Make Eterm
patchu
mam problem z zainstalowanie eterm z zrodel
./configure wywala na samym koncu
  Source code location:       .
 Host System Type:           i686-pc-linux-gnu
 Preprocessor:               gcc -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include
 Compiler:               gcc -g -O2
 Linker:                     gcc -L/usr/lib -L/usr/X11R6/lib -L/usr/lib -L/usr/X11R6/lib  -lImlib2 -lttf -ldl -L/usr/lib -lImlib2 -lfreetype -lz -L/usr/X11R6/lib -lX11 -lXext -ldl -lm  -lSM -lICE    -lSM -lICE -lXmu -lutempter -last -lXext -lX11 -lutil -lm
 Install path:        /usr
 See src/feature.h for further configuration information.
 Now type 'make' to build Eterm 0.9.3.
wiec chyba dobrze
pozniej po wpisaniu "make" otrzymuje komunikat
make  all-recursive
make[1]: Entering directory `/root/Download/Eterm-0.9.3'
Making all in src
make[2]: Entering directory `/root/Download/Eterm-0.9.3/src'
/bin/sh ../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I..   -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include   -g -O2 -c actions.c
mkdir .libs
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include -g -O2 -c actions.c  -fPIC -DPIC -o .libs/actions.lo
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include -g -O2 -c actions.c -o actions.o >/dev/null 2>&1
mv -f .libs/actions.lo actions.lo
/bin/sh ../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I..   -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include   -g -O2 -c buttons.c
rm -f .libs/buttons.lo
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include -g -O2 -c buttons.c  -fPIC -DPIC -o .libs/buttons.lo
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include -g -O2 -c buttons.c -o buttons.o >/dev/null 2>&1
mv -f .libs/buttons.lo buttons.lo
/bin/sh ../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I..   -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include   -g -O2 -c command.c
rm -f .libs/command.lo
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/X11R6/include -I/usr/include -I/usr/X11R6/include -g -O2 -c command.c  -fPIC -DPIC -o .libs/command.lo
command.c: In function 'inp_text':
command.c:2560: warning: pointer targets in passing argument 1 of 'tt_write' differ in signedness
command.c: In function 'init_command':
command.c:3005: error: invalid lvalue in assignment
command.c:3007: error: invalid lvalue in assignment
command.c: In function 'main_loop':
command.c:3472: warning: pointer targets in passing argument 1 of 'safe_print_string' differ in signedness
make[2]: *** [command.lo] Błąd 1
make[2]: Leaving directory `/root/Download/Eterm-0.9.3/src'
make[1]: *** [all-recursive] Błąd 1
make[1]: Leaving directory `/root/Download/Eterm-0.9.3'
make: *** [all-recursive-am] Błąd 2
o co biega ??
RPM nie wchodza w gre bo znalalem tylko do fc3 ktory jednak nie chce sie odpalic po zainstalowaniu - widocznie niekompatybilny
Eeeee.... O ile dobrze pamietam:
yum install eterm ... oO
Jeśli jesteś takim zapalonym maniakiem ./configure make itp - polecam Gentoo :>
Eterm jest bodajze w repozytoriach yuma.... tak samo Aterm itp.
no dziwnym trafem u mnie jednak nie ma go na yumie
a posiadam rowniez dodatkowe repo
Program jest źle napisany. Niecała minuta googlowania (!) i jest wynik:
http://www.mail-archive.com/enlightenment-...t/msg06747.html
http://www.gentoo.org/cgi-bin/viewcvs.cgi/...4.patch?rev=1.1 (patch)
Ludzie w Gentoo nie są w ciemię bici i nie bawią się w ogóle w bzdury typu `./configure && make && make install'. Taki sposób instalacji śmieci tylko w systemie. Tam jest system pakietów (Portage).
Próbowałeś tego → http://sps.nus.edu.sg/~didierbe/ ? Nawet wiedzę paczki dla FC4 → http://dr17.saaf.co.uk/fedora/4/en/i386/RPMS.e17/
