Xgl W Fc5 ?
Hadron
AIGLX Project for Fedora Core 5 and Beyond - Fedora Project Wiki
Written by Administrator  User Rating:starstarstarstarstar / 1
Wednesday, 22 February 2006
AIGLX is 'Accelerated Indirect GL X'.
There are three interesting pieces of technology here:
  1.
      An updated Mesa that includes accelerated indirect rendering. This allows the compositing manager to do GL operations through the server instead of having to push window pixmaps from the COMPOSITE extension down to the client and then back up to the card.
  2.
      A version of metacity with a compositing manager enabled. It has a few effects implemented, including window minimzation and drop shadows.
  3.
      An updated X server. This X server is a devlopement version of Xorg that contains support for a new extension to improve performance. It can be installed along side your usual X server.
We are planning on shipping the first two with FC5. They should function normally in standard use. We plan to make the third available as a separate yum repository or possibly in Fedora Extras over the course of FC5.
pierwsze 2 podpunkty maja podobny byc juz w fc5 wink.gif a 3 w krutce ma byc dostepne na rep;)
Moge sięmylić, ale czy AIGLX nie jest ściśle zależne od sterowników (zamkniętych sterowników), a sami znacie filozofię Fedory Core. Chyba że z założenia będzie działało na Mesa, ale to o niskiej wydajnosci, ale lepszy rydz niz nic, zawsze mozna sterowniki doinstalować.
