Yum Update...:(
vonblank
witam!!
mam problem z aktualizacją systemu!!
gdy daje komende
yum update
po wypisaniu dostepnych pakietów strasznie długo robi test aż w końcu wyskakuje...
Transaction Summary
Install     10 Package(s)
Update     561 Package(s)
Remove       0 Package(s)
Total download size: 1.6 G
Is this ok [y/N]: y
Downloading Packages:
Running Transaction Test
Finished Transaction Test
Transaction Check Error:   file /usr/lib64/libbind.so.3.0.8 from install of bind
-libbind-devel-9.3.1-14_FC4 conflicts with file from package bind-libs-9.3.1-4
 file /usr/share/man/man1/debugsh.1.gz from install of pilot-link-0.12.0-0.pre4
.0.fc4.2 conflicts with file from package pilot-link-0.12.0-0.pre2.0
 file /usr/share/man/man1/dlpsh.1.gz from install of pilot-link-0.12.0-0.pre4.0
 file /usr/share/man/man1/hinotes.1.gz from install of pilot-link-0.12.0-0.pre4
 file /usr/share/man/man1/ietf2datebook.1.gz from install of pilot-link-0.12.0-
0.pre4.0.fc4.2 conflicts with file from package pilot-link-0.12.0-0.pre2.0
 file /usr/share/man/man1/install-datebook.1.gz from install of pilot-link-0.12
.0-0.pre4.0.fc4.2 conflicts with file from package pilot-link-0.12.0-0.pre2.0
 file /usr/share/man/man1/install-expenses.1.gz from install of pilot-link-0.12
 file /usr/share/man/man1/install-hinote.1.gz from install of pilot-link-0.12.0
 file /usr/share/man/man1/install-memo.1.gz from install of pilot-link-0.12.0-0
 file /usr/share/man/man1/install-netsync.1.gz from install of pilot-link-0.12.
 file /usr/share/man/man1/install-todo.1.gz from install of pilot-link-0.12.0-0
 file /usr/share/man/man1/install-todos.1.gz from install of pilot-link-0.12.0-
 file /usr/share/man/man1/install-user.1.gz from install of pilot-link-0.12.0-0
 file /usr/share/man/man1/memos.1.gz from install of pilot-link-0.12.0-0.pre4.0
 file /usr/share/man/man1/pi-csd.1.gz from install of pilot-link-0.12.0-0.pre4.
 file /usr/share/man/man1/pi-getram.1.gz from install of pilot-link-0.12.0-0.pr
 file /usr/share/man/man1/pi-getrom.1.gz from install of pilot-link-0.12.0-0.pr
 file /usr/share/man/man1/pi-getromtoken.1.gz from install of pilot-link-0.12.0
 file /usr/share/man/man1/pi-nredir.1.gz from install of pilot-link-0.12.0-0.pr
 file /usr/share/man/man1/pilot-addresses.1.gz from install of pilot-link-0.12.
 file /usr/share/man/man1/pilot-clip.1.gz from install of pilot-link-0.12.0-0.p
 file /usr/share/man/man1/pilot-dedupe.1.gz from install of pilot-link-0.12.0-0
 file /usr/share/man/man1/pilot-file.1.gz from install of pilot-link-0.12.0-0.p
 file /usr/share/man/man1/pilot-foto.1.gz from install of pilot-link-0.12.0-0.p
 file /usr/share/man/man1/pilot-schlep.1.gz from install of pilot-link-0.12.0-0
 file /usr/share/man/man1/pilot-treofoto.1.gz from install of pilot-link-0.12.0
 file /usr/share/man/man1/pilot-wav.1.gz from install of pilot-link-0.12.0-0.pr
 file /usr/share/man/man1/pilot-xfer.1.gz from install of pilot-link-0.12.0-0.p
 file /usr/share/man/man1/read-expenses.1.gz from install of pilot-link-0.12.0-
 file /usr/share/man/man1/read-ical.1.gz from install of pilot-link-0.12.0-0.pr
 file /usr/share/man/man1/read-notepad.1.gz from install of pilot-link-0.12.0-0
 file /usr/share/man/man1/read-palmpix.1.gz from install of pilot-link-0.12.0-0
 file /usr/share/man/man1/read-screenshot.1.gz from install of pilot-link-0.12.
 file /usr/share/man/man1/read-todos.1.gz from install of pilot-link-0.12.0-0.p                                           re4.0.fc4.2 conflicts with file from package pilot-link-0.12.0-0.pre2.0
 file /usr/share/man/man1/read-veo.1.gz from install of pilot-link-0.12.0-0.pre                                           4.0.fc4.2 conflicts with file from package pilot-link-0.12.0-0.pre2.0
 file /usr/share/man/man1/reminders.1.gz from install of pilot-link-0.12.0-0.pr                                           e4.0.fc4.2 conflicts with file from package pilot-link-0.12.0-0.pre2.0
 file /etc/sensors.conf from install of lm_sensors-2.9.1-3.FC4.2 conflicts with                                            file from package lm_sensors-2.8.8-5
 file /usr/bin/decode-vaio.pl from install of lm_sensors-2.9.1-3.FC4.2 conflict                                           s with file from package lm_sensors-2.8.8-5
 file /usr/sbin/pwmconfig from install of lm_sensors-2.9.1-3.FC4.2 conflicts wi                                           th file from package lm_sensors-2.8.8-5
 file /usr/sbin/sensors-detect from install of lm_sensors-2.9.1-3.FC4.2 conflic                                           ts with file from package lm_sensors-2.8.8-5
 file /usr/share/man/man8/i2cset.8.gz from install of lm_sensors-2.9.1-3.FC4.2                                            conflicts with file from package lm_sensors-2.8.8-5
 file /usr/share/man/man8/isadump.8.gz from install of lm_sensors-2.9.1-3.FC4.2                                            conflicts with file from package lm_sensors-2.8.8-5
 file /usr/share/man/man8/isaset.8.gz from install of lm_sensors-2.9.1-3.FC4.2                                            conflicts with file from package lm_sensors-2.8.8-5
 file /usr/bin/alsacard from install of alsa-utils-1.0.10-1.FC4 conflicts with                                            file from package alsa-lib-1.0.9rc4-2
[root@localhost ~]#
nie jestem jesszce wprawnym użytkownikiem (_linuxa_ → Linuksa) ORT, prosze o pomoc
tak, instalowałem...
ale jest cos jeszcze.... za pierwszym razem update zrobił mi sie.... znaczy ściagneły mi sie pliki ale przy instalacji proces staną na 127 pakiecie z 1288 (czy coś takiego), najnowszy kerlen też chyba wgrałem osobno, albo własnie przy tym update-cie!!
Zdarzylo mi sie kilka razy sciagac ok. 1GB (update na czystej duzej instalce) ale 1.6GB to jeszcze nie widzialem... ;-) to sporo nawet jak na 64bit'y, a takiej chyba wlasnie platformy uzywasz?... Robisz jakis koszmarny UPGRADE, czy to rzeczywiscie update?
Na Twoim miejscu sprawdzilbym konfiguracje yuma czy przypadkiem nie masz powlaczanych za duzo repozytoriow, zostaw tylko base / extras / updates-released + livna (zadnych devel / testing ani innych dodatkowych), zapusc
yum clean all
...choc z drugiej strony jak juz sciagnales te 1.6GB to szkoda wszystko wyrzucac, moze
yum clean metadata
wystarczy? A pozniej
yum update kernel
restart i dopiero
yum update
BTW - nie chce sie wdawac w dyskusje czy takie zachowanie (najpierw update kernela, restart i dopiero cala reszta, mi takie zachowanie kilkukrotnie pomoglo :-)
... i powiedz czy nadal chce ciagnac 1.6GB
Ale wyglada na to ze niezle juz zdazyles namieszac instalkami spoza yuma...
Pozdrawiam, i powodzenia zycze
W zasadzie tez czesto tak robie, choc z drugiej strony ciezko znalesc logiczne uzasadnienie dla takiego postepowania (podobnie jak z 'moim' kernelem...).
Nie widze wplywu jaki moglby miec 'nowszy' yum na przebieg aktualizacji ktorej czas zalezy w zasadzie tylko od predkosci lacza + mocy obliczeniowej maszyny...
yum funkcjonalne to 'polaczenie' programow wget i rpm, nowsza wersja moze byc bezpieczniejsza, stabilniejsza, miec wieksza 'konfigurowalnosc', posiadac nowe mozliwosci (lepsze ponawianie pobierania - dociaganie pakietow, lepsza kontrola poprawnosci pobranych juz plikow, lepsza/szybsza obsluga mirrorow, wewnetrzna kompresja(?) itd...), ale na sam proces aktualizacji 1.6GB pakietow wplywu raczej to nie ma.
Chyba ze ktoras z nowych 'funkcjonalnosci' wlasnie zostanie wykorzystana, jak np: [fantazja] wykrycie uszkodzenia w juz pobranym pliku - uszkodzenia ktorego starsza wersja nie wykrywala, lub wykorzystanie dodatkowej kompresji przy transferze z odpowiedniego mirrora - kompresji ktorej poprzednia wersja byla pozbawiona [/fantazja]...
Mialem napisac, ze aktualizacja yuma przed czymkolwiek innym jest "sztuka dla sztuki", ale wlasnie przekonalem sam siebie ze tak chyba nie jast unsure.gif
Chyba nie powinienem sie dzis wypowiadac publicznie na forum...
Pozdro
