Problem Z Yum Upgrade
shymon_
mam problem z upgradem fedory.... przy tworzeniu zaleznosci wyskakuje mi blad dotyczacy nvidia-glx - jest wymagadny przez inny pakiet lecz nie moze znalezdz tego pakietu.. chodz najnowsza wersja jest zainstalowana. mozna jakos zrobic uprgade wylaczajac niektore paczki
rpm -qa |grep kernel: zwrocil:
kernel-2.6.14-1.1653_FC4
kernel-2.6.11-1.1369_FC4
kernel-module-ntfs-2.6.14-1.1653_FC4-2.1.22-0.lvn.3.4
kernel-devel-2.6.11-1.1369_FC4
kernel-module-ntfs-2.6.11-1.1369_FC4-2.1.22-0.lvn.3.4
kernel-module-nvidia-2.6.14-1.1653_FC4-1.0.8178-0.lvn.1.4
a yum update:
Setting up Update Process
Setting up repositories
primary.xml.gz 100% |=========================| 438 kB 00:17
primary.xml.gz 100% |=========================| 431 kB 00:17
primary.xml.gz 100% |=========================| 431 kB 00:33
primary.xml.gz 100% |=========================| 400 kB 00:16
primary.xml.gz 100% |=========================| 431 kB 00:16
primary.xml.gz 100% |=========================| 431 kB 00:23
primary.xml.gz 100% |=========================| 431 kB 00:18
primary.xml.gz 100% |=========================| 431 kB 00:20
primary.xml.gz 100% |=========================| 431 kB 00:35
primary.xml.gz 100% |=========================| 396 kB 00:19
primary.xml.gz 100% |=========================| 431 kB 00:19
primary.xml.gz 100% |=========================| 346 kB 00:15
primary.xml.gz 100% |=========================| 438 kB 00:22
primary.xml.gz 100% |=========================| 431 kB 00:28
primary.xml.gz 100% |=========================| 431 kB 00:22
primary.xml.gz 100% |=========================| 431 kB 00:21
primary.xml.gz 100% |=========================| 431 kB 00:15
primary.xml.gz 100% |=========================| 431 kB 00:25
primary.xml.gz 100% |=========================| 438 kB 00:19
primary.xml.gz 100% |=========================| 431 kB 06:44
primary.xml.gz 32 kB 00:02
primary.xml.gz 100% |=========================| 0 B 00:15
primary.xml.gz 100% |=========================| 360 kB 01:05
primary.xml.gz 100% |=========================| 346 kB 00:18
Error: failure: repodata/primary.xml.gz from updates-released: [Errno 256] No more mirrors to try.
  • 3 weeks later...
(jestem poczatkujacym uzytkownikiem)
podczepie sie pod temat bo takze mam problem z yum update.
Chce zrobic aktalizacje systemu, wpisalem yum update, ruszylo wiec zostawilem kompa na noc wlaczonego zeby sie aktualizowalo. Paczki zostaly sciagniete na dysk ale system nie zostal zaktualizowany(???).
Nic sie nie zmeinilo, dalem restar i mam to co mialem.
Pomyslalem sobie, wlacze na nowo update, ale dalej sie nie zaktualizowalo.
Postanowilem recznie zaktualizowac cos i tu nie bylo problemow. yum nie sciagal paczki tylko od razu przeszedl do instalacji.
Jak mam teraz zrobic aktualizacje? przeciez nie bede instalowal wszytkiego z osobna :/
@pawel_F4 - yum pobral juz na dysk wszystkie paczki... nie wiem dlaczego po pobraniu nie zainstalowal ich jak nalezy, ale mam jakies podejrzenia ze to Twoj pierwszy yum update i moze byc tych paczek troche duzo?... Sprawdz konfiguracje repozytoriow i zainstaluj odpowiedznie klucze jesli jeszcze ich nie zainstalowales (info dosc latwo znajdziesz na tym forum) i na dzien dobry uruchom
yum update yum
potem
yum update kernel
restart i caly update
yum update
Gdybys mial nadal problemy, to daj znac na czym sie wysypuje...
I jeszcze wazne info - dzialasz na FC4?
@shymon_ - albo to chwilowe problemy z repo updates-released albo masz cos pokaszanione z repozytoriami... na wszelki wypadek sprawdz kofiguracje.
Pozdro
