Xmmsctrl Instalacja
durny
Wiatm mam nastepujący problem chciałbym zainstalować xmmsctrl ale niemogę znaleźć paczek dla FC4 tylko mdk i suse wink.gif Więc ściągnąłem źródła i po make wywala mi masę błędów.
Z góry dziekuję za wszelka pomoc.
[root@localhost xmmsctrl-1.9]# make
make: xmms-config: Polecenie nie znalezione
gcc -o xmmsctrl xmmsctrl.c removefile.c -Wall -Wshadow -Wmissing-prototypes -W -O2  -DPRETTY_PRINT -D_GNU_SOURCE -DVERSION=\"1.9\"
xmmsctrl.c:35:57: error: xmms/xmmsctrl.h: Nie ma takiego pliku ani katalogu
xmmsctrl.c:46: error: syntax error before ‘is_stream_playing’
xmmsctrl.c:46: warning: type defaults to ‘int’ in declaration of ‘is_stream_playing’
xmmsctrl.c:46: warning: parameter names (without types) in function declaration
xmmsctrl.c:46: warning: data definition has no type or storage class
xmmsctrl.c:49: warning: parameter names (without types) in function declaration
xmmsctrl.c:50: warning: parameter names (without types) in function declaration
xmmsctrl.c:51: warning: parameter names (without types) in function declaration
xmmsctrl.c:52: warning: parameter names (without types) in function declaration
xmmsctrl.c:53: error: syntax error before ‘session’
xmmsctrl.c:54: warning: parameter names (without types) in function declaration
xmmsctrl.c:55: warning: parameter names (without types) in function declaration
xmmsctrl.c:56: warning: parameter names (without types) in function declaration
xmmsctrl.c:57: warning: parameter names (without types) in function declaration
xmmsctrl.c:58: warning: parameter names (without types) in function declaration
xmmsctrl.c:59: warning: parameter names (without types) in function declaration
xmmsctrl.c:60: warning: parameter names (without types) in function declaration
xmmsctrl.c:61: warning: parameter names (without types) in function declaration
xmmsctrl.c:64: error: syntax error before ‘char’
xmmsctrl.c:65: error: syntax error before ‘char’
xmmsctrl.c:66: error: syntax error before ‘char’
xmmsctrl.c:67: error: syntax error before ‘char’
xmmsctrl.c:68: error: syntax error before ‘char’
xmmsctrl.c:69: error: syntax error before ‘char’
xmmsctrl.c:70: error: syntax error before ‘char’
xmmsctrl.c:71: error: syntax error before ‘char’
xmmsctrl.c:72: error: syntax error before ‘char’
xmmsctrl.c:90: warning: parameter names (without types) in function declaration
xmmsctrl.c:109: error: ‘xmms_remote_eject’ undeclared here (not in a function)
xmmsctrl.c:139: error: ‘xmms_remote_playlist_next’ undeclared here (not in a function)
xmmsctrl.c:144: error: ‘xmms_remote_pause’ undeclared here (not in a function)
xmmsctrl.c:149: error: ‘xmms_remote_play’ undeclared here (not in a function)
xmmsctrl.c:164: error: ‘xmms_remote_show_prefs_box’ undeclared here (not in a function)
xmmsctrl.c:169: error: ‘xmms_remote_playlist_prev’ undeclared here (not in a function)
xmmsctrl.c:184: error: ‘xmms_remote_toggle_repeat’ undeclared here (not in a function)
xmmsctrl.c:189: error: ‘xmms_remote_toggle_shuffle’ undeclared here (not in a function)
xmmsctrl.c:194: error: ‘xmms_remote_stop’ undeclared here (not in a function)
xmmsctrl.c:209: error: ‘xmms_remote_quit’ undeclared here (not in a function)
xmmsctrl.c:223: error: syntax error before ‘gboolean’
xmmsctrl.c:223: warning: no semicolon at end of struct or union
xmmsctrl.c:225: error: syntax error before ‘}’ token
xmmsctrl.c:225: warning: type defaults to ‘int’ in declaration of ‘Test’
xmmsctrl.c:225: warning: data definition has no type or storage class
xmmsctrl.c:229: error: syntax error before ‘test’
xmmsctrl.c:229: warning: type defaults to ‘int’ in declaration of ‘test’
xmmsctrl.c:230: warning: braces around scalar initializer
xmmsctrl.c:230: warning: (near initialization for ‘test[0]’)
xmmsctrl.c:231: warning: initialization makes integer from pointer without a cast
xmmsctrl.c:232: error: ‘xmms_remote_is_paused’ undeclared here (not in a function)
xmmsctrl.c:232: warning: excess elements in scalar initializer
xmmsctrl.c:232: warning: (near initialization for ‘test[0]’)
xmmsctrl.c:234: warning: excess elements in scalar initializer
xmmsctrl.c:234: warning: (near initialization for ‘test[0]’)
xmmsctrl.c:235: warning: braces around scalar initializer
xmmsctrl.c:235: warning: (near initialization for ‘test[1]’)
xmmsctrl.c:236: warning: initialization makes integer from pointer without a cast
xmmsctrl.c:237: error: ‘xmms_remote_is_playing’ undeclared here (not in a function)
xmmsctrl.c:237: warning: excess elements in scalar initializer
xmmsctrl.c:237: warning: (near initialization for ‘test[1]’)
xmmsctrl.c:239: warning: excess elements in scalar initializer
xmmsctrl.c:239: warning: (near initialization for ‘test[1]’)
xmmsctrl.c:240: warning: braces around scalar initializer
xmmsctrl.c:240: warning: (near initialization for ‘test[2]’)
xmmsctrl.c:241: warning: initialization makes integer from pointer without a cast
xmmsctrl.c:242: error: ‘xmms_remote_is_eq_win’ undeclared here (not in a function)
xmmsctrl.c:242: warning: excess elements in scalar initializer
xmmsctrl.c:242: warning: (near initialization for ‘test[2]’)
xmmsctrl.c:244: warning: excess elements in scalar initializer
xmmsctrl.c:244: warning: (near initialization for ‘test[2]’)
xmmsctrl.c:245: warning: braces around scalar initializer
xmmsctrl.c:245: warning: (near initialization for ‘test[3]’)
xmmsctrl.c:246: warning: initialization makes integer from pointer without a cast
xmmsctrl.c:247: error: ‘xmms_remote_is_main_win’ undeclared here (not in a function)
xmmsctrl.c:247: warning: excess elements in scalar initializer
xmmsctrl.c:247: warning: (near initialization for ‘test[3]’)
xmmsctrl.c:249: warning: excess elements in scalar initializer
xmmsctrl.c:249: warning: (near initialization for ‘test[3]’)
xmmsctrl.c:250: warning: braces around scalar initializer
xmmsctrl.c:250: warning: (near initialization for ‘test[4]’)
xmmsctrl.c:251: warning: initialization makes integer from pointer without a cast
xmmsctrl.c:252: error: ‘xmms_remote_is_pl_win’ undeclared here (not in a function)
xmmsctrl.c:252: warning: excess elements in scalar initializer
xmmsctrl.c:252: warning: (near initialization for ‘test[4]’)
xmmsctrl.c:254: warning: excess elements in scalar initializer
xmmsctrl.c:254: warning: (near initialization for ‘test[4]’)
xmmsctrl.c:255: warning: braces around scalar initializer
xmmsctrl.c:255: warning: (near initialization for ‘test[5]’)
xmmsctrl.c:256: warning: initialization makes integer from pointer without a cast
xmmsctrl.c:257: warning: excess elements in scalar initializer
xmmsctrl.c:257: warning: (near initialization for ‘test[5]’)
xmmsctrl.c:259: warning: excess elements in scalar initializer
xmmsctrl.c:259: warning: (near initialization for ‘test[5]’)
xmmsctrl.c:260: warning: braces around scalar initializer
xmmsctrl.c:260: warning: (near initialization for ‘test[6]’)
xmmsctrl.c:261: warning: initialization makes integer from pointer without a cast
xmmsctrl.c:262: error: ‘xmms_remote_is_running’ undeclared here (not in a function)
xmmsctrl.c:262: warning: excess elements in scalar initializer
xmmsctrl.c:262: warning: (near initialization for ‘test[6]’)
xmmsctrl.c:264: warning: excess elements in scalar initializer
xmmsctrl.c:264: warning: (near initialization for ‘test[6]’)
xmmsctrl.c:265: warning: data definition has no type or storage class
xmmsctrl.c:271: warning: parameter names (without types) in function declaration
xmmsctrl.c:280: error: ‘xmms_remote_eq_win_toggle’ undeclared here (not in a function)
xmmsctrl.c:285: error: ‘xmms_remote_main_win_toggle’ undeclared here (not in a function)
xmmsctrl.c:290: error: ‘xmms_remote_pl_win_toggle’ undeclared here (not in a function)
xmmsctrl.c:299: error: syntax error before ‘char’
xmmsctrl.c:399: error: syntax error before ‘session’
xmmsctrl.c:399: warning: ‘print_length’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_length’:
xmmsctrl.c:399: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:399: error: (Each undeclared identifier is reported only once
xmmsctrl.c:399: error: for each function it appears in.)
xmmsctrl.c: At top level:
xmmsctrl.c:400: error: syntax error before ‘session’
xmmsctrl.c:400: warning: ‘print_current’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_current’:
xmmsctrl.c:400: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:401: error: syntax error before ‘session’
xmmsctrl.c:401: warning: ‘print_volume’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_volume’:
xmmsctrl.c:401: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:402: error: syntax error before ‘session’
xmmsctrl.c:402: warning: ‘print_time’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_time’:
xmmsctrl.c:402: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:403: error: syntax error before ‘session’
xmmsctrl.c:403: warning: ‘print_current_title’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_current_title’:
xmmsctrl.c:403: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:404: error: syntax error before ‘session’
xmmsctrl.c:404: warning: ‘print_playlist’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_playlist’:
xmmsctrl.c:404: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:405: error: syntax error before ‘session’
xmmsctrl.c:405: warning: ‘print_playfiles’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_playfiles’:
xmmsctrl.c:405: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:406: error: syntax error before ‘session’
xmmsctrl.c:406: warning: ‘print_current_pos’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_current_pos’:
xmmsctrl.c:406: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:412: error: syntax error before ‘is_stream_playing’
xmmsctrl.c:412: error: syntax error before ‘session’
xmmsctrl.c:412: warning: return type defaults to ‘int’
xmmsctrl.c:412: warning: no previous prototype for ‘is_stream_playing’
xmmsctrl.c: In function ‘is_stream_playing’:
xmmsctrl.c:413: warning: implicit declaration of function ‘xmms_remote_get_playlist_file’
xmmsctrl.c:413: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:413: warning: implicit declaration of function ‘xmms_remote_get_playlist_pos’
xmmsctrl.c:413: warning: passing argument 1 of ‘strlen’ makes pointer from integer without a cast
xmmsctrl.c:413: warning: passing argument 2 of ‘__builtin_strcmp’ makes pointer from integer without a cast
xmmsctrl.c:413: warning: passing argument 2 of ‘strncmp’ makes pointer from integer without a cast
xmmsctrl.c:425: error: syntax error before ‘session’
xmmsctrl.c:425: warning: ‘play_prev’ was used with no prototype before its definition
xmmsctrl.c: In function ‘play_prev’:
xmmsctrl.c:426: error: syntax error before ‘DEV’
xmmsctrl.c:427: error: ‘gint’ undeclared (first use in this function)
xmmsctrl.c:429: error: ‘DEV’ undeclared (first use in this function)
xmmsctrl.c:429: warning: passing argument 1 of ‘strlen’ from incompatible pointer type
xmmsctrl.c:429: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:429: warning: passing argument 1 of ‘strlen’ makes pointer from integer without a cast
xmmsctrl.c:429: error: invalid operands to binary -
xmmsctrl.c:429: warning: comparison between pointer and integer
xmmsctrl.c:429: warning: passing argument 1 of ‘__builtin_strcmp’ from incompatible pointer type
xmmsctrl.c:429: warning: passing argument 2 of ‘__builtin_strcmp’ makes pointer from integer without a cast
xmmsctrl.c:429: warning: statement with no effect
xmmsctrl.c:429: warning: passing argument 1 of ‘strncmp’ from incompatible pointer type
xmmsctrl.c:429: warning: passing argument 2 of ‘strncmp’ makes pointer from integer without a cast
xmmsctrl.c:434: error: ‘first’ undeclared (first use in this function)
xmmsctrl.c:434: warning: statement with no effect
xmmsctrl.c:437: warning: comparison between pointer and integer
xmmsctrl.c:438: warning: implicit declaration of function ‘xmms_remote_playlist_prev’
xmmsctrl.c:438: warning: declaration of ‘xmms_remote_playlist_prev’ shadows previous non-variable
xmmsctrl.c:440: warning: implicit declaration of function ‘xmms_remote_set_playlist_pos’
xmmsctrl.c:440: warning: implicit declaration of function ‘xmms_remote_get_playlist_length’
xmmsctrl.c:447: error: syntax error before ‘session’
xmmsctrl.c:447: warning: ‘remove_from_playlist’ was used with no prototype before its definition
xmmsctrl.c: In function ‘remove_from_playlist’:
xmmsctrl.c:448: warning: implicit declaration of function ‘xmms_remote_playlist_delete’
xmmsctrl.c:448: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:456: error: syntax error before ‘session’
xmmsctrl.c:456: warning: ‘set_track’ was used with no prototype before its definition
xmmsctrl.c: In function ‘set_track’:
xmmsctrl.c:459: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:459: warning: passing argument 1 of ‘strlen’ from incompatible pointer type
xmmsctrl.c:459: error: invalid operands to binary -
xmmsctrl.c:459: warning: comparison between pointer and integer
xmmsctrl.c:459: warning: passing argument 1 of ‘__builtin_strcmp’ from incompatible pointer type
xmmsctrl.c:459: warning: statement with no effect
xmmsctrl.c:460: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:462: warning: passing argument 1 of ‘atoi’ from incompatible pointer type
xmmsctrl.c:474: error: syntax error before ‘session’
xmmsctrl.c:474: warning: ‘set_vol’ was used with no prototype before its definition
xmmsctrl.c: In function ‘set_vol’:
xmmsctrl.c:475: error: ‘gint’ undeclared (first use in this function)
xmmsctrl.c:475: error: syntax error before ‘vol’
xmmsctrl.c:477: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:477: error: switch quantity not an integer
xmmsctrl.c:483: error: ‘vol’ undeclared (first use in this function)
xmmsctrl.c:483: warning: passing argument 1 of ‘atoi’ from incompatible pointer type
xmmsctrl.c:483: warning: statement with no effect
xmmsctrl.c:487: warning: passing argument 1 of ‘atoi’ from incompatible pointer type
xmmsctrl.c:487: warning: statement with no effect
xmmsctrl.c:491: warning: ordered comparison of pointer with integer zero
xmmsctrl.c:492: warning: statement with no effect
xmmsctrl.c:493: warning: comparison between pointer and integer
xmmsctrl.c:494: warning: statement with no effect
xmmsctrl.c:496: warning: implicit declaration of function ‘xmms_remote_set_main_volume’
xmmsctrl.c:496: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:503: error: syntax error before ‘session’
xmmsctrl.c:503: warning: ‘set_time’ was used with no prototype before its definition
xmmsctrl.c: In function ‘set_time’:
xmmsctrl.c:504: error: ‘gint’ undeclared (first use in this function)
xmmsctrl.c:504: error: syntax error before ‘ptime’
xmmsctrl.c:508: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:508: error: switch quantity not an integer
xmmsctrl.c:514: error: ‘ptime’ undeclared (first use in this function)
xmmsctrl.c:514: warning: passing argument 1 of ‘atoi’ from incompatible pointer type
xmmsctrl.c:514: warning: statement with no effect
xmmsctrl.c:522: error: ‘length’ undeclared (first use in this function)
xmmsctrl.c:522: warning: passing argument 1 of ‘atoi’ from incompatible pointer type
xmmsctrl.c:522: warning: statement with no effect
xmmsctrl.c:526: warning: passing argument 1 of ‘atoi’ from incompatible pointer type
xmmsctrl.c:526: warning: statement with no effect
xmmsctrl.c:530: warning: ordered comparison of pointer with integer zero
xmmsctrl.c:531: warning: statement with no effect
xmmsctrl.c:533: warning: statement with no effect
xmmsctrl.c:535: warning: implicit declaration of function ‘xmms_remote_jump_to_time’
xmmsctrl.c:535: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:542: error: syntax error before ‘session’
xmmsctrl.c:542: warning: ‘add_file’ was used with no prototype before its definition
xmmsctrl.c: In function ‘add_file’:
xmmsctrl.c:543: warning: implicit declaration of function ‘xmms_remote_playlist_add_url_string’
xmmsctrl.c:543: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:543: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:550: error: syntax error before ‘session’
xmmsctrl.c:550: warning: ‘clear_playlist’ was used with no prototype before its definition
xmmsctrl.c: In function ‘clear_playlist’:
xmmsctrl.c:551: warning: implicit declaration of function ‘xmms_remote_playlist_clear’
xmmsctrl.c:551: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:558: error: syntax error before ‘session’
xmmsctrl.c:558: warning: ‘set_dir’ was used with no prototype before its definition
xmmsctrl.c: In function ‘set_dir’:
xmmsctrl.c:559: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:560: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:579: error: syntax error before ‘unused’
xmmsctrl.c:579: warning: ‘def_eq’ was used with no prototype before its definition
xmmsctrl.c: In function ‘def_eq’:
xmmsctrl.c:581: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:581: warning: statement with no effect
xmmsctrl.c:587: error: syntax error before ‘unused’
xmmsctrl.c:587: warning: ‘def_neq’ was used with no prototype before its definition
xmmsctrl.c: In function ‘def_neq’:
xmmsctrl.c:589: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:589: warning: statement with no effect
xmmsctrl.c:596: error: syntax error before ‘session’
xmmsctrl.c: In function ‘exec_print’:
xmmsctrl.c:597: error: ‘gint’ undeclared (first use in this function)
xmmsctrl.c:597: error: syntax error before ‘start’
xmmsctrl.c:600: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:602: error: ‘depth’ undeclared (first use in this function)
xmmsctrl.c:602: warning: comparison between pointer and integer
xmmsctrl.c:610: error: ‘start’ undeclared (first use in this function)
xmmsctrl.c:610: warning: statement with no effect
xmmsctrl.c:611: error: ‘end’ undeclared (first use in this function)
xmmsctrl.c:611: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:611: warning: statement with no effect
xmmsctrl.c:614: error: ‘i’ undeclared (first use in this function)
xmmsctrl.c:614: warning: statement with no effect
xmmsctrl.c:614: error: wrong type argument to increment
xmmsctrl.c:615: warning: statement with no effect
xmmsctrl.c:619: error: syntax error before ‘pos’
xmmsctrl.c:621: error: syntax error before ‘x’
xmmsctrl.c:625: error: ‘pos’ undeclared (first use in this function)
xmmsctrl.c:625: warning: statement with no effect
xmmsctrl.c:629: warning: statement with no effect
xmmsctrl.c:632: error: invalid operands to binary *
xmmsctrl.c:632: warning: statement with no effect
xmmsctrl.c:635: error: wrong type argument to decrement
xmmsctrl.c:635: warning: ordered comparison of pointer with integer zero
xmmsctrl.c:635: warning: statement with no effect
xmmsctrl.c:647: warning: implicit declaration of function ‘xmms_remote_get_playlist_title’
xmmsctrl.c:647: warning: assignment makes pointer from integer without a cast
xmmsctrl.c:654: warning: assignment makes pointer from integer without a cast
xmmsctrl.c:661: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘struct ToggleCommand *’
xmmsctrl.c:664: warning: implicit declaration of function ‘xmms_remote_get_output_time’
xmmsctrl.c:667: warning: implicit declaration of function ‘xmms_remote_get_playlist_time’
xmmsctrl.c:670: error: ‘x’ undeclared (first use in this function)
xmmsctrl.c:670: warning: statement with no effect
xmmsctrl.c:671: error: invalid operands to binary /
xmmsctrl.c:671: error: invalid operands to binary %
xmmsctrl.c:671: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘struct ToggleCommand *’
xmmsctrl.c:671: warning: format ‘%-2.2d’ expects type ‘int’, but argument 3 has type ‘struct ToggleCommand *’
xmmsctrl.c:674: warning: statement with no effect
xmmsctrl.c:675: error: invalid operands to binary /
xmmsctrl.c:675: error: invalid operands to binary %
xmmsctrl.c:675: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘struct ToggleCommand *’
xmmsctrl.c:675: warning: format ‘%-2.2d’ expects type ‘int’, but argument 3 has type ‘struct ToggleCommand *’
xmmsctrl.c:678: warning: implicit declaration of function ‘xmms_remote_get_main_volume’
xmmsctrl.c:684: warning: statement with no effect
xmmsctrl.c:686: error: invalid operands to binary /
xmmsctrl.c:686: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘struct ToggleCommand *’
xmmsctrl.c:691: warning: statement with no effect
xmmsctrl.c:693: error: invalid operands to binary *
xmmsctrl.c:693: warning: statement with no effect
xmmsctrl.c:696: error: wrong type argument to decrement
xmmsctrl.c:696: warning: statement with no effect
xmmsctrl.c:697: error: ‘current’ undeclared (first use in this function)
xmmsctrl.c:698: warning: ordered comparison of pointer with integer zero
xmmsctrl.c:698: warning: comparison between pointer and integer
xmmsctrl.c:698: error: array subscript is not an integer
xmmsctrl.c:698: error: request for member ‘eq’ in something not a structure or union
xmmsctrl.c:700: warning: ordered comparison of pointer with integer zero
xmmsctrl.c:700: warning: comparison between pointer and integer
xmmsctrl.c:700: error: array subscript is not an integer
xmmsctrl.c:700: error: request for member ‘neq’ in something not a structure or union
xmmsctrl.c:719: error: syntax error before ‘session’
xmmsctrl.c:719: warning: ‘print’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print’:
xmmsctrl.c:720: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:720: error: ‘arg’ undeclared (first use in this function)
xmmsctrl.c:728: error: syntax error before ‘dummy’
xmmsctrl.c:728: warning: ‘print_help’ was used with no prototype before its definition
xmmsctrl.c: In function ‘print_help’:
xmmsctrl.c:766: error: request for member ‘name’ in something not a structure or union
xmmsctrl.c:766: error: request for member ‘help’ in something not a structure or union
xmmsctrl.c:766: warning: format ‘%s’ expects type ‘char *’, but argument 2 has type ‘struct ToggleCommand *’
xmmsctrl.c:766: warning: format ‘%s’ expects type ‘char *’, but argument 3 has type ‘struct ToggleCommand *’
xmmsctrl.c:803: error: syntax error before ‘launch_xmms’
xmmsctrl.c:803: warning: return type defaults to ‘int’
xmmsctrl.c:803: warning: no previous prototype for ‘launch_xmms’
xmmsctrl.c: In function ‘launch_xmms’:
xmmsctrl.c:804: error: ‘gint’ undeclared (first use in this function)
xmmsctrl.c:804: error: syntax error before ‘session’
xmmsctrl.c:821: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:821: warning: statement with no effect
xmmsctrl.c:821: warning: comparison between pointer and integer
xmmsctrl.c:821: error: wrong type argument to increment
xmmsctrl.c:822: warning: implicit declaration of function ‘xmms_remote_is_running’
xmmsctrl.c:822: warning: declaration of ‘xmms_remote_is_running’ shadows previous non-variable
xmmsctrl.c:823: warning: return makes integer from pointer without a cast
xmmsctrl.c: In function ‘main’:
xmmsctrl.c:833: error: ‘gint’ undeclared (first use in this function)
xmmsctrl.c:833: error: syntax error before ‘session’
xmmsctrl.c:841: error: ‘session’ undeclared (first use in this function)
xmmsctrl.c:841: warning: statement with no effect
xmmsctrl.c:841: warning: comparison between pointer and integer
xmmsctrl.c:841: error: wrong type argument to increment
xmmsctrl.c:845: warning: comparison between pointer and integer
xmmsctrl.c:850: warning: statement with no effect
xmmsctrl.c:862: warning: statement with no effect
xmmsctrl.c:879: error: request for member ‘name’ in something not a structure or union
xmmsctrl.c:879: warning: passing argument 1 of ‘strlen’ from incompatible pointer type
xmmsctrl.c:879: error: invalid operands to binary -
xmmsctrl.c:879: warning: comparison between pointer and integer
xmmsctrl.c:879: warning: passing argument 2 of ‘__builtin_strcmp’ from incompatible pointer type
xmmsctrl.c:879: warning: statement with no effect
xmmsctrl.c:880: error: request for member ‘test’ in something not a structure or union
xmmsctrl.c:880: error: called object ‘&<erroneous-expression>’ is not a function
removefile.c:35:57: error: xmms/xmmsctrl.h: Nie ma takiego pliku ani katalogu
removefile.c:38: error: syntax error before ‘session’
removefile.c:39: warning: parameter names (without types) in function declaration
removefile.c:47: error: syntax error before ‘gint’
removefile.c:47: warning: no semicolon at end of struct or union
removefile.c:48: warning: type defaults to ‘int’ in declaration of ‘song_t’
removefile.c:48: warning: data definition has no type or storage class
removefile.c:54: warning: type defaults to ‘int’ in declaration of ‘song_t’
removefile.c:54: warning: declaration of ‘song_t’ shadows a global declaration
removefile.c:48: warning: shadowed declaration is here
removefile.c:54: error: syntax error before ‘*’ token
removefile.c: In function ‘add_index’:
removefile.c:59: error: ‘nb_pos’ undeclared (first use in this function)
removefile.c:59: error: (Each undeclared identifier is reported only once
removefile.c:59: error: for each function it appears in.)
removefile.c:59: error: ‘nb_songs’ undeclared (first use in this function)
removefile.c:60: error: ‘pwd’ undeclared (first use in this function)
removefile.c:61: error: ‘filename’ undeclared (first use in this function)
removefile.c:65: error: ‘root_len’ undeclared (first use in this function)
removefile.c:74: error: ‘gint’ undeclared (first use in this function)
removefile.c:74: error: syntax error before ‘nb’
removefile.c:75: error: syntax error before ‘*’ token
removefile.c:77: error: ‘nb’ undeclared (first use in this function)
removefile.c:78: error: syntax error before ‘middle’
removefile.c:79: error: ‘start’ undeclared (first use in this function)
removefile.c:79: error: ‘middle’ undeclared (first use in this function)
removefile.c:89: error: ‘pos’ undeclared (first use in this function)
removefile.c: At top level:
removefile.c:105: warning: type defaults to ‘int’ in declaration of ‘song_t’
removefile.c:105: warning: declaration of ‘song_t’ shadows a global declaration
removefile.c:105: error: syntax error before ‘*’ token
removefile.c: In function ‘remove_dirname’:
removefile.c:108: error: ‘dirname’ undeclared (first use in this function)
removefile.c:131: error: ‘root_len’ undeclared (first use in this function)
removefile.c:131: error: ‘start_songs’ undeclared (first use in this function)
removefile.c:131: error: ‘nb_songs’ undeclared (first use in this function)
removefile.c:131: error: ‘pos’ undeclared (first use in this function)
removefile.c:131: error: ‘nb_pos’ undeclared (first use in this function)
removefile.c: In function ‘song_compare’:
removefile.c:147: error: syntax error before ‘*’ token
removefile.c:148: error: syntax error before ‘*’ token
removefile.c:149: error: ‘s1’ undeclared (first use in this function)
removefile.c:149: error: ‘s2’ undeclared (first use in this function)
removefile.c:146: warning: unused parameter ‘p1’
removefile.c:146: warning: unused parameter ‘p2’
removefile.c: In function ‘index_compare’:
removefile.c:155: error: syntax error before ‘*’ token
removefile.c:156: error: syntax error before ‘*’ token
removefile.c:157: error: ‘i1’ undeclared (first use in this function)
removefile.c:157: error: ‘i2’ undeclared (first use in this function)
removefile.c:154: warning: unused parameter ‘p1’
removefile.c:154: warning: unused parameter ‘p2’
removefile.c:161: error: syntax error before ‘session’
removefile.c:161: warning: no previous prototype for ‘remove_file’
removefile.c: In function ‘remove_file’:
removefile.c:164: error: ‘filename’ undeclared (first use in this function)
removefile.c:167: error: ‘gint’ undeclared (first use in this function)
removefile.c:167: error: syntax error before ‘list_size’
removefile.c:168: error: ‘play_list’ undeclared (first use in this function)
removefile.c:189: error: ‘list_size’ undeclared (first use in this function)
removefile.c:189: warning: implicit declaration of function ‘xmms_remote_get_playlist_length’
removefile.c:189: error: ‘session’ undeclared (first use in this function)
removefile.c:190: error: syntax error before ‘)’ token
removefile.c:193: error: ‘remove_pos’ undeclared (first use in this function)
removefile.c:193: error: syntax error before ‘)’ token
removefile.c:198: error: syntax error before ‘i’
removefile.c:200: error: ‘i’ undeclared (first use in this function)
removefile.c:201: warning: implicit declaration of function ‘xmms_remote_get_playlist_file’
removefile.c:220: warning: implicit declaration of function ‘xmms_remote_playlist_delete’
removefile.c:234: error: syntax error before ‘session’
removefile.c:234: warning: no previous prototype for ‘unique’
removefile.c: In function ‘unique’:
removefile.c:235: error: ‘gint’ undeclared (first use in this function)
removefile.c:235: error: syntax error before ‘list_size’
removefile.c:236: error: ‘play_list’ undeclared (first use in this function)
removefile.c:236: error: syntax error before ‘)’ token
removefile.c:238: error: ‘remove_pos’ undeclared (first use in this function)
removefile.c:238: error: ‘list_size’ undeclared (first use in this function)
removefile.c:241: error: syntax error before ‘i’
removefile.c:242: error: ‘i’ undeclared (first use in this function)
removefile.c:243: error: ‘session’ undeclared (first use in this function)
removefile.c:247: error: ‘current’ undeclared (first use in this function)
removefile.c:247: warning: implicit declaration of function ‘xmms_remote_get_playlist_pos’
removefile.c:250: error: ‘n’ undeclared (first use in this function)
make: *** [xmmsctrl] Błąd 1
]EDIT
