lukas_gab Napisano Wrzesień 11, 2005 Zgłoszenie Share Napisano Wrzesień 11, 2005 chciałem zainstalować ten plik i wpisuje ./configure i wyskakuje takie coś [lukas@localhost sclient-0.7.2]$ ./configure loading cache ./config.cache checking for a BSD compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking whether make sets ${MAKE}... yes checking for working aclocal... found checking for working autoconf... found checking for working automake... found checking for working autoheader... found checking for working makeinfo... found checking for egcs... no checking for pgcc... no checking for gcc... gcc checking whether the C compiler (gcc ) works... yes checking whether the C compiler (gcc ) is a cross-compiler... no checking whether we are using GNU C... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking whether ln -s works... yes checking for a BSD compatible install... /usr/bin/install -c checking host system type... i686-pc-linux-gnu checking whether build environment is sane... yes checking whether to enable maintainer-specific portions of Makefiles... no checking for gtk-config... no checking for GTK - version >= 1.2.0... no *** The gtk-config script installed by GTK could not be found *** If GTK was installed in PREFIX, make sure PREFIX/bin is in *** your path, or set the GTK_CONFIG environment variable to the *** full path to gtk-config. configure: error: Cannot find GTK: Is gtk-config in path? [lukas@localhost sclient-0.7.2]$ i nie mam pojęcia co dalej zrobić ?? mam fedora core 3 i nic wiecej nie wiem ... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
spyro Napisano Wrzesień 11, 2005 Zgłoszenie Share Napisano Wrzesień 11, 2005 a masz zainstalowaną paczke gtk+-devel ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
