marcYr Napisano Marzec 17, 2004 Zgłoszenie Share Napisano Marzec 17, 2004 Witam!CZy ktoś z Was mógłby pokazać listing swojego sourcelist do apt.Próbowałem cos w nim grzebać(dodać nowe źródła, na podstawie HOWTO), ale ciągle mi się sypie.. :oops: prszę bardzo :mrgreen: rpm http://www.quantumlinux.com rpmpan rpmpan rpm http://sunsite.informatik.rwth-aachen.de ftp/pub/Linux/fedora/fedora/1/i386 os updates stable testing unstable rpm-src http://sunsite.informatik.rwth-aachen.de ftp/pub/Linux/fedora/fedora/1/i386 os updates stable testing unstable rpm http://apt.physik.fu-berlin.de fedora/1/en/i386 at-testing rpm-src http://apt.physik.fu-berlin.de fedora/1/en/i386 at-testing rpm http://ayo.freshrpms.net fedora/linux/1/i386 core updates freshrpms rpm http://people.ecsc.co.uk/~matt/downloads/apt fedora-1-i386 production testing depends rpm-src http://people.ecsc.co.uk/~matt/downloads/apt fedora-1-i386 production testing rpm ftp://apt-rpm.tuxfamily.org/apt fedora/1/i386 os updates testing extra rpm-src ftp://apt-rpm.tuxfamily.org/apt fedora/1/i386 os updates testing extra rpm http://apt.ling.li fedora/1/i586 li unstable rpm http://apt.sw.be redhat/fc1/en/i386 dag rpm http://rpm.livna.org/ fedora/1/i386 stable unstable testing rpm-src http://rpm.livna.org/ fedora/1/i386 stable unstable testing rpm http://newrpms.sunsite.dk/apt/ redhat/en/i386/fc1 newrpms rpm-src http://newrpms.sunsite.dk/apt/ redhat/en/i386/fc1 newrpms rpm http://ftp.icm.edu.pl/pub/linux/mplayer-rpms/apt/ 7.3 testing rpm http://rpms.xcyb.org/fedora/1 athlon stable bleeding rpm-src http://rpms.xcyb.org/fedora/1 athlon stable bleeding rpm http://download.fedora.us/ fedora/fedora/1/i386 stable rpm http://download.fedora.us/ fedora/fedora/1/i386 testing rpm http://download.fedora.us/ fedora/fedora/1/i386 os rpm http://download.fedora.us/ fedora/fedora/1/i386 updates rpm http://apt.wsisiz.edu.pl/ fc1/i386 wsisiz rpm ftp://apt.kde-redhat.org/apt/ fedora/all stable czasem jak Ci jakieś repozytorium "nie odpowiada" (czyli wywala błędy) zachaszuj je na moment pozdro upgrade listy przez autora postu - 2004-03-21 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
barbulek Napisano Marzec 18, 2004 Zgłoszenie Share Napisano Marzec 18, 2004 Dzięki.Jeszcze mała prośba odnośnie apt.conf coś tez tam pogrzebałem i mi się sypie :oops: .... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcYr Napisano Marzec 18, 2004 Zgłoszenie Share Napisano Marzec 18, 2004 Dzięki.Jeszcze mała prośba odnośnie apt.conf coś tez tam pogrzebałem i mi się sypie :oops: .... cat /etc/apt/apt.conf APT { // Give stable archive a higher priority by default Default-Release "stable"; // Options for apt-get Get { Download-Only "false"; Show-Upgraded "true"; }; }; Dir { Etc { Scripts "/usr/lib/apt/scripts/"; }; }; RPM { // Completely ignore GnuPG signature packages (introduced in rpm 4.1) Ignore { "gpg-pubkey"; }; // Allow multiple kernel and kernel-related packages to be installed Allow-Duplicated "^kernel(-(BOOT|bigmem|debug|smp|unsupported|source))?$"; "^gpg-pubkey$"; }; // Enable source rebuilds Source { Build-Command "rpmbuild --rebuild"; }; // These are for Lua-script configuration // Do GPG-signature checking for packages GPG-Check "false"; // Enable to upgrade kernel along with (dist-)upgrade Upgrade-Kernel "false"; // Enable to hold back packages with modified config files in (dist-)upgrade Preserve-Config "false"; }; // Options for the downloading routines Acquire { Retries "1"; http::User-Agent "Fedora APT-HTTP/1.3"; // http::Proxy "http://user:[email protected]:port/"; // http::Proxy "http://proxy-server.domain.tld:port/"; }; Scripts { Init { "gpg-import.lua"; }; RPM { Pre { "gpg-checker.lua"; }; }; Apt { Upgrade { "kernel-upgrade.lua"; "preserve-conf.lua"; }; DistUpgrade {"kernel-upgrade.lua"; "preserve-conf.lua"; }; }; } ale nic w sumie chyba nie zmieniałem ..... (zresztą i tak się linijki się w poście rozwalą ) do upgradu kernela używam yuma. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Marzec 20, 2004 Zgłoszenie Share Napisano Marzec 20, 2004 A mi się z kolei wali yum. Zaczął gdy ściągnąłem przez apt upgrade'y [m. in. nowe yum]. Mam coś takiego: [root@kurak lszk]# yum upgrade Traceback (most recent call last): File "/usr/bin/yum", line 30, in ? yummain.main(sys.argv[1:]) File "/usr/share/yum/yummain.py", line 169, in main lock('/var/run/yum.pid', mypid) File "/usr/share/yum/yummain.py", line 121, in lock while not yumlock.lock(lockfile, mypid, 0644): File "/usr/share/yum/yumlock.py", line 10, in lock if not msg.strerror == "File exists": raise msg OSError: [Errno 17] Plik istnieje: '/var/run/yum.pid' Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcYr Napisano Marzec 21, 2004 Zgłoszenie Share Napisano Marzec 21, 2004 Witam!CZy ktoś z Was mógłby pokazać listing swojego sourcelist do apt.Próbowałem cos w nim grzebać(dodać nowe źródła, na podstawie HOWTO), ale ciągle mi się sypie.. :oops: coś miałem namieszane w poprzednim poście w którym zrzuciłem swoje repozytoria - jak korzystasz to luknij teraz i ewentualnie zrób upgrade - już wszystko gra rpm http://www.quantumlinux.com rpmpan rpmpan rpm http://sunsite.informatik.rwth-aachen.de ftp/pub/Linux/fedora/fedora/1/i386 os updates stable testing unstable rpm-src http://sunsite.informatik.rwth-aachen.de ftp/pub/Linux/fedora/fedora/1/i386 os updates stable testing unstable rpm http://apt.physik.fu-berlin.de fedora/1/en/i386 at-testing rpm-src http://apt.physik.fu-berlin.de fedora/1/en/i386 at-testing rpm http://ayo.freshrpms.net fedora/linux/1/i386 core updates freshrpms rpm http://people.ecsc.co.uk/~matt/downloads/apt fedora-1-i386 production testing depends rpm-src http://people.ecsc.co.uk/~matt/downloads/apt fedora-1-i386 production testing rpm ftp://apt-rpm.tuxfamily.org/apt fedora/1/i386 os updates testing extra rpm-src ftp://apt-rpm.tuxfamily.org/apt fedora/1/i386 os updates testing extra rpm http://apt.ling.li fedora/1/i586 li unstable rpm http://apt.sw.be redhat/fc1/en/i386 dag rpm http://rpm.livna.org/ fedora/1/i386 stable unstable testing rpm-src http://rpm.livna.org/ fedora/1/i386 stable unstable testing rpm http://newrpms.sunsite.dk/apt/ redhat/en/i386/fc1 newrpms rpm-src http://newrpms.sunsite.dk/apt/ redhat/en/i386/fc1 newrpms rpm http://ftp.icm.edu.pl/pub/linux/mplayer-rpms/apt/ 7.3 testing rpm http://rpms.xcyb.org/fedora/1 athlon stable bleeding rpm-src http://rpms.xcyb.org/fedora/1 athlon stable bleeding rpm http://download.fedora.us/ fedora/fedora/1/i386 stable rpm http://download.fedora.us/ fedora/fedora/1/i386 testing rpm http://download.fedora.us/ fedora/fedora/1/i386 os rpm http://download.fedora.us/ fedora/fedora/1/i386 updates rpm ftp://apt.kde-redhat.org/apt/ fedora/all stable rpm http://apt.wsisiz.edu.pl/ fc1/i386 wsisiz pozdr Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Papik Napisano Maj 1, 2004 Zgłoszenie Share Napisano Maj 1, 2004 OSError: [Errno 17] Plik istnieje: '/var/run/yum.pid' Wywal ten plik i bedzie dobrze Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
