Instalacja Matlaba
bisz
na mandrivie instalacja przebiegla bez przeszkod, tu jednak na fedorze 4 na takowe sie natknąłem
[root@marek marekd]# /home/marekd/matlab/install
An error status was returned by the program 'xsetup',
the X Window System version of 'install'. The following
messages were written to standard error:
/tmp/5002tmwinstall/update/bin/glnx86/xsetup: error while loading shared libraries: /tmp/5002tmwinstall/update/bin/glnx86/libmwins.so: cannot restore segment prot after reloc: Permission denied
Attempt to fix the problem and try again. If X is not available
or 'xsetup' cannot be made to work then try the terminal
version of 'install' using the command:
install* -t or INSTALL* -t
/tmp/5002tmwinstall/update/install/abort.sh: line 15: /tmp/5002tmwinstall/update/install/cleanup.sh: Nie ma takiego pliku ani katalogu
no dobra, robie instalacje z tym parametrem -t
[root@marek marekd]# /home/marekd/matlab/install* -t
Welcome to the MATLAB Installer
| Please review the license agreement on the next set of screens. On any |
| screen the options to proceed are at the bottom. Type your response |
| at the prompt. |
[screen 1 of 38]
The MathWorks, Inc.
Software License Booklet
IMPORTANT NOTICE
Read the terms and conditions of your License Agreement carefully.
The License Agreement together with any applicable Addendum
represents the entire agreement between you (the "Licensee") and The
MathWorks, Inc. ("MathWorks") concerning the Program(s) and
Documentation delivered hereunder.
CONTENTS
The MathWorks, Inc. Software License Agreement
Installation and Use Addendum (if applicable)
Educational Installation and Use Addendum (if applicable)
Student Installation and Use Addendum (if applicable)
Deployment Addendum
>>>>>>>> For this License Agreement <<<<<<<<
Enter either: <return> a r p ^C
To: [next screen] [accept] [reject] [print] [abort]
> a
/tmp/5165tmwinstall/update/bin/glnx86/xsetup: error while loading shared libraries: /tmp/5165tmwinstall/update/bin/glnx86/libmwins.so: cannot restore segment prot after reloc: Permission denied
co radzicie ?
