jaro33 Napisano Grudzień 29, 2005 Zgłoszenie Share Napisano Grudzień 29, 2005 -------------------------------- no j.angielski ------------------------------ 1) pobrałem sterowniki tej strony http://www.ralink.com.tw/supp-1.htm RT2500-Linux-STA-1.4.1.0.tar RT2500-Linux-STA-1.4.2.0.tar .. RT2500-Linux-STA-1.4.6.2.tar nastepnie próbowałem je zainstalować (po rozpakowaniu w /root/sterowniki) zgodnie z instrukcją : root@localhost Utility]# more How_To_Compile.txt How to compile ---------------------- This Configuration Utility Application was developed by Qt/X11 Free Edition. You can install the Qt/X11 Free Edition development when install the Linux OS by selecting the Qt/X11 development package or you can find it on Trolltech's website. http://www.trolltech.com/ ftp://ftp.trolltech.com/qt/source/qt-x11-...ee-3.2.1.tar.gz After install the package then follow the steps. 1.) qmake -o Makefile raconfig2500.pro 2.) make [root@localhost Utility]# qmake -o Makefile raconfig2500.pro -------------------------------------------------------------------------- a teraz same błędy ----------------------------------------------------------------------------- [root@localhost Module]# make cc -DRT2500_DBG -D__KERNEL__ -I/usr/src/kernels/2.6.11-1.1369_FC4-i686/include -O2 -fomit-frame-pointer -fno-strict-aliasing -fno-common -pipe -mpreferred-stack-boundary=2 -march=i686 -DMODULE -DMODVERSIONS -include /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/modversions.h -Wall -Wstrict-prototypes -Wno-trigraphs -c -o rtmp_main.o rtmp_main.c cc1: error: /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/modversions.h: Nie ma takiego pliku ani katalogu In file included from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/irq.h:21, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/asm/hardirq.h:6, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/hardirq.h:6, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/interrupt.h:11, from rt_config.h:62, from rtmp_main.c:38: /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/asm/irq.h:16:25: error: irq_vectors.h: Nie ma takiego pliku ani katalogu In file included from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/asm/hardirq.h:6, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/hardirq.h:6, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/interrupt.h:11, from rt_config.h:62, from rtmp_main.c:38: /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/irq.h:72: error: ‘NR_IRQS’ undeclared here (not in a function) In file included from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/irq.h:74, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/asm/hardirq.h:6, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/hardirq.h:6, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/interrupt.h:11, from rt_config.h:62, from rtmp_main.c:38: /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/asm/hw_irq.h:28: error: ‘NR_IRQ_VECTORS’ undeclared here (not in a function) In file included from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/if_ether.h:107, from /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/netdevice.h:29, from rt_config.h:64, from rtmp_main.c:38: /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/skbuff.h: In function ‘skb_add_data’: /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/linux/skbuff.h:1067: warning: pointer targets in passing argument 1 of ‘csum_and_copy_from_user’ differ in signedness In file included from mlme.h:39, from rtmp.h:41, from rt_config.h:138, from rtmp_main.c:38: oid.h: At top level: oid.h:276: warning: ‘packed’ attribute ignored oid.h:277: warning: ‘packed’ attribute ignored rtmp_main.c: In function ‘RT2500_probe’: rtmp_main.c:121: error: ‘struct pci_dev’ has no member named ‘slot_name’ rtmp_main.c:146: error: ‘struct pci_dev’ has no member named ‘slot_name’ rtmp_main.c:163: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast rtmp_main.c:164: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast rtmp_main.c: In function ‘RTMPIsr’: rtmp_main.c:465: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast rtmp_main.c:466: warning: passing argument 2 of ‘writel’ makes pointer from integer without a cast make: *** [rtmp_main.o] Błąd 1 -------------------------------------------------------------------------------------- nie znam angielskieg więc nie wiemco odemnie chce proszę o pomoc ------------------------------------------------------------------------------------- nawet stworzyłem sobie potem "kernel source " ale czy mi się przyda ? i co znim zrobić rpmbuild -bp --target=noarch /usr/src/..../SPECS/kernel-2.6.spec zrobił 190MB danych ????? 2) a teraz "rpm" jakoś dziwnie działa : jak go pytam #rpm -q qt-3.3.......4.src to mówi ze go nie ma a jak dam: #rpm -Uhv qt-3.3.......4.src to mowi ze nie trzeba ?// Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Faust_ Napisano Grudzień 30, 2005 Zgłoszenie Share Napisano Grudzień 30, 2005 Po pierwsze sterowniki, które wybrałeś nie są że tak to ujmę więc odrodzam. Polecam starowniki z http://rt2x00.sf.net. Tu masz bezprośredniego linka do sterownika. Po drugie co chcesz zaistalować? Sterownik czy Utilitys? Jeśli sterownik, to olej katalog Utilitys, bo tam jest program do nadzorowania sieci. Żeby zainstalować sterownik wchodzisz do katalogu Module i odpalasz na rootie make && make install . PO tym modprobe ra0 i reszte konfigurujesz w system-config-network . Jeśli chodzi o Utilitys, olej bo wymagają ręcznie skompilowanej biblioteki qt, a to zajmuje dość dużo czasu. Jest wiele innych dobrych programów np. Gwifimanager Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Grudzień 30, 2005 Zgłoszenie Share Napisano Grudzień 30, 2005 2) a teraz "rpm" jakoś dziwnie działa : jak go pytam #rpm -q qt-3.3.......4.src to mówi ze go (_niema_ → nie ma) ORT a jak dam: #rpm -Uhv qt-3.3.......4.src to mowi ze nie trzeba ?// Paczek src.rpm się tak nie instaluje. NAjpierw należy je przebudować poprzez rpmbuild --rebuild Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jaro33 Napisano Grudzień 30, 2005 Autor Zgłoszenie Share Napisano Grudzień 30, 2005 dobre strony ze sterownikami Ralink http://rt2x00.serialmonkey.com/wiki/index.php/Downloads http://rt2x00.serialmonkey.com/wiki/index....x.php/Downloads Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
