Yum Update
uosiu
[root@localhost ~]# yum update
Setting up Update Process
Setting up repositories
livna                     100% |=========================|  951 B    00:00
updates-released          100% |=========================|  951 B    00:00
jpackage-fedora           100% |=========================|  951 B    00:00
jpackage-generic          100% |=========================|  951 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
base                      100% |=========================| 1.1 kB    00:00
primary.xml.gz            100% |=========================| 192 kB    00:03
livna     : ################################################## 682/682
Added 9 new packages, deleted 8 old in 2.13 seconds
primary.xml.gz            100% |=========================| 367 kB    00:06
updates-re: ################################################## 1073/1073
Added 125 new packages, deleted 58 old in 12.28 seconds
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for libattr to pack into transaction set.
libattr-2.4.24-1.FC4.1.i3 100% |=========================| 4.5 kB    00:00
---> Package libattr.i386 0:2.4.24-1.FC4.1 set to be updated
---> Downloading header for nvidia-glx to pack into transaction set.
nvidia-glx-1.0.8174-0.lvn 100% |=========================|  28 kB    00:00
---> Package nvidia-glx.i386 0:1.0.8174-0.lvn.1.4 set to be updated
---> Downloading header for libacl to pack into transaction set.
libacl-2.2.32-1.FC4.2.i38 100% |=========================| 5.1 kB    00:00
---> Package libacl.i386 0:2.2.32-1.FC4.2 set to be updated
---> Downloading header for libacl-devel to pack into transaction set.
libacl-devel-2.2.32-1.FC4 100% |=========================| 9.3 kB    00:00
---> Package libacl-devel.i386 0:2.2.32-1.FC4.2 set to be updated
---> Downloading header for acl to pack into transaction set.
acl-2.2.32-1.FC4.2.i386.r 100% |=========================| 6.5 kB    00:00
---> Package acl.i386 0:2.2.32-1.FC4.2 set to be updated
---> Downloading header for libattr-devel to pack into transaction set.
libattr-devel-2.4.24-1.FC 100% |=========================| 7.2 kB    00:00
---> Package libattr-devel.i386 0:2.4.24-1.FC4.1 set to be updated
---> Downloading header for attr to pack into transaction set.
attr-2.4.24-1.FC4.1.i386. 100% |=========================| 6.5 kB    00:00
---> Package attr.i386 0:2.4.24-1.FC4.1 set to be updated
---> Downloading header for kernel-module-nvidia-2.6.14-1.1644_FC4 to pack into transaction set.
kernel-module-nvidia-2.6. 100% |=========================|  15 kB    00:00
---> Package kernel-module-nvidia-2.6.14-1.1644_FC4.i686 0:1.0.8174-0.lvn.1.4 set to be updated
--> Running transaction check
--> Processing Dependency: nvidia-glx = 0:1.0.7676 for package: kernel-module-nvidia-2.6.13-1.1532_FC4
--> Finished Dependency Resolution
Error: Missing Dependency: nvidia-glx = 0:1.0.7676 is needed by package kernel-module-nvidia-2.6.13-1.1532_FC4
dodam ze byl robiony wczoraj yum update, po ktorym wywalilem kilka starych kernelow po czym go nie restartowalem. dalej jezdzi na tym samym starcie. jak to naprawic? yum remove kernel module nvidia, update i install?
edit
[root@localhost ~]# rpm -qa |grep nvidia-glx
nvidia-glx-1.0.7676-0.lvn.3.4
z tego co widze to z livny wywalili modul 7676 i dali 81xx, ktory nie ma modulu do 2.6.13-1532... czyli jak nie siosadzie 2.6.14 to kupa, nie bede mial jak 2.6.13 odpalic biggrin.gif
oto calosc tego co dzisiaj namotalem w yumie
[root@localhost ~]# yum remove nvidia-glx
Setting up Remove Process
---> Package nvidia-glx.i386 0:1.0.7676-0.lvn.3.4 set to be erased
primary.xml.gz            100% |=========================| 895 kB    00:20
extras    : ################################################## 2547/2547
Added 17 new packages, deleted 5 old in 11.72 seconds
--> Processing Dependency: nvidia-glx = 0:1.0.7676 for package: kernel-module-nvidia-2.6.14-1.1644_FC4
--> Restarting Dependency Resolution with new changes.
---> Package kernel-module-nvidia-2.6.14-1.1644_FC4.i686 0:1.0.7676-0.lvn.3.4 set to be erased
---> Package kernel-module-nvidia-2.6.13-1.1532_FC4.i686 0:1.0.7676-0.lvn.2.4 set to be erased
Dependencies Resolved
Package                 Arch       Version          Repository        Size
Removing:
nvidia-glx              i386       1.0.7676-0.lvn.3.4  installed          11 M
Removing for dependencies:
kernel-module-nvidia-2.6.13-1.1532_FC4  i686       1.0.7676-0.lvn.2.4  installed         4.4 M
kernel-module-nvidia-2.6.14-1.1644_FC4  i686       1.0.7676-0.lvn.3.4  installed         4.4 M
Transaction Summary
Install      0 Package(s)
Update       0 Package(s)
Remove       3 Package(s)
Total download size: 0
Is this ok [y/N]: y
Downloading Packages:
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
 Removing  : kernel-module-nvidia-2.6.14- ######################### [1/3]
 Removing  : nvidia-glx                   ######################### [2/3]
 Removing  : kernel-module-nvidia-2.6.13- ######################### [3/3]
Removed: nvidia-glx.i386 0:1.0.7676-0.lvn.3.4
Dependency Removed: kernel-module-nvidia-2.6.13-1.1532_FC4.i686 0:1.0.7676-0.lvn.2.4 kernel-module-nvidia-2.6.14-1.1644_FC4.i686 0:1.0.7676-0.lvn.3.4
Complete!
primary.xml.gz            100% |=========================| 356 kB    00:08
updates-re: ################################################## 1014/1014
Added 9 new packages, deleted 68 old in 8.79 seconds
---> Downloading header for bittorrent to pack into transaction set.
bittorrent-4.2.1-1.fc4.no 100% |=========================|  37 kB    00:01
---> Package bittorrent.noarch 0:4.2.1-1.fc4 set to be updated
---> Downloading header for bittorrent-gui to pack into transaction set.
bittorrent-gui-4.2.1-1.fc 100% |=========================| 9.5 kB    00:00
---> Package bittorrent-gui.noarch 0:4.2.1-1.fc4 set to be updated
Updating:
bittorrent              noarch     4.2.1-1.fc4      extras            938 k
bittorrent-gui          noarch     4.2.1-1.fc4      extras             84 k
Transaction Summary
Update       2 Package(s)
Remove       0 Package(s)
Total download size: 1.0 M
Is this ok [y/N]: y
(1/2): bittorrent-4.2.1-1 100% |=========================| 938 kB    00:21
(2/2): bittorrent-gui-4.2 100% |=========================|  84 kB    00:01
Running Transaction
 Updating  : bittorrent                   ######################### [1/4]
 Updating  : bittorrent-gui               ######################### [2/4]
 Cleanup   : bittorrent                   ######################### [3/4]
 Cleanup   : bittorrent-gui               ######################### [4/4]
Updated: bittorrent.noarch 0:4.2.1-1.fc4 bittorrent-gui.noarch 0:4.2.1-1.fc4
Complete!
[root@localhost ~]# yum install nvidia-glx kernel-module-nvidia-$(uname -r)
Setting up Install Process
primary.xml.gz            100% |=========================| 367 kB    00:14
Added 68 new packages, deleted 9 old in 7.62 seconds
---> Package kernel-module-nvidia-2.6.13-1.1532_FC4.i686 0:1.0.7676-0.lvn.2.4 set to be updated
--> Processing Dependency: kernel-module-nvidia = 0:1.0.8174 for package: nvidia-glx
[root@localhost ~]# yum install kernel-module-nvidia-$(rpm -q --queryformat="%{version}-%{release}\n" kernel | tail -n 1)
--> Processing Dependency: nvidia-glx = 0:1.0.8174 for package: kernel-module-nvidia-2.6.14-1.1644_FC4
--> Processing Dependency: nvidia-glx for package: kernel-module-nvidia-2.6.14-1.1644_FC4
Installing:
kernel-module-nvidia-2.6.14-1.1644_FC4  i686       1.0.8174-0.lvn.1.4  livna             1.5 M
Installing for dependencies:
nvidia-glx              i386       1.0.8174-0.lvn.1.4  livna             3.9 M
Transaction Summary
Install      2 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 5.5 M
Is this ok [y/N]: y
(1/2): nvidia-glx-1.0.817 100% |=========================| 3.9 MB    02:21
(2/2): kernel-module-nvid 100% |=========================| 1.5 MB    00:57
Running Transaction
 Installing: nvidia-glx                   ######################### [1/2]
 Installing: kernel-module-nvidia-2.6.14- ######################### [2/2]
Installed: kernel-module-nvidia-2.6.14-1.1644_FC4.i686 0:1.0.8174-0.lvn.1.4
Dependency Installed: nvidia-glx.i386 0:1.0.8174-0.lvn.1.4
Complete!
[root@localhost ~]# yum remove xmms
---> Package xmms.i386 1:1.2.10-16 set to be erased
primary.xml.gz            100% |=========================| 346 kB    00:19
updates-re: ################################################## 1006/1006
Added 58 new packages, deleted 125 old in 7.71 seconds
primary.xml.gz            100% |=========================| 879 kB    00:20
extras    : ################################################## 2497/2497
Added 29 new packages, deleted 79 old in 14.67 seconds
--> Processing Dependency: xmms >= 1.0.1 for package: xmms-wma
--> Processing Dependency: libxmms.so.1 for package: kdebluetooth
--> Processing Dependency: xmms for package: xmms-crossfade
--> Processing Dependency: xmms = 1:1.2.10 for package: xmms-cdread
--> Processing Dependency: libxmms.so.1 for package: xmms-wma
--> Processing Dependency: libxmms.so.1 for package: xmms-flac
--> Processing Dependency: xmms for package: xmms-xosd
--> Processing Dependency: xmms for package: xmms-skins
--> Processing Dependency: xmms = 1:1.2.10 for package: xmms-mp3
--> Processing Dependency: libxmms.so.1 for package: xmms-crossfade
---> Package xmms-wma.i386 0:1.0.4.1-1.fc4 set to be erased
---> Package xmms-skins.noarch 1:1.2.10-15 set to be erased
---> Package xmms-crossfade.i386 0:0.3.8-4 set to be erased
---> Package xmms-cdread.i386 0:0.14-6.a set to be erased
---> Package xmms-flac.i386 0:1.1.2-25.fc4 set to be erased
---> Package xmms-xosd.i386 0:2.2.14-3 set to be erased
---> Package kdebluetooth.i386 0:1.0-0.4.beta1.kde set to be erased
---> Package xmms-mp3.i386 0:1.2.10-0.lvn.3.4 set to be erased
Removing:
xmms                    i386       1:1.2.10-16      installed         5.2 M
kdebluetooth            i386       1.0-0.4.beta1.kde  installed          17 M
xmms-cdread             i386       0.14-6.a         installed          74 k
xmms-crossfade          i386       0.3.8-4          installed         266 k
xmms-flac               i386       1.1.2-25.fc4     installed         122 k
xmms-mp3                i386       1.2.10-0.lvn.3.4  installed         180 k
xmms-skins              noarch     1:1.2.10-15      installed         2.7 M
xmms-wma                i386       1.0.4.1-1.fc4    installed         138 k
xmms-xosd               i386       2.2.14-3         installed          30 k
Transaction Summary
Update       0 Package(s)
Remove       9 Package(s)
Is this ok [y/N]: y
Running Transaction
 Removing  : xmms-flac                    ######################### [1/9]
 Removing  : xmms-wma                     ######################### [2/9]
 Removing  : xmms-skins                   ######################### [3/9]
 Removing  : xmms-crossfade               ######################### [4/9]
 Removing  : xmms-cdread                  ######################### [5/9]
 Removing  : xmms                         ######################### [6/9]
 Removing  : xmms-xosd                    ######################### [7/9]
 Removing  : kdebluetooth                 ######################### [8/9]
 Removing  : xmms-mp3                     ######################### [9/9]
Removed: xmms.i386 1:1.2.10-16
Dependency Removed: kdebluetooth.i386 0:1.0-0.4.beta1.kde xmms-cdread.i386 0:0.14-6.a xmms-crossfade.i386 0:0.3.8-4 xmms-flac.i386 0:1.1.2-25.fc4 xmms-mp3.i386 0:1.2.10-0.lvn.3.4 xmms-skins.noarch 1:1.2.10-15 xmms-wma.i386 0:1.0.4.1-1.fc4 xmms-xosd.i386 0:2.2.14-3
Complete!
[root@localhost ~]# yum install xmms kdebluetooth xmms-cdread xmms-crossfade xmms-flac xmms-mp3 xmms-skins xmms-wma xmms-xosd
primary.xml.gz            100% |=========================| 367 kB    00:09
Added 125 new packages, deleted 58 old in 15.46 seconds
No Match for argument: kdebluetooth
No Match for argument: xmms-wma
---> Package xmms.i386 1:1.2.10-16 set to be updated
---> Package xmms-skins.noarch 1:1.2.10-15 set to be updated
---> Package xmms-crossfade.i386 0:0.3.8-4 set to be updated
---> Package xmms-cdread.i386 0:0.14-6.a set to be updated
---> Package xmms-xosd.i386 0:2.2.14-3 set to be updated
---> Package xmms-flac.i386 0:1.1.2-25.fc4 set to be updated
---> Package xmms-mp3.i386 0:1.2.10-0.lvn.3.4 set to be updated
Installing:
xmms                    i386       1:1.2.10-16      extras            1.9 M
xmms-cdread             i386       0.14-6.a         extras             36 k
xmms-crossfade          i386       0.3.8-4          extras             97 k
xmms-flac               i386       1.1.2-25.fc4     extras             56 k
xmms-mp3                i386       1.2.10-0.lvn.3.4  livna              78 k
xmms-skins              noarch     1:1.2.10-15      extras            2.6 M
xmms-xosd               i386       2.2.14-3         extras             18 k
Transaction Summary
Install      7 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 4.8 M
Is this ok [y/N]: y
(1/7): xmms-1.2.10-16.i38 100% |=========================| 1.9 MB    00:40
(2/7): xmms-skins-1.2.10- 100% |=========================| 2.6 MB    00:58
(3/7): xmms-crossfade-0.3 100% |=========================|  97 kB    00:01
(4/7): xmms-cdread-0.14-6 100% |=========================|  36 kB    00:00
(5/7): xmms-xosd-2.2.14-3 100% |=========================|  18 kB    00:00
(6/7): xmms-flac-1.1.2-25 100% |=========================|  56 kB    00:00
(7/7): xmms-mp3-1.2.10-0. 100% |=========================|  78 kB    00:02
Running Transaction
 Installing: xmms                         ######################### [1/7]
 Installing: xmms-skins                   ######################### [2/7]
 Installing: xmms-crossfade               ######################### [3/7]
 Installing: xmms-cdread                  ######################### [4/7]
 Installing: xmms-xosd                    ######################### [5/7]
 Installing: xmms-flac                    ######################### [6/7]
 Installing: xmms-mp3                     ######################### [7/7]
Installed: xmms.i386 1:1.2.10-16 xmms-cdread.i386 0:0.14-6.a xmms-crossfade.i386 0:0.3.8-4 xmms-flac.i386 0:1.1.2-25.fc4 xmms-mp3.i386 0:1.2.10-0.lvn.3.4 xmms-skins.noarch 1:1.2.10-15 xmms-xosd.i386 0:2.2.14-3
Complete!
[root@localhost ~]# cd ~uosiu
[root@localhost uosiu]# rpm -ivh xmms*.rpm
Przygotowywanie...          ########################################### [100%]
  1:xmms-wma               ########################################### [100%]
