Kłopot Przy Budowaniu źródeł Kernela
galak
+ make ARCH=i386 nonint_oldconfig
In file included from /usr/include/bits/posix1_lim.h:153,
from /usr/include/limits.h:144,
from /usr/lib/gcc/i386-redhat-linux/4.0.2/include/limits.h:122,
from /usr/lib/gcc/i386-redhat-linux/4.0.2/include/syslimits.h:7,
from /usr/lib/gcc/i386-redhat-linux/4.0.2/include/limits.h:11,
from scripts/basic/fixdep.c:113:
/usr/include/bits/local_lim.h:36:26: error: linux/limits.h: No such file or directory
In file included from /usr/include/sys/socket.h:35,
from /usr/include/netinet/in.h:24,
from /usr/include/arpa/inet.h:23,
from scripts/basic/fixdep.c:115:
/usr/include/bits/socket.h:304:24: error: asm/socket.h: No such file or directory
scripts/basic/fixdep.c: In function 'use_config':
scripts/basic/fixdep.c:201: error: 'PATH_MAX' undeclared (first use in this function)
scripts/basic/fixdep.c:201: error: (Each undeclared identifier is reported only once
scripts/basic/fixdep.c:201: error: for each function it appears in.)
scripts/basic/fixdep.c:201: warning: unused variable 's'
scripts/basic/fixdep.c: In function 'parse_dep_file':
scripts/basic/fixdep.c:297: error: 'PATH_MAX' undeclared (first use in this function)
scripts/basic/fixdep.c:297: warning: unused variable 's'
make[1]: *** [scripts/basic/fixdep] Error 1
make: *** [scripts_basic] Error 2
bł±d: Błędny status wyj¶cia z /var/tmp/rpm-tmp.74992 (%prep)
Błędy budowania RPM-a:
i co z tym zrobić ??
wykonywane polecenia :
rpm -ivh kernel-****src.rpm
rpmbuild -bp --target=i686 kernel-2.6.spec
zaktualizowany policycoreutils, udev, selinux-policy-targeted
jajo 2.6.14-1.1656_FC4
