Tworzenie Superusera W Mysql W Fc4
Bioreaktor
Witam
Jestem po calym dniu walki z serwerem a wlasciwie ratowania danych, no i koncze wlasnie instalacje na nowej fc4
Mam pytanie
w fedorze 4 mamy na starcie mysql'a jezeli sie nie mysql'a 5-0.4.10
zawsze zakladalem sobie uzytkownika superusera plikiem o tresci :
____
# Dumping data for table 'user'
INSERT INTO user VALUES("%", "uzytkownik", "haslo", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y", "Y");
flush privileges;
____
w nowej wersji nie widze tylu kolumien bo mamy :
mysql> use mysql
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> describe user;
| Field | Type | Null | Key | Default | Extra |
| Host | varchar(60) | | PRI | | |
| User | varchar(16) | | PRI | | |
| Password | varchar(41) | | | | |
| Select_priv | enum('N','Y') | | | N | |
| Insert_priv | enum('N','Y') | | | N | |
| Update_priv | enum('N','Y') | | | N | |
| Delete_priv | enum('N','Y') | | | N | |
| Create_priv | enum('N','Y') | | | N | |
| Drop_priv | enum('N','Y') | | | N | |
| Reload_priv | enum('N','Y') | | | N | |
| Shutdown_priv | enum('N','Y') | | | N | |
| Process_priv | enum('N','Y') | | | N | |
| File_priv | enum('N','Y') | | | N | |
| Grant_priv | enum('N','Y') | | | N | |
| References_priv | enum('N','Y') | | | N | |
| Index_priv | enum('N','Y') | | | N | |
| Alter_priv | enum('N','Y') | | | N | |
| Show_db_priv | enum('N','Y') | | | N | |
| Super_priv | enum('N','Y') | | | N | |
| Create_tmp_table_priv | enum('N','Y') | | | N | |
| Lock_tables_priv | enum('N','Y') | | | N | |
| Execute_priv | enum('N','Y') | | | N | |
| Repl_slave_priv | enum('N','Y') | | | N | |
| Repl_client_priv | enum('N','Y') | | | N | |
| ssl_type | enum('','ANY','X509','SPECIFIED') | | | | |
| ssl_cipher | blob | | | | |
| x509_issuer | blob | | | | |
| x509_subject | blob | | | | |
| max_questions | int(11) unsigned | | | 0 | |
| max_updates | int(11) unsigned | | | 0 | |
| max_connections | int(11) unsigned | | | 0 | |
31 rows in set (0.00 sec)
po probie ywkonania skryptu mam
ERROR 1136 (21S01): Column count doesn't match value count at row 1
jestem za bardzo zmeczony chyba juz i nie kontaktuje biggrin.gif, bardzo prosze Was o pomoc, abyscie mi podali ta zlota linijke smile.gif)) z prawidlowo wpisanymi wartosciamii do tej wersji, albo krok po kroku komendy od utworzenia uzytkownika do konca nadawania praw aby zostal super userem biggrin.gif bo ja juz nie mam sily hehe
dodam ze ostatnia wersja na ktorej dzialalem to mysql 4.0.4
z gory dzieki i pozdrawiam
