Nvidia I Odświeżanie Monitora
derbich
[uosiu@localhost ~]$ cat /etc/X11/xorg.conf
# XFree86 4 configuration created by pyxf86config
Section "ServerLayout"
       Identifier     "Default Layout"
       Screen      0  "Screen0" 0 0
       InputDevice    "Mouse0" "CorePointer"
       InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# RgbPath is the location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
       ModulePath   "/usr/lib/xorg/modules/extensions/nvidia"
       ModulePath   "/usr/lib/xorg/modules"
       FontPath     "unix/:7100"
EndSection
Section "Module"
       Load  "dbe"
       Load  "extmod"
       Load  "fbdevhw"
       Load  "record"
       Load  "freetype"
       Load  "type1"
       Load  "glx"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#       Option  "Xleds"         "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#       Option  "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#       Option  "XkbModel"      "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#       Option  "XkbModel"      "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#       Option  "XkbLayout"     "de"
# or:
#       Option  "XkbVariant"    "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#       Option  "XkbOptions"    "ctrl:swapcaps"
# Or if you just want both to be control, use:
#       Option  "XkbOptions"    "ctrl:nocaps"
       Identifier  "Keyboard0"
       Driver      "kbd"
       Option      "XkbModel" "pc105"
       Option      "XkbLayout" "pl"
EndSection
       Identifier  "Mouse0"
       Driver      "mouse"
       Option      "Protocol" "IMPS/2"
       Option      "Device" "/dev/input/mice"
       Option      "ZAxisMapping" "4 5"
       Option      "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
### Comment all HorizSync and VertSync values to use DDC:
       Identifier   "Monitor0"
       VendorName   "Monitor Vendor"
       ModelName    "CTX PR705F series"
       HorizSync    30.0 - 85.0
       VertRefresh  50.0 - 160.0
       Option      "dpms"
EndSection
Section "Device"
       Identifier  "Videocard0"
       Driver      "nvidia"
       VendorName  "Prolink"
       BoardName   "NVIDIA GeForce 4 (generic)"
       Option      "Coolbits" "1"
       Option      "RenderAccel" "true"
       Option      "NoDDC" "false"
       Option      "UseEdidDPI" "true"
       Option      "UseEdidFreqs" "true"
       Option      "NvAGP" "1"
       Option      "AllowGLXWithComposite" "true"
       Option      "UseEDID" "false"
EndSection
Section "Screen"
       Identifier "Screen0"
       Device     "Videocard0"
       Monitor    "Monitor0"
       DefaultDepth     24
       SubSection "Display"
               Viewport   0 0
               Depth     16
               Modes    "800x600" "640x480"
       EndSubSection
               Viewport   0 0
               Depth     24
               Modes    "1152x864" "1024x768" "800x600" "640x480"
       EndSubSection
EndSection
Section "DRI"
       Group        0
       Mode         0666
EndSection
Section "Extensions"
       Option      "Composite" "Enable"
EndSection
wszystko zgodnie z tym co napisaliscie (_wyrzej_ → wyżej) ORT, nawet mam 75hz a nie 60, ale moj monitor moze 85
Masz tak:
Viewport 0 0
Depth 24
EndSubSection
Spróbuj tak:
Viewport 0 0
Depth 24
Modes "1152x864@85" "1024x768@85" "800x600@85" "640x480@85"
EndSubSection
Faktycznie dodanie do section device:
"UseEDID" "false"
rozwiązuje problem ale częściowo, ponieważ nie ma możliwości zmiany rozdzielczości i odświerzania. I to w zasadzie jest zastnawiające. Ponieważ to polecenie blokuje możliwość zmiany rozdzielczości ekranu i niejako wymusza konkretne ustawienie. Ale pytanie moje brzmi dlaczego po usunieciu tego wpisu dzieja się dziwne jaja i nie można ustawić wybranej rozdzielczości i odświerzania montora.
