uosiu Napisano Kwiecień 7, 2006 Zgłoszenie Share Napisano Kwiecień 7, 2006 [uosiu@localhost captive]$ ppracer PPRacer 0.3.1 -- http://racer.planetpenguin.de (c) 2004-2005 The PPRacer team (c) 1999-2001 Jasmin F. Patry<[email protected]> PPRacer comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to redistribute it under certain conditions. See http://www.gnu.org/copyleft/gpl.html for details. Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". *** ppracer error: Couldn't initialize video: Couldn't find matching GLX visual (Success) [uosiu@localhost captive]$ cat /etc/X11/xorg.conf # XFree86 4 configuration created by pyxf86config Section "ServerLayout" Identifier "Default Layout" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # RgbPath is the location of the RGB database. Note, this is the name of the # file minus the extension (like ".txt" or ".db"). There is normally # no need to change the default. # Multiple FontPath entries are allowed (they are concatenated together) # By default, Red Hat 6.0 and later now use a font server independent of # the X server to render fonts. ModulePath "/usr/lib/xorg/modules/extensions/nvidia" ModulePath "/usr/lib/xorg/modules" FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "record" Load "freetype" Load "type1" Load "glx" EndSection Section "InputDevice" # Specify which keyboard LEDs can be user-controlled (eg, with xset(1)) # Option "Xleds" "1 2 3" # To disable the XKEYBOARD extension, uncomment XkbDisable. # Option "XkbDisable" # To customise the XKB settings to suit your keyboard, modify the # lines below (which are the defaults). For example, for a non-U.S. # keyboard, you will probably want to use: # Option "XkbModel" "pc102" # If you have a US Microsoft Natural keyboard, you can use: # Option "XkbModel" "microsoft" # # Then to change the language, change the Layout setting. # For example, a german layout can be obtained with: # Option "XkbLayout" "de" # or: # Option "XkbLayout" "de" # Option "XkbVariant" "nodeadkeys" # # If you'd like to switch the positions of your capslock and # control keys, use: # Option "XkbOptions" "ctrl:swapcaps" # Or if you just want both to be control, use: # Option "XkbOptions" "ctrl:nocaps" # Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: ### Comment all HorizSync and VertSync values to use DDC: Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "CTX PR705F series" ### Comment all HorizSync and VertSync values to use DDC: HorizSync 30.0 - 85.0 VertRefresh 50.0 - 160.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "nvidia" VendorName "Prolink" BoardName "NVIDIA GeForce 4 (generic)" Option "Coolbits" "1" Option "RenderAccel" "on" Option "AllowGLXWithComposite" "true" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" "640x480" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "1152x864" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection Section "Extensions" Option "Composite" "Enable" EndSection [uosiu@localhost captive]$ rpm -qa |grep nvidia xorg-x11-drv-nvidia-1.0.8178-7.lvn5 kmod-nvidia-1.0.8178-6.2.6.16_1.2080_FC5 [uosiu@localhost captive]$ glxinfo bash: glxinfo: command not found [uosiu@localhost captive]$ glxgears bash: glxgears: command not found [root@localhost html]# glxinfo -bash: glxinfo: command not found [uosiu@localhost captive]$ dmesg |grep nvidia nvidia: module license 'NVIDIA' taints kernel. [uosiu@localhost captive]$ uname -r 2.6.16-1.2080_FC5 nie wiecie jak wlaczyc nvidie? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
MitS Napisano Kwiecień 7, 2006 Zgłoszenie Share Napisano Kwiecień 7, 2006 może oto chodzi: http://forum.fedora.pl/index.php?showtopic=9960 Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
