Fc5 + Nvidia
uosiu
[root@localhost yum.repos.d]# yum install kmod-nvidia
Setting up Install Process
Setting up repositories
livna        [1/4]
updates-released                                                     [2/4]
core        [3/4]
extras                                                               [4/4]
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package kmod-nvidia.i686 0:1.0.8178-6.2.6.16_1.2080_FC5 set to be updated
--> Running transaction check
--> Processing Dependency: nvidia-kmod-common = 1.0.8178 for package: kmod-nvidia
--> Restarting Dependency Resolution with new changes.
---> Package xorg-x11-drv-nvidia.i386 0:1.0.8178-7.lvn5 set to be updated
Dependencies Resolved
Package                 Arch       Version          Repository        Size
Installing:
kmod-nvidia             i686       1.0.8178-6.2.6.16_1.2080_FC5  livna             1.4 M
Installing for dependencies:
xorg-x11-drv-nvidia     i386       1.0.8178-7.lvn5  livna             3.9 M
Transaction Summary
Install      2 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 5.3 M
Is this ok [y/N]: y
Downloading Packages:
(1/2): xorg-x11-drv-nvidi 100% |=========================| 3.9 MB    01:05
(2/2): kmod-nvidia-1.0.81 100% |=========================| 1.4 MB    00:22
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
 Installing: kmod-nvidia                  ######################### [1/2]
 Installing: xorg-x11-drv-nvidia          ######################### [2/2]
FATAL: Module nvidia not found.
Installed: kmod-nvidia.i686 0:1.0.8178-6.2.6.16_1.2080_FC5
Dependency Installed: xorg-x11-drv-nvidia.i386 0:1.0.8178-7.lvn5
Complete!
dziwne- niby wszystko,ok zadnych bledow nie truje a tu taki FATAL... nie wiecie nic o tym?
na razie chodze na świeżym jajku, co na plycie dali smile.gif update z fc4 robilem z plyty CD, wczesniej dalem
yum remove *nvidia*
Jeżeli denerwuje Cię to logo Nvidii to można je wywalić przez edycję /etc/X11/xorg.conf.
Znajdź fragment odpowiadający za kartę graficzną i dodaj linię pomiędzy >>> i <<<
Section "Device"
Identifier  "Videocard0"
Driver      "nvidia"
>>>Option      "NoLogo" "true"<<<
VendorName  "Videocard vendor"
BoardName   "nVidia Corporation
EndSection
