pitero Napisano Marzec 2, 2006 Zgłoszenie Share Napisano Marzec 2, 2006 Witam, mam taki problem z vpn w trybie bridge. eth0 - 192.168.1.254 eth1 - ip.zewn.netu załadowany moduł bridge route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface ip.sieci.zewn.netu * 255.255.255.248 U 0 0 0 eth1 192.168.1.0 * 255.255.255.0 U 0 0 0 eth0 169.254.0.0 * 255.255.0.0 U 0 0 0 eth0 default ip.zewn.netu 0.0.0.0 UG 0 0 0 eth1 udostępnione poł. internetowe - wszystko hula montuje most eth="eth0" eth_ip="192.168.1.200" eth_netmask="255.255.255.0" eth_broadcast="192.168.1.255" openvpn --mktun --dev $tap brctl addbr $br brctl addif $br $eth pause brctl addif $br $tap ifconfig $tap 0.0.0.0 promisc up ifconfig $eth 0.0.0.0 promisc up ifconfig $br $eth_ip netmask $eth_netmask broadcast $eth_broadcast no i teraz Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface ip.sieci.zewn.netu * 255.255.255.248 U 0 0 0 eth1 192.168.1.0 * 255.255.255.0 U 0 0 0 br0 192.168.1.0 * 255.255.255.0 U 0 0 0 eth0 169.254.0.0 * 255.255.0.0 U 0 0 0 eth0 default ip.zewn.netu 0.0.0.0 UG 0 0 0 eth1 ifconfig br0 Link encap:Ethernet HWaddr 00:0E:2E:52:FE:49 inet addr:192.168.1.200 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::20e:2eff:fe52:fe49/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:2 errors:0 dropped:0 overruns:0 frame:0 TX packets:8 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:273 (273.0 TX bytes:540 (540.0 eth0 Link encap:Ethernet HWaddr 00:0E:2E:52:FE:49 inet addr:192.168.1.254 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::20e:2eff:fe52:fe49/64 Scope:Link UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1 RX packets:1030 errors:0 dropped:0 overruns:0 frame:0 TX packets:27950 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:144042 (140.6 KiB) TX bytes:2028735 (1.9 MiB) Interrupt:11 Base address:0xa800 eth1 Link encap:Ethernet HWaddr 00:0E:2E:52:DA:67 inet addr:ip.zewn.netu Bcast:88.x9.1x.1x Mask:255.255.255.248 inet6 addr: fe80::20e:2eff:fe52:da67/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:4190 errors:0 dropped:0 overruns:0 frame:0 TX packets:1963 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:713939 (697.2 KiB) TX bytes:315408 (308.0 KiB) Interrupt:10 Base address:0xa400 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:27423 errors:0 dropped:0 overruns:0 frame:0 TX packets:27423 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:1752663 (1.6 MiB) TX bytes:1752663 (1.6 MiB) tap0 Link encap:Ethernet HWaddr 12:CF:29:67:3B:CF inet6 addr: fe80::10cf:29ff:fe67:3bcf/64 Scope:Link UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:7 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 TX bytes:0 (0.0 kompy z sieci lokalnej mogą ping-ować na eth0, br0, eth1 i tyle. Do modemu dsl już nie, a tym bardziej gdzieś dalej po zatrzymaniu mostu br="br0" tap="tap0" ifconfig $br down brctl delbr $br openvpn --rmtun --dev $tap wszystko wraca do normy - czyli sieć wewn uzyskuje dostęp do netu W czym może być problem ? Czemu pingi przestają działać ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
