Problemy Z K3b Po Aktualizacji
ars
Witam wczoraj postawilem na nowo FC bo za duzo namieszalem... od razu jak stal czysty (_linuks_ → Linux) ORT zrobilem update yumem i teraz gdy chce odpalic k3b wyskakuje mi blad:
K3b - obsluga krytycznych bledow w KDE
(no debugging symbols found)
Using host libthread_db library "/lib/libthread_db.so.1".
`shared object read from target memory' has disappeared; keeping its symbols.
[Thread debugging using libthread_db enabled]
[New Thread -1208730784 (LWP 3453)]
[KCrash handler]
#4 0x00be0483 in __gnu_cxx::__pool<true>::_M_reclaim_block ()
from /usr/lib/libstdc++.so.6
#5 0x002d9265 in Arts::readTypeSeq<Arts::InterfaceDef> ()
from /usr/lib/libmcop.so.1
#6 0x002ce228 in Arts::ModuleDef::readType () from /usr/lib/libmcop.so.1
#7 0x002ce6aa in Arts::ModuleDef::ModuleDef () from /usr/lib/libmcop.so.1
#8 0x002f996f in Arts::IDLFileReg::startup () from /usr/lib/libmcop.so.1
#9 0x00301bf2 in Arts::StartupManager::startup () from /usr/lib/libmcop.so.1
#10 0x002e27d5 in Arts::Dispatcher::Dispatcher () from /usr/lib/libmcop.so.1
#11 0x00593aa9 in KArtsDispatcher::KArtsDispatcher ()
from /usr/lib/libartskde.so.1
#12 0x0808a5c0 in KFileTreeView::slotSetNextUrlToSelect ()
#13 0x0809b86e in QValueList<int>::detachInternal ()
#14 0x0809f228 in QValueList<int>::detachInternal ()
#15 0x0808194b in QValueListPrivate<QString>::QValueListPrivate ()
#16 0x080a003f in QPtrList<K3bPluginFactory>::~QPtrList ()
#17 0x06a42d5f in __libc_start_main () from /lib/libc.so.6
#18 0x0807e0f1 in ?? ()
odinstalowalem yumem k3b i zainstalowalem na nowo (tez przez yum) i dalej mam ten sam problem... co robic? dziekuje za pomoc smile.gif
