Qmail
qlman
Witam
Nie spotkalem tego tematu nigdzie na forum tutaj, w necie znalazlem rozwiazanie problemu, ktore u mnie nie dziala niestety.
Problem:
Chce zainstalowac qmaila potem jak sie uda doinstalowac mu Clam antywiurs oraz SpamAssasin ustawic.
Wspieralem sie opisami z strony qmaila oraz:
Life with Qmail
Problem pojawia sie po wydaniu komnedy ./config
[root@foxsev netqmail-1.05]# ./config
Your hostname is foxsev.localdomain.
hard error
Sorry, I couldn't find your host's canonical name in DNS.
You will have to set up control/me yourself.
Po wydaniu:
[root@foxsev netqmail-1.05]# ./config-fast foxsev.localdomain
Your fully qualified host name is foxsev.localdomain.
Putting foxsev.localdomain into control/me...
Putting foxsev.localdomain into control/defaultdomain...
Putting foxsev.localdomain into control/plusdomain...
Putting foxsev.localdomain into control/locals...
Putting foxsev.localdomain into control/rcpthosts...
Now qmail will refuse to accept SMTP messages except to foxsev.localdomain.
Make sure to change rcpthosts if you add hosts to locals or virtualdomains!
Niestety ponowne ./config znow zwraca w/w blad.
Dodanie recznie wpisu o domenie i hoscie: foxsev.localdomain do pliku w control/me nic nie zmienia.
Nie mam zainstalowanego servera DNS czy to moze byc problem ??
