Masa Warningów Przy Rpmbuild
szybki_gumis
witam.
chce skompilować nowe jądro i po wydaniu komendy:
rpmbuild -bp --target=i686 kernel-2.6.spec
wywala dziesiątki warningów (dodam, że finalnie wszystko się robi i jądro da się skompilować)
pytanko do bardziej obeznanych smile.gif czy ta sytuacja jest normalna i nie ma się czy,m martwić, czy coś robie nie tak.
oyto wycinek tego co wyala, bo w całości to pare ekranów.
.config:3035:warning: trying to reassign symbol CRYPTO_DEV_PADLOCK
+ echo '# i386'
+ cat .config
+ for i in '*.config'
+ mv kernel-2.6.16-i686.config .config
++ head -1 .config
++ cut -b 3-
+ Arch=i386
+ make ARCH=i386 nonint_oldconfig
.config:2569:warning: trying to reassign symbol NI5010
.config:2572:warning: trying to reassign symbol AT1700
.config:2735:warning: trying to reassign symbol SONYPI
.config:2749:warning: trying to assign nonexistent symbol X86_UP_APIC_DEFAULT_OFF
.config:2758:warning: trying to reassign symbol SYNCLINK_CS
.config:2759:warning: trying to reassign symbol SYNCLINK
.config:2760:warning: trying to reassign symbol SYNCLINKMP
.config:2761:warning: trying to reassign symbol HP100
.config:2762:warning: trying to reassign symbol PCMCIA_FDOMAIN
.config:2763:warning: trying to reassign symbol SCSI_FUTURE_DOMAIN
.config:2764:warning: trying to reassign symbol SCSI_ADVANSYS
.config:2765:warning: trying to reassign symbol CAPI_EICON
.config:2766:warning: trying to reassign symbol I2O
.config:2837:warning: trying to reassign symbol NVRAM
.config:2838:warning: trying to reassign symbol IBM_ASM
.config:2865:warning: trying to reassign symbol HOTPLUG_PCI_PCIE
.config:2866:warning: trying to reassign symbol HOTPLUG_PCI_PCIE_POLL_EVENT_MODE
.config:2871:warning: trying to reassign symbol IEEE80211
.config:2872:warning: trying to reassign symbol IEEE80211_DEBUG
.config:2873:warning: trying to reassign symbol IEEE80211_CRYPT_CCMP
.config:2874:warning: trying to reassign symbol IEEE80211_CRYPT_TKIP
.config:2875:warning: trying to reassign symbol IPW2100
.config:2877:warning: trying to reassign symbol IPW2200
.config:2879:warning: trying to reassign symbol BLK_DEV_AMD74XX
.config:2880:warning: trying to reassign symbol I2C_ALI1535
.config:2881:warning: trying to reassign symbol I2C_ALI15X3
.config:2882:warning: trying to reassign symbol I2C_ALI1563
.config:2883:warning: trying to reassign symbol I2C_AMD756
.config:2884:warning: trying to reassign symbol I2C_AMD756_S4882
.config:2885:warning: trying to reassign symbol I2C_AMD8111
.config:2886:warning: trying to reassign symbol I2C_I801
.config:2887:warning: trying to reassign symbol I2C_I810
.config:2889:warning: trying to reassign symbol I2C_NFORCE2
.config:2890:warning: trying to reassign symbol I2C_PIIX4
.config:2891:warning: trying to reassign symbol I2C_PROSAVAGE
.config:2892:warning: trying to reassign symbol I2C_SAVAGE4
.config:2893:warning: trying to reassign symbol SCx200_ACB
.config:2894:warning: trying to reassign symbol I2C_SIS5595
.config:2895:warning: trying to reassign symbol I2C_SIS630
.config:2896:warning: trying to reassign symbol I2C_SIS96X
.config:2897:warning: trying to reassign symbol I2C_VIA
.config:2898:warning: trying to reassign symbol I2C_VIAPRO
.config:2899:warning: trying to reassign symbol I2C_ISA
.config:2900:warning: trying to reassign symbol I2C_VOODOO3
.config:2915:warning: trying to reassign symbol M686
.config:2915:warning: M686 creates inconsistent choice state
.config:2916:warning: trying to reassign symbol SMP
.config:2917:warning: trying to reassign symbol NOHIGHMEM
.config:2918:warning: trying to reassign symbol HIGHMEM4G
.config:2918:warning: HIGHMEM4G creates inconsistent choice state
.config:2919:warning: trying to reassign symbol HIGHMEM64G
+ echo '# i386'
+ cat .config
+ perl -p -i -e 's/^SUBLEVEL.*/SUBLEVEL = 16/' Makefile
+ perl -p -i -e 's/^EXTRAVERSION.*/EXTRAVERSION = -prep/' Makefile
+ find . -name '*.orig' -o -name '*~' -exec rm -f '{}' ';'
+ exit 0
mak toś jakiś pomysł ?
Takie coś to raczej mało groźne, po prostu ma jakieś wpisy w konfiguracji, które nie istnieją.
To znaczy że pewnie coś prędzej kompilował ?
I trochę bezpieczeństwo mógł rozwalić (ale nie musiał)
instalacja z *rpm ma swoją wyższość ponieważ wszystkie działania rejestruje system, a biblioteki z kompilacji nie ?
Poprawcie mnie jeżeli się mylę.
Narka
Nic wcześniej nie kompilowałem, system mam postawiony z płytek i wykonany yum update. Nie wykonywałem żadnych zmian w konfiguracji.
Kernela zassałem ze stron fedory wersje 2.6.16.1-2080 o ile dobrze pamiętam, no i postępowałem według podanych mi na forum wskzówek
czyli:
# cd /del
# wget http://download.fedora.redhat.com/pub/fedo...xxx_FC5.src.rpm
# mkdir -p /usr/src/redhat/SPECS
# rpm -ivh kernel-2.6.xx-x.xxxx_FC5
# yum install rpm-build redhat-rpm-config
# cd /usr/src/redhat/SPECS
# rpmbuild -bp --target=i686 kernel-2.6.spec
# cp -R /usr/src/redhat/BUILD/kernel-2.6.xx-x/linux-2.6.xx /usr/src
# cd usr/src
# ln -s linux-2.6.xx/ linux
# cd /usr/src/linux
# make xconfig
no i właśnie cały czas mnie zastanawia czy to normalne co się dzieje, czy o czymś nie wiem (co jest bardziej prawdopodobne smile.gif )
Gumiś, proponuję jednak użyć już skompilowanego jądra, bo z tego co widzę, config pluje się, że dane wartości zostału już zadeklarowane. Ewentualnie zrebootuj i wtedy skonfiguruj.
Jeśli jesteś jednak zainteresowany paczkami, znajdziesz je na:
/etc/yum.repos.d/kernels.repo
[davej]
name=kernels
baseurl=http://people.redhat.com/davej/kernels/Fedora/FC$releasever/RPMS.kernel/
enabled=0
gpgcheck=0
yum update kernel --enablerepo=kernels
