Yum Instalowanie Konkretnej Wersji
kakiet
Witam:)
Chcialem ostatnio zainstalowac sobie sterowniki do mojej karty grafiki. A wiec wydaje polecenie:
[root@localhost ~]# yum install kernel-module-nvidia-2.6.11-1.1369_FC4
Setting up Install Process
Setting up repositories
livna                     100% |=========================|  951 B    00:00
kde-redhat                100% |=========================|  951 B    00:00
base                      100% |=========================| 1.1 kB    00:00
extras                    100% |=========================| 1.1 kB    00:00
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package kernel-module-nvidia-2.6.11-1.1369_FC4.i686 0:1.0.7174-0.lvn.4.4 set to be updated
--> Running transaction check
--> Processing Dependency: /usr/sbin/nvidia-config-display for package: kernel-module-nvidia-2.6.11-1.1369_FC4
--> Processing Dependency: nvidia-glx = 0:1.0.7174 for package: kernel-module-nvidia-2.6.11-1.1369_FC4
--> Restarting Dependency Resolution with new changes.
---> Package nvidia-glx.i386 0:1.0.8174-0.lvn.1.4 set to be updated
--> Processing Dependency: kernel-module-nvidia = 0:1.0.8174 for package: nvidia-glx
---> Package kernel-module-nvidia-2.6.14-1.1644_FC4.i686 0:1.0.8174-0.lvn.1.4 set to be updated
--> Finished Dependency Resolution
Error: Missing Dependency: nvidia-glx = 0:1.0.7174 is needed by package kernel-module-nvidia-2.6.11-1.1369_FC4
Zawsze myslalem ze yum potrafi obsluzyc zaleznosci ale mowi sie trudno i szikam pakietu nvidia-glx = 0:1.0.7174. Wydaje polecenie idostaje:
[root@localhost ~]# yum search nvidia-glx
Searching Packages:
nvidia-glx-legacy-devel.i386             1.0.7174-0.lvn.2.4     livna
Matched from:
nvidia-glx-devel.i386                    1.0.7174-0.lvn.4.4     livna
Matched from:
nvidia-glx-devel
nvidia-glx.i386                          1.0.7174-0.lvn.4.4     livna
Matched from:
nvidia-glx
i tak dalej.....
W takim razie wpisuje
[root@localhost ~]# yum install nvidia-glx.i386
Dependencies Resolved
Package                 Arch       Version          Repository        Size
Installing:
nvidia-glx              i386       1.0.8174-0.lvn.1.4  livna             3.9 M
Installing for dependencies:
kernel-module-nvidia-2.6.14-1.1644_FC4  i686       1.0.8174-0.lvn.1.4  livna             1.5 M
Transaction Summary
Install      2 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 5.5 M
Is this ok [y/N]:
A on chce mi instalowac nie te co trzeba moduly nvidia-glx oraz nie te co trzeba sterowniki do karty graf. kernel-module-nvidia-2.6.14-1.1644_FC4 i686 (podczas gdy ja mam jadro 2.6.11-1.1369)?
Jak temu zaradzic?
Zaktualizuj kernela, aktualizujesz system w ogóle? Używasz jajka dostarczonego z dystrybucją, nic dziwnego, że chce Ci zainstalować do nowszego bo Twoje już nie jest wspierane.
/edit/
Zgodnie z tym to yum nie robi nic dziwnego, instaluje moduł do kernela którego posiadasz.
Edytowane przez Zuk87
