurować go, wówczas pokazuje mi się coś takiego: checking for g++... no checking for c++... no checking for gpp... no checking for aCC... no checking for CC... no checking for cxx... no checking for cc++... no checking for cl... no checking for FCC... no checking for KCC... no checking for RCC... no checking for xlC_r... no checking for xlC... no checking for C++ compiler default output file name... configure: error: C++ compiler cannot create executables See `config.log' for more details. gdy otworzę do podglądu pliczek config.log mam coś takiego: ## --------- ## ## Platform. ## ## --------- ## hostname = Grzesiek uname -m = i686 uname -r = 2.4.22-1.2115.nptl uname -s = Linux uname -v = #1 Wed Oct 29 15:31:21 EST 2003 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = i686 /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /usr/local/bin PATH: /usr/bin PATH: /bin PATH: /usr/X11R6/bin PATH: /usr/java/bin PATH: /home/grzesiek/bin PATH: /usr/java/bin PATH: /usr/java/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:1425: checking for g++ configure:1454: result: no configure:1425: checking for c++ configure:1454: result: no configure:1425: checking for gpp configure:1454: result: no configure:1425: checking for aCC configure:1454: result: no configure:1425: checking for CC configure:1454: result: no configure:1425: checking for cxx configure:1454: result: no configure:1425: checking for cc++ configure:1454: result: no configure:1425: checking for cl configure:1454: result: no configure:1425: checking for FCC configure:1454: result: no configure:1425: checking for KCC configure:1454: result: no configure:1425: checking for RCC configure:1454: result: no configure:1425: checking for xlC_r configure:1454: result: no configure:1425: checking for xlC configure:1454: result: no configure:1467: checking for C++ compiler version configure:1470: g++ --version </dev/null >&5 ./configure: line 1: g++: command not found configure:1473: $? = 127 configure:1475: g++ -v </dev/null >&5 ./configure: line 1: g++: command not found configure:1478: $? = 127 configure:1480: g++ -V </dev/null >&5 ./configure: line 1: g++: command not found configure:1483: $? = 127 configure:1506: checking for C++ compiler default output file name configure:1509: g++ conftest.cc >&5 ./configure: line 1: g++: command not found configure:1512: $? = 127 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "xMule" | #define PACKAGE_TARNAME "xmule" | #define PACKAGE_VERSION "1.8.2" | #define PACKAGE_STRING "xMule 1.8.2" | #define PACKAGE_BUGREPORT "[email protected]" | #define PACKAGE "xmule" | #define VERSION "1.8.2" | /* end confdefs.h. */ | | int | main () | { | | ; | return 0; | } configure:1551: error: C++ compiler cannot create executables See `config.log' for more details. ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_CXXFLAGS_set= ac_cv_env_CXXFLAGS_value= ac_cv_env_CXX_set= ac_cv_env_CXX_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set= ac_cv_env_host_alias_value= ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ## ----------------- ## ## Output variables. ## ## ----------------- ## ALLOCA='' BUILD_INCLUDED_LIBINTL='' CATOBJEXT='' CC='' CFLAGS=' ' CPP='' CPPFLAGS='' CXX='g++' CXXFLAGS=' ' DATADIRNAME='' DEBUG_FLAGS='' DEFS='' DISABLE_PROGRESS='' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='' EXEEXT='' GENCAT='' GLIBC21='' GMSGFMT='' GTK_CFLAGS='' GTK_CONFIG='' GTK_DEFS='' GTK_LIBS='' GTK_USEDVERSION='' INSTALL_DATA='' INSTALL_PROGRAM='' INSTALL_SCRIPT='' INSTOBJEXT='' INTLBISON='' INTLLIBS='' INTLOBJS='' INTL_LIBTOOL_SUFFIX_PREFIX='' LDFLAGS='' LIBICONV='' LIBINTL='' LIBOBJS='' LIBS='' LTLIBICONV='' LTLIBINTL='' LTLIBOBJS='' MAKE_PRECOMP='' MKINSTALLDIRS='' MSGFMT='' MSGMERGE='' OBJEXT='' PACKAGE='xmule' PACKAGE_BUGREPORT='[email protected]' PACKAGE_NAME='xMule' PACKAGE_STRING='xMule 1.8.2' PACKAGE_TARNAME='xmule' PACKAGE_VERSION='1.8.2' PATH_SEPARATOR=':' PCHFLAGS='' PKG_CONFIG='' POSUB='' RANLIB='' SET_MAKE='' SHELL='/bin/sh' STRIPGTK='' USE_INCLUDED_LIBINTL='' USE_NLS='' VERSION='1.8.2' WX_CFLAGS='' WX_CFLAGS_ONLY='' WX_CONFIG_PATH='' WX_CPPFLAGS='' WX_CXXFLAGS='' WX_CXXFLAGS_ONLY='' WX_LIBS='' WX_LIBS_STATIC='' WX_VERSION='' XGETTEXT='' ZLIB_CFLAGS='' ZLIB_LIBS='' ac_ct_CC='' ac_ct_CXX='g++' ac_ct_RANLIB='' bindir='${exec_prefix}/bin' build='' build_alias='' build_cpu='' build_os='' build_vendor='' datadir='${prefix}/share' exec_prefix='NONE' host='' host_alias='' host_cpu='' host_os='' host_vendor='' includedir='${prefix}/include' infodir='${prefix}/info' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localstatedir='${prefix}/var' mandir='${prefix}/man' oldincludedir='/usr/include' prefix='NONE' program_transform_name='s,x,x,' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target_alias='' ## ----------- ## ## confdefs.h. ## ## ----------- ## #define PACKAGE "xmule" #define PACKAGE_BUGREPORT "[email protected]" #define PACKAGE_NAME "xMule" #define PACKAGE_STRING "xMule 1.8.2" #define PACKAGE_TARNAME "xmule" #define PACKAGE_VERSION "1.8.2" #define VERSION "1.8.2" configure: exit 77 może mi ktoś powiedzieć o co chodzi ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
blackhat Napisano Czerwiec 2, 2004 Zgłoszenie Share Napisano Czerwiec 2, 2004 Chodzi o to ze nie wykrywa ci tych kompilatorów itp. musisz dodac do jakiegos pliku w systemie niepamietam gdzie chyba gdzies w /etc linijki gdzie ma jescze to szukac. I wtedy powinno byc dobrze. Opisane jest to w Ks-Ekspert w tym nowym numerze Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
grzgar Napisano Czerwiec 2, 2004 Autor Zgłoszenie Share Napisano Czerwiec 2, 2004 Chodzi o to ze nie wykrywa ci tych kompilatorów itp. musisz dodac do jakiegos pliku w systemie niepamietam gdzie chyba gdzies w /etc linijki gdzie ma jescze to szukac. I wtedy powinno byc dobrze. Opisane jest to w Ks-Ekspert w tym nowym numerze Jajcarz z Ciebie ale nie kupuję Ks-Ekspertów.. To jak sobie przypomniesz i napiszesz gdzie to było, to bedzie git Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
blackhat Napisano Czerwiec 2, 2004 Zgłoszenie Share Napisano Czerwiec 2, 2004 Już sie pofatygowalem wstałem od krzesła i poszlem po eksperta Musisz byc na rootcie otwórz plik /etc/ld.so.conf (jakims edytorem txtu) i wpisuj tam linijki gdzie są te biblioteki spróbuj wpisac tak /usr/X11R6/lib /usr/lib/qt3/lib /usr/local /usr/local/lib Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
grzgar Napisano Czerwiec 2, 2004 Autor Zgłoszenie Share Napisano Czerwiec 2, 2004 Już sie pofatygowalem wstałem od krzesła i poszlem po eksperta wow, poszedłeś specjalnie dla mnie po eksperta <lol> przynajmniej masz na kogo zwalić, jakby ktoś pytał na co poszły pieniądze ale niestety dalej to nie działa... ale nie zawracja sobie pewnej części ciała i daj spokój, zainstalowałem sobie już aMule'a, ale wielkie dzięki mistrzu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Czerwiec 2, 2004 Zgłoszenie Share Napisano Czerwiec 2, 2004 /usr/local /usr/local/lib Samo dopisanie nie załatwi sprawy. Trzeba potem odpalić program ldconfig. Dodawanie /usr/local i /usr/local/lib w Fedorze/RedHatach nie ma sensu, bo nie ma tam żadnych programów (no chyba, że ktoś ma jakieś skopilowane własnoręcznie). Ta porada raczej tutaj nic nie pomoże, bo użytkownik grzgar zapewne po prostu nie zainstalował kompilatora :-) ale niestety dalej to nie działa... Nie masz zainstalowanych kompilatorów. Skrypt configure Ci to wyraźnie napisał. Gdybyś chciał kiedyś coś jeszcze kompilować, będziesz musiał doinstalować gcc i ewentualnie g++ yum install gcc gcc-g++ Prawdopodobnie ściągnie się jeszcze coś ze względu na niespełnione zależności. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
