Problem...
Phase_Accurate
Witam,
Po komendzie uname -rm command dostaje takie info:
2.6.14-1.1656_FC4smp i686
Więc zainstalowałem:
2.6.14-1.1656_FC4 i686-smp Multi Processor rpm.
Mój /etc/fstab wyglada tak:
This file is edited by fstab-sync - see 'man fstab-sync' for details
/dev/VolGroup00/LogVol00 / ext3 defaults 1 1
LABEL=/boot /boot ext3 defaults 1 2
/dev/devpts /dev/pts devpts gid=5,mode=620 0 0
/dev/shm /dev/shm tmpfs defaults 0 0
/dev/proc /proc proc defaults 0 0
/dev/sys /sys sysfs defaults 0 0
/dev/VolGroup00/LogVol01 swap swap defaults 0 0
/dev/fd0 /media/floppy auto pamconsole,exec,noauto,managed 0 0
/dev/scd0 /media/cdrom auto pamconsole,exec,noauto,managed 0 0
/dev/hdc /media/cdrecorder auto pamconsole,exec,noauto,managed 0 0
/dev/sda1 /mnt/win-c ro,defaults,umask=0222 0 0
/dev/sdb5 /mnt/win-d ro,defaults,umask=0222 0 0
Wynik fdisk -l wygląda tak:
[root@localhost chefren]# /sbin/fdisk -l
Disk /dev/sda: 37.0 GB, 37019566080 bytes
255 heads, 63 sectors/track, 4500 cylinders
/dev/sda1 * 1 3084 24772198+ 7 HPFS/NTFS
/dev/sda2 3085 3097 104422+ 83 Linux
/dev/sda3 3098 4500 11269597+ 8e Linux LVM
Disk /dev/sdb: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders
/dev/sdb1 * 2 14593 117210240 f W95 Ext'd (LBA)
/dev/sdb5 2 14593 117210208+ 7 HPFS/NTFS
Jednak właściwe katalogi w /mnt/ są puste - nie podmontował:
Dziwne jest to, że:
root@localhost chefren]# rpm -q kernel-module-ntfs-2.6.14-1.656_FC4smp
package kernel-module-ntfs-2.6.14-1.656_FC4smp is not installed
[root@localhost chefren]# yum install kernel-module-ntfs-2.6.14-1.656_FC4smp
Setting up Install Process
Setting up repositories
updates-released 100% |=========================| 951 B 00:00
extras 100% |=========================| 1.1 kB 00:00
base 100% |=========================| 1.1 kB 00:00
primary.xml.gz 100% |=========================| 424 kB 00:06
updates-re: ################################################## 1192/1192
Added 5 new packages, deleted 9 old in 2.44 seconds
primary.xml.gz 100% |=========================| 991 kB 00:13
extras : ################################################## 2877/2877
Added 81 new packages, deleted 10 old in 4.45 seconds
No Match for argument: kernel-module-ntfs-2.6.14-1.656_FC4smp
Nothing to do
Dziwne - niby zaistaloał odpowiedni pakiet do NTFS'a ale coś się pomieszało.
Co dziwniejsze po kliknieći na znajdującym sie na pulpiecie
kernel-module-ntfs-2.6.14-1.656_FC4smp-2.1.24-0.rr.10.4.i656.rpm
system infomuje mnie, że jest zainstalowany.
Jeszcze dodam to, żeby było jaśniej:
[root@localhost ~]# uname -r
[root@localhost ~]# rpm -qa | grep ntfs
kernel-module-ntfs-2.6.14-1.1656_FC4smp-2.1.24-0.rr.10.4
Co może być?
Będę wdzięczy na wszystkie sugestie,
EDIT:
O dziwo po komendach:
mount -t ntfs /dev/sda1 /mnt/win-c
mount -t ntfs /dev/sdb5 /mnt/win-d
Dyski montuje - widać zawartośc katalogow (wszystko w konsoli @root)
I dziwna rzecz - patrze w fstab - a teraz okazuje się, że linijki:
Znajdują sie na środku pliku fstab a nie na koncu...
/dev/hda1 /mnt/windows ntfs ro,umask=0222 0 0
tak wygląda poprawny wpis w fstabie
tak wygląda Twój. Widzisz różnicę? Brakuje "ntfs".
/dev/sdb5 /mnt/win-d ntfs ro,defaults,umask=0222 0 0
Taki wpis powinieneś mieć. Analogicznie do drugiej partycji.
