Problem Z Dlink Dwl 520+
srobert
Witam!!!
Mam problem! Podczas kompilacji sterow przez polecenie ./Configure jest ok nie ma zadnych bledow jak pozniej wpisze polecenie make to wyskakuja mi bledy ze nie moze znalesc pliku ze blad w pliku linia ... itd. Prosze o Pomoc!!! Mam Fedore Core 2 i 3 i obydwu dzieje sie tosamo!!!! :lammer:
Abraaaakadabraa! Linuksie napraw się ;) A tak powaznie to dobrze ze chociaz temat mowi co nieco a nie np. "AAAA popsulo sie" ;)
srobert nie obraz sie ale moglbys sie bardziej postarac na przyszlosc opisujac swoj problem. Moze te dwie rzeczy Ci w przyszłosci pomoga -> TO $2 i TO.
I jak napisał The Structorr wklej tu co wywala make
to co pisze po wpisaniu polecenia ./Configure
Kernel version file: /lib/modules/2.6.5-1.358/build/include/linux/version.h
Kernel configuration file: /lib/modules/2.6.5-1.358/build/.config
Make damn sure these really match your currently running kernel!!
Kernel configuration found, performing sanity checks
All of the following items are required by the driver:
Loadable modules support is enabled.
Wireless LAN (non-hamradio) support is enabled.
Wireless extensions support is enabled.
The following is needed for PCMCIA/CardBus cards:
PCMCIA support is enabled.
CardBus support is enabled.
The following is needed for USB card support:
USB support is enabled.
The following is needed for PCI card support:
PCI support is enabled.
Kernel configuration satisfies the minimum requirements, continuing.
Wireless header file is WIRELESS_EXT version 16.
Running linux 2.6.5-1.358
Compile info: will choose to use code infrastructure for NEWER wireless extension interface version (>= 13)
Symmetric multiprocessing support (CONFIG_SMP) is disabled.
i po wpisaniu polecenia make
make -C src
make[1]: Entering directory `/popo/src'
if test -n ; then \
mkdir -p /popo/src/tmp; \
cp /lib/modules/2.6.5-1.358/build/.config /popo/src/tmp; \
fi
# use "make V=1" to see full compile execution
make -C /lib/modules/2.6.5-1.358/build SUBDIRS=/popo/src \
MODVERDIR=/popo/src WLAN_HOSTIF=WLAN_PCI modules
/lib/modules/2.6.5-1.358/build/scripts/gcc-version.sh: line 1: gcc: command not found
make[2]: Entering directory `/lib/modules/2.6.5-1.358/build'
CC [M] /popo/src/acx100.o
/bin/sh: line 1: gcc: command not found
make[3]: *** [/popo/src/acx100.o] B??d 127
make[2]: *** [/popo/src] BĹ‚Ä…d 2
make[2]: Leaving directory `/lib/modules/2.6.5-1.358/build'
make[1]: *** [modules] BĹ‚Ä…d 2
make[1]: Leaving directory `/popo/src'
make: *** [driver] BĹ‚Ä…d 2
Prosze o Pomoc!
Niezwiązane z Twoim problemem, ale zaktualizuj jądro/system.
Zainstaluj kompilator:
yum install gcc
(jak nie masz dostępu do netu, to zainstluj z płytki).
jak zaktualizowac jądro?
yum update kernel
http://80.55.221.90/~gajownik/linux/fedora...installsoftware
Jak nie masz dostępu do netu (karta sieciowa dalej Ci nie działa?), to ściągnij paczkę rpm stąd → http://mirrors.kernel.org/fedora/core/updates/3/i386/
W przypadku kernela nie aktualizuje się paczki, ale instaluje obok starego (tak na wszelki wypadek jakby nowy nie działał):
rpm -ivh kernel-numerki.rpm
A masz zainstalowane wireless tools?I jakie stery sciagles. Do instalacji tej karty bedzie ci potrzebne wireless tools , stery acx100pci i firmware.Napisz co masz przygotowane.A poza tym to update by sie przydalo. Popatrz tu na forum gdzies jest dokladny opis instalacji napisany przez Skazi-ego.W tym opisie jest wszystko jedyne co mozesz zmienic to sciagnij nowsze stery niz te ktore podaje skazi. Pozdrawiam.
Mam nas tepny problem po zainstalowaniu sterownikow ... konfiguracji pliku start_net mam nastepny problem gdy wpisuje ./Start_net to pisze mi cos takiego:
[root@localhost wlan]# ./start_net
Module not found or not readable.
Have you built it? This script expects it to be at ../src/acx_pci.[k]o, relative to the script's location. Bailing...
Pomocy
Zobacz czy dobry plik przeniosles do WLAN/module powinien tam byc acx_pci.ko i w pliku start_net musisz podac sciezke do niego w lini modules.Najlepiej przedstaw mi twoj plik start_net.To zobaczymy co jest grane.Robiles wszystko wedlug instrukcji Skazi-ego?
Postanowi³em napisaæ jak zainstalowa³em ten sterownik czyli acx100 na naszej ukochanej dystrybucji (MUSISZ MIEÆ ZAINSTALOWAN¥ PACZK WIRELESS-TOOLS).
Najpierw œci¹gamy wszystkie potrzebne pliki czyli sterownik i firmware z tych stron:
sterownik acx100
firmware
Nastepnie nale¿y rozpakowaæ paczke takim poleceniem:
tar -xvjf acx100-0.2.0pre8_plus_fixes_34.tar.bz2
Przechodzmy do przedchwileczk¹ rozpakowanego archiwum:
cd acx100-0.2.0pre8_plus_fixes_34
Wklepujemy teraz:
./Configure
jak nie wywali jakiegoœ b³êdu to:
make
cd src
A teraz musimy utworzyæ sobie katalogi:
mkdir /home/bartek/WLAN
mkdir /home/bartek/WLAN/module
mkdir /home/bartek/WLAN/firmware
u ciebie "bartek" zamieñ np. na swoje imiê lub coœ innego
Przenosimy nasz œwie¿o skompilowany modul do odpowiedniego katalogu:
mv acx_pci.ko /home/bartek/WLAN/module
Nastepnie wychodzmy do katalogu:
cd scripts
St¹d musimy przenieœæ pliki start i stop:
mv start_net /home/bartek/WLAN
mv stop_net /home/bartek/WLAN
Nastepnie trzeba sobie œciagn¹æ firmware i je rozpakowaæ:
tar -zxf acx100_firmware.tar.gz
Pliki MUSZA miec takie nazwy:
RADIO0D.BIN
RADIO11.BIN
RADIO15.BIN
WLANGEN.BIN
wszystkie musz¹ byæ du¿ymi literami jak nie s¹ to zrób ¿eby by³y
I teraz je przenosimy:
mv *.BIN /home/bartek/WLAN/firmware
Teraz przechodzmy do katalogu i edytujemy plik start_net:
cd /home/bartek/WLAN
nano start_net
Nasz plik powinien wygl¹daæ mniej wiêcej tak:
DEV=wlan0
IP=tutaj.twoj.adres.ip
NETMASK=255.255.255.0
GATEWAY=tukej.adres.ip.bramki
ESSID="tutaj_twoj_essid" lub zostaw "any"
RATE=11M # zostaw 11M, albo daj 1M
CHAN=1 # Tutaj Twoj kanal
MODE=Managed
DEBUG=0x00
KEY="s:twójklucz" # jesli nie uzywasz wep'a to zahaszuj to, to sa dane w ASCII
ALG=open # open == Open System, restricted == Shared Key
To tam sobie odpowiednio zmieñ
Teraz sobie odnajdujesz takie linijki:
MODULE_AT="${SCRIPT_AT}/src/acx100_pci.o"
FIRMWARE_AT="${SCRIPT_AT}/firmware"
I zmieniasz je na:
MODULE_AT="/home/bartek/WLAN/module/acx100_pci.ko"
FIRMWARE_AT="/home/bartek/WLAN/firmware"
Zapisujesz CTRL+O i wychodzisz CTRL+X.
Na sam koniec teraz tylko wpiszemy adresy serwerów DNS.
W tym celu musimy zedytowaæ plik resolv.conf:
nano /etc/resolv.conf
I wpisujesz tutaj swoje serwery DNS np.:
nameserver 192.168.0.1
nameserver 194.205.159.1
Zapisujesz plik i wychodzisz
Zrób sobie reboot'a dla pewnoœci
Wchodzimy do katalogu gdzie mamy plik start_net i odpalamy go tak¹ komend¹:
./start_net
Jesli dobrze sie za³adowa³o, to sprawdŸ czy coœ dochodzi:
ping -c 10 192.168.0.1
Zamiast 192.168.0.1 wpisz swoj¹ bramkê
To jest sposob instalacji dla osób, ktore posiadaja w³asny adres IP, jesli
biega o DHCP to trzeba tylko ma³e poprawki waln¹æ w skrypcie
Net’a zawsze bêdziesz musia³ odpala³ poprzez ./start_net, ale jak chcesz, to mo¿esz zawartoœæ skryptu start_net przekopiowaæ do pliku rc.local w katalogu /etc/rc.d
dziêki czemu sterownik bêdzie ³adowany podczas startu systemu i nie bêdzie trzeba wpisywaæ zawsze ./start_net, niestety nie wiem jak zrobiæ ¿eby podczas wy³¹czania systemu sterownik siê wy³¹cza³ ale mo¿e ktoœ wymyœli jak to siê robi.
To by by³o na tyle testowa³em sterownik na j¹drze 2.6.6, 2.6.8-1 i 2.6.9 na wszystkich dzia³a bez problemów. Jeœli macie jakieœ pytania lub czegoœ nie rozumiecie to piszcie.
ps. Moja karta to Dlink Dwl-520+ ale z tego co wiem to sterownik acx100 obs³uguje wiêcej kart które s¹ oparte na chipsecie Texas Instruments.
To jest opis instalacji skaziego. :D i tak przy okazji sory za te krzaczki ale musze zrobic czcionki i kodowanie z windy bo polskich znakow nie ma.
Wiesz co przedstaw mi twoj plik start_net bo sie domyslam co to moze byc ale nie jestem pewien.Nie chcialbym cie w blad wprowadzic.
Przypatrz sie dokladnie czy czasem jakas linijka sie na dol nie przesunela np jak wpisujesz swoj kanal to linijka przechodzi do nastepnej i juz jest blad wtedy.Najlepiej mi pokarz plik.Aha i jeszcze to
"src" nie sciezka do modulu acx_pci.ko jak robiles wszystko wedlug instrukcji to sciezke masz taka /home/twoj katalog/WLAN/module
Ja mam tak
/home/lukasz/WLAN/module
nie podalem swoichdanych czyli IP, MASKI I BRAMKi.
Jak Cos jest nie tak to prosze napisz.
O to zawartosc pliku start_net:
#!/bin/bash
# start_net script #
# acx100 project #
# acx100.sourceforge.net #
# edited by arnie <[email protected]> #
# with modifications by craig #
# summary at end of file #
# Please edit below
# syntax is: VARIABLENAME=VALUE, with _no_ spaces in between
# make sure to _preserve_ any double-quotes (")
# text beginning with the comment delimiter (#) is ignored
# make sure to _preserve_ at least one space before any
# comment delimiters (#) that do not begin a line
# "uncommenting" a line means to remove it's leading "#" character
ESSID="network_down" # THIS IS CASE SeNsItIvE!! any == associate to any ESSID
# Default rate configured as 11Mbps to not cause speed problems (while
# using auto rate) or connection problems (while not using auto rate)
# with non-22Mbps hardware...
RATE=11M
AUTORATE=1 # only disable auto rate if you know what you're doing...
CHAN=10 # it's useful to try to stick to channels 1, 6 or 11 only, since these don't overlap with other channels
#SHORTPREAMBLE=1 # set a value of 1 in order to force "Short Preamble" (incompatible with very old WLAN hardware!) instead of peer autodetect
#TXPOWER=20 # 0..20 (dBm) (18dBm is firmware default) overly large setting might perhaps destroy your radio eventually!
MODE=Managed # Managed for infrastructure, Ad-hoc for peer-to-peer, or Auto to auto-select depending on environment
DEBUG=0xb # 0xffff for maximum debug info, 0 for none
# WEP Key(s)
# ascii keys (passphrase) should look like this: KEY="s:asciikey"
# hex keys should look like this: KEY="4378c2f43a"
# most wep users will want to use this line
#KEY=""
# [ *** NOTE ***: WEP still doesn't work with acx111 cards yet! ]
# alternatively, you can uncomment and use these lines to
# set all 4 possible WEP keys
#KEY1="1234567890" #WEP64
#KEY2="1234567890"
#KEY3="1234567890"
#KEY4="1234567890"
# you must select which of the 4 keys above to use here:
#KEY="[1]" # for KEY1, "[2]" for KEY2, etc
#IP address
USE_DHCP=0 # set to 1 for auto configuration instead of fixed IP setting
IP=..........# set this if you did not set USE_DHCP=1
NETMASK=......... # set this if you did not set USE_DHCP=1
GATEWAY=.......... # set this if you did not set USE_DHCP=1
LED_OFF=1 # set to 1 to turn off the power LED to save power
MTU_576=0 # set to 1 if you have buffer management problems
# DO NOT EDIT BELOW THIS LINE
if test "$UID" != "0"; then echo "You are not root. To insert the module into your kernel, you need to be root. Enter su and try again. Bailing..."; exit 1; fi
SYNC=`which sync`
INSMOD=`which insmod`
IFCONF=`which ifconfig`
IWCONF=`which iwconfig`
IWPRIV=`which iwpriv`
ROUTE=`which route`
SCRIPT_AT=`dirname $0`
# while we check for all 3, we run them in this
# "preferred" order: dhcpcd, pump, dhclient
# so if more than one exists it's ok
which dhcpcd &> /dev/null
if [ $? -eq 0 ]; then DHCPCD=`which dhcpcd`; fi
which pump &> /dev/null
if [ $? -eq 0 ]; then PUMP=`which pump`; fi
which dhclient &> /dev/null
if [ $? -eq 0 ]; then DHCLIENT=`which dhclient`; fi
if test -z "$SYNC"; then echo "sync not found. Go get a sane Linux system. Bailing..."; exit 1; fi
if test -z "$INSMOD"; then echo "insmod not found. Go get a sane Linux system. Bailing..."; exit 1; fi
if test -z "$IFCONF"; then echo "ifconfig not found. I can insert the module for you, but you won't be able to configure your interface."; CONTINUE=ASK; fi
if test -z "$IWCONF"; then echo "iwconfig not found. Make sure it is installed. The interface might work without, though."; CONTINUE=ASK; fi
if test -n "$CONTINUE"; then echo -n "Problems encountered. Do you want to continue? [n] "; read ANSWER
case $ANSWER in ( y | Y | Yes | YES | yes | j | J | ja | Ja | JA ) ;;
( * ) exit 1 ;;
esac
fi
case "`uname -r`" in
2.4*)
MODULE_AT="${/home/wlan/module/acx_pci.ko"
esac
if test ! -r "$MODULE_AT"; then echo "Module not found or not readable.
Have you built it? This script expects it to be at ../src/acx_pci.[k]o, relative to the script's location. Bailing..."; exit 1; fi
# check whether any file name of the required main firmware file is
# available in the acx100/firmware or global firmware directory
# FIRMWARE_AT has to be given as an absolute path!!
for FIRMWARE_AT in "/home/wlan/firmware"; do
for FW_FILE in WLANGEN.BIN TIACX111.BIN FwRad16.bin FW1130.BIN; do
if test -r "$FIRMWARE_AT/$FW_FILE"; then
#echo A firmware file has been found at "$FIRMWARE_AT/$FW_FILE"
FW_FOUND=1
break 2
fi
done
done
if test "$FW_FOUND" != "1"; then
echo "Firmware not found or not readable. Have you placed it in the firmware directory or run make extract_firmware once? This script expects it to be either at ../firmware/WLANGEN.BIN (or ../firmware/TIACX111.BIN for the ACX111 chip), relative to the script's location, OR have you placed it in the default directory:/usr/share/acx?. Bailing...";
exit 1;
fi
if test $AUTORATE != "1"; then
if test "$RATE" != "11M"; then echo "Transfer rate is not set to 11
Mbps, but $RATE (and not using auto rate either). If something doesn't work, try 11 Mbps or auto rate."; fi
fi
test "$AUTORATE" = "1" && AUTO=auto || AUTO=
# for better debugging
# set -x
#echo 8 > /proc/sys/kernel/printk
# just in case ;)
$SYNC
sleep 1
DEV=wlan0 # this may become wlan1, wlan2, etc depending on if any other wlanX devices are found
if test -n "`lsmod | grep acx_pci`"; then ${SCRIPT_AT}/stop_net;fi
# now that the interface is "down", let's also check for and remove
# those *really* old modules that might be supplied with some distributions
lsmod | grep acx100_pci &> /dev/null
if test "$?" = "0"; then
rmmod acx100_pci;
echo "NOTICE: Found a very old version of the driver loaded (acx100_pci), removing."
# we could also add the old module's name to the blacklist, though this
# only benefits hotplug devices and might be considered invasive
# echo acx100_pci >> /etc/hotplug/blacklist
fi
# before inserting the module, let's check for the presence of existing wlan devices
# and if necessary, adjust our $DEV variable to be wlan1, wlan2, etc.
# these could be other wireless drivers' devs, or the device created by acx_usb
MAX_WLANS=9 # failsafe break counter
while true
do
# at this point $DEV is always "wlan0"
$IFCONF $DEV &> /dev/null
echo -n "$DEV exists, "
DIGIT=`echo $DEV | cut -d 'n' -f 2`
DIGIT=`expr $DIGIT + 1`
DEV="wlan${DIGIT}"
echo -n "trying $DEV..."
else
echo "using $DEV."
break
fi
# failsafe break
if test $MAX_WLANS -eq 0; then break;fi
MAX_WLANS=`expr $MAX_WLANS - 1`
done
$INSMOD $MODULE_AT debug=$DEBUG firmware_dir=$FIRMWARE_AT
if test "$?" = "0"; then echo "Module successfully inserted."; else echo "Error while inserting module! Bailing..."; exit 1; fi
# before we get too involved in trying to setup $DEV, let's verify that it exists
if test "$?" = "0"; then # $DEV exists
if test -n "$IWCONF"; then
if test -n "$RATE"; then
echo Setting rate to $RATE $AUTO.
$IWCONF $DEV rate $RATE $AUTO
test "$?" != "0" && echo Failed.
fi
if test -n "$CHAN"; then
echo Setting channel $CHAN.
$IWCONF $DEV channel $CHAN
fi
if test -n "$SHORTPREAMBLE"; then
echo Setting short preamble to $SHORTPREAMBLE.
$IWPRIV $DEV SetSPreamble $SHORTPREAMBLE
sleep 1
fi
if test -n "$TXPOWER"; then
echo Setting Tx power level to $TXPOWER dBm.
$IWCONF $DEV txpower $TXPOWER
sleep 1
fi
echo Going to try to join or setup ESSID $ESSID.
$IWCONF $DEV essid "$ESSID"
if test -n "$MODE"; then
echo Setting mode to $MODE.
$IWCONF $DEV mode $MODE
fi
if test -n "$KEY1"; then
echo Setting key 1 to $KEY1, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY1" [1]
fi
if test -n "$KEY2"; then
echo Setting key 2 to $KEY2, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY2" [2]
fi
if test -n "$KEY3"; then
echo Setting key 3 to $KEY3, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY3" [3]
fi
if test -n "$KEY4"; then
echo Setting key 4 to $KEY4, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY4" [4]
fi
# this is now placed after the "KEY%D" stuff
# to support the "KEY=[1]" option
if test -n "$KEY"; then
echo Setting key to $KEY, algorithm $ALG.
$IWCONF $DEV key "$KEY" $ALG
fi
fi # end "if found(iwconfig)"
# for notebook use - a power LED is sooo useless anyway ;-))
if test "$LED_OFF" -eq 1; then
test -n "$IWPRIV" && "$IWPRIV" $DEV SetLEDPower 0
echo Setting power LED to off.
fi
# It shouldn't hurt to bring the device up, and dhcp seems to like it that way
$IFCONF $DEV up
sleep 1
# if they want dhcp or they've set to managed mode, then we
# take up to 10 seconds to wait for something to show up
# in iwconfig besides zeros, we don't want to give the user
# the wrong impression re: success/failure and mainly we don't
# want to bother with a dhcp attempt without association
# we could also use /proc/driver/acx_$DEV instead ??
# check MODE for some form of the word "managed", case-insensitive
echo $MODE | grep -ic managed &> /dev/null
if test "$?" = "0" -o $USE_DHCP -eq 1; then # begin test for association
WAIT_ASSOC=10
echo -n "Waiting for association..."
while true
do
echo -n "$WAIT_ASSOC "
if test "`$IWCONF $DEV | grep -c 00:00:00:00:00:00`" = "0"; then
echo "OK."
# ok, have association, now verify that the card associated with
# the desired AP, it could easily have found a stray linksys instead ;^}
if test -n "$ESSID"; then
echo "$ESSID" | grep -ic any &> /dev/null # don't bother checking "essid=any"
if test "$?" = "0" -a "`$IWCONF $DEV | grep -c $ESSID`" = "0"; then
echo "NOTICE: $DEV associated, but NOT with $ESSID!"
fi
fi
break
fi
WAIT_ASSOC=`expr $WAIT_ASSOC - 1`
if test "$WAIT_ASSOC" = "0"; then
echo FAILED.
# if they wanted dhcp, tell them the bad news
if test $USE_DHCP -eq 1; then
echo "Error: $DEV failed to associate, can't use DHCP for IP address."
USE_DHCP=0;
fi
break
fi
# we *could* issue an iwconfig here at the end of each loop:
# $IWCONF $DEV essid $ESSID
# I'm not sure if it would help or hinder...it isn't necessary w/my hardware
sleep 1 # give it a second
done
fi # end test for association, if mode=managed or USE_DHCP=1
# now we fetch an IP address from DHCP
# first, try dhcpcd:
if test -n "$DHCPCD"; then
echo -n "Attempting to use $DHCPCD for DHCP, this may take a moment..."
rm -f /etc/dhcpc/dhcpcd-$DEV.pid > /dev/null
$DHCPCD -d $DEV -t 5 &> /dev/null
echo "OK."
echo "Interface has been set up successfully.";
else echo "FAILED"
fi
# no dhcpcd was found, next we try pump:
elif test -n "$PUMP"; then
echo -n "Attempting to use $PUMP for DHCP, this may take a moment..."
$PUMP -i $DEV &> /dev/null
echo "OK."
else echo "FAILED"
fi
# no dhcpcd or pump was found, finally we try dhclient;
elif test -n "$DHCLIENT"; then
echo -n "Attempting to use $DHCLIENT for DHCP, this may take a moment..."
rm -f /var/run/dhclient.pid
$DHCLIENT $DEV &> /dev/null
echo "OK."
else echo "FAILED"
fi
else # dhcpcd, pump, and dhclient not found, inform user and bail
echo "ERROR: USE_DHCP=1 , but no dhcp clients could be found"
echo "Bailing..."
exit 1;
fi #end check for usable dhcp client
else # wants manual config
# Hehe, this can be done after iwconfigs now :)
$IFCONF $DEV $IP netmask $NETMASK
if test "$?" != "0"; then
echo "Error in \"$IFCONF $DEV $IP netmask $NETMASK\". Bailing..."; exit 1;
else
test -n "$GATEWAY" && $ROUTE add default gw $GATEWAY $DEV
fi
fi # end if USE_DHCP=1
# ugly workaround for buffer management problems
if test "$MTU_576" -eq 1; then
echo "Setting mtu down to 576. NOTE that e.g. IPv6 would need >= 1280, so make sure you're doing the right thing here!"
test -n "$IFCONF" && "$IFCONF" $DEV mtu 576
if test "$?" != "0"; then echo "Error in \"$IFCONF $DEV mtu 576\". Bailing..."; exit 1; fi
fi
else # $DEV is not found by ifconfig
echo "Error: Failed to create device: $DEV...bailing."
exit 1;
fi # end test for $DEV exists
# just in case ;)
$SYNC
# summary of craig's changes to pf33's start_net:
# added SET_LED and MTU_576 vars, moved DEV below the do-not-edit line
# changed KEY0-KEY3 vars to KEY1-KEY4 to match iwconfig's scheme
# added a line for selecting a numbered key eg: "KEY=[1]"
# moved setting wep key to last in the order for above to work
# added attempt to automagically find/use a dhcp client
# added checking for firmware in /usr/share/acx before bailing
# check for and unload the old acx100_pci module if present
# don't assume $DEV is going to always be wlan0 (needs more work)
# don't assume that $DEV exists, even after a successful module load
# if MODE=managed || USE_DHCP=1, wait for association
# upon assoc, test for correct SSID if one was specified
# added $DEV to route add default gw command
# end of file
Wtam!!
Jeżeli nie używasz DHCP musisz sobie nadać IP :
ifconfig wlan0 IP--hehe
Ja tam polecam ndiswrapper !!
Jutor Ci moge podać szczgóły a jeli się upierasz przy acx100, to znajdź w google, czy twoja karta przypadkiem nie ma acx111, bo moja miała i ma :):) DWL-G520+ :):) I nawet WPA dział (ndiswrapper )
Więc jutro Ci przyśle jakieś bliższe info, bom dzisiaj nie w stanie :):)
Męczyłem się z tą kartą 2 tygodnie !!
Ale ładuje się szybciej niż w windzie !! TO JEST LINUCH!!!!! -- ni po polsku nie !! :):)
POZDRO!!
Ale on ma dwl520+ stary wiec dobry ster ma. A po 2 podales sciezke do module a sprawdz w home czy czasem WLAN nie jest duzymi literami.Bo wedlug opisu to tak jest. Po 3
Tutaj gdzie msz shortpreamble jeden wyraz zjechal do lini na dol a musi byc wszystko w jednej.Mi od tego tez blad wyskakiwal.
Nastepnie debug ustawiasz na 0x00
I tutaj
#KEY=""
w lini z KEY miedzy cudzyslowiem podajesz swoj wep
i najlepiej autorate zmien sobie zamiast 1 na 0
i jezeli czytales opis to firmware(katalog) masz we WLAN czyli sciezka jest u mnie taka "/home/lukasz/WLAN/firmware" i ty na pewno tez masz w swoim katalogu czyli imie pewnie czyli cos takiego /home/twoje imie/WLAN/firmware
aha i jeszcze jedno przy sciezce np do module nie ma tak
tylko tak
"/home.....
nie motaj zadnych nawiasow ani nic poprostu je wymarz. Zadnych ${ tylko od razu sciezka
Jak wszystko poustawiasz i bedzie dobrze to daj znac a jezeli nie to napisz jeszcze co wyskakuje.
Sporo tam bledow radze ci czytac uwaznie ten opis bo tutaj kazda literka wazna.Tak jak mowi pan Gryhid to linux nie winda.
Pozdrawiam :)
