Nvidia + Fc5 = Brak Akceleracji
scooter
Dziękuję serdecznie :) Nie zapamiętałem tego polecenia i jak głupi wchodziłem na http://pbone.net i wyszukiwałem...
jak powinien wyglądać ten wpis w przypadku karty PCI-ex ? Wpisałem wszystko co podaliście powyżej, odblokowałem selinuxa i nie mam akceleracji :(
Po zainstalowaniu sterów ze strony nvidii mam :
[pinio@dolsat ~]$ glxgears
4650 frames in 5.0 seconds = 929.913 FPS
5716 frames in 5.0 seconds = 1143.151 FPS
5716 frames in 5.0 seconds = 1142.906 FPS
5066 frames in 5.0 seconds = 1012.071 FPS
6017 frames in 5.0 seconds = 1203.352 FPS
5735 frames in 5.0 seconds = 1146.823 FPS
5358 frames in 5.0 seconds = 1071.508 FPS
X connection to :0.0 broken (explicit kill or server shutdown).
[pinio@dolsat ~]$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
GLX_ARB_multisample, GLX_NV_float_buffer, GLX_ARB_fbconfig_float
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float
GLX version: 1.3
GLX extensions:
GLX_ARB_multisample, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 6100/PCI/SSE2
OpenGL version string: 2.0.2 NVIDIA 87.62
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_float,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_Cg_shader, GL_EXT_depth_bounds_test, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_clear_tag, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
GL_EXT_texture3D, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_sRGB, GL_EXT_timer_query,
GL_EXT_vertex_array, GL_HP_occlusion_test, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KTX_buffer_region, GL_NV_blend_square,
GL_NV_copy_depth_to_color, GL_NV_depth_clamp, GL_NV_fence,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
GL_NV_fragment_program_option, GL_NV_fragment_program2, GL_NV_half_float,
GL_NV_light_max_exponent, GL_NV_multisample_filter_hint,
GL_NV_occlusion_query, GL_NV_packed_depth_stencil, GL_NV_pixel_data_range,
GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_register_combiners,
GL_NV_register_combiners2, GL_NV_texgen_reflection,
GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
GL_NV_texture_expand_normal, GL_NV_texture_rectangle,
GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
GL_NV_vertex_array_range, GL_NV_vertex_array_range2, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3,
GL_NVX_conditional_render, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x22 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x23 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x24 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x28 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x29 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x2a 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2b 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2c 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2d 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2e 24 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x2f 24 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x30 24 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x31 24 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x32 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x33 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x34 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x35 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x36 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x37 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x38 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x39 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x3a 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x3b 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x3c 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x3d 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x3e 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x3f 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x40 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x41 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x42 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x43 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x44 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x45 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x46 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x47 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x48 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x49 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x4a 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x4b 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x4c 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x4d 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x4e 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x4f 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x50 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x51 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x52 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x53 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x54 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x55 24 dc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x56 24 dc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x57 24 dc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x58 24 dc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x59 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x5a 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x5b 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x5c 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x5d 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  2 1 Ncon
0x5e 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  2 1 Ncon
0x5f 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  4 1 Ncon
0x60 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  4 1 Ncon
0x61 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x62 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x63 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x64 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x65 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  2 1 Ncon
0x66 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  2 1 Ncon
0x67 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  4 1 Ncon
0x68 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  4 1 Ncon
0x69 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x6a 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x6b 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x6c 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
0x6d 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  2 1 Ncon
0x6e 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  2 1 Ncon
0x6f 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  4 1 Ncon
0x70 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  4 1 Ncon
Kurde ludzie. Na forum jest coś takiego jak codebox...
Edytowane przez lszk
