irc + pident, jakby ktos chcial
Papik
Standardowo nie ma identa (albo mi sie nie zainstalowal)..
Walczylem dzisiaj kilkadziesiat minut aby na ircu osiagnac:
*!papik@ zamiast *!^Papik@ lub *!vGbt5Dc@ :)
apt-get install pidentd
moj identd.conf:
#-- User and group (from passwd database) to run as
server:user = ident
#-- Override the group id
server:group = ident
#-- What port to listen on when started as a daemon or from /etc/inittab
# server:port = 113
#-- The socket backlog limit
# server:backlog = 256
#-- Where to write the file containing our process id
server:pid-file = "/var/run/identd.pid"
#-- Maximum number of concurrent requests allowed (0 = unlimited)
# server:max-requests = 0
#-- Enable some protocol extensions like "VERSION" or "QUIT"
protocol:extensions = enabled
#-- Allow multiple queries per connection. This slightly breaks RFC1413
#protocol:multiquery = enabled
#-- Timeout in seconds since connection or last query. Zero = disable
# protocol:timeout = 120
#-- Disable username lookups (only return uid numbers)
result:uid-only = no
#-- Enable the ".noident" file
result:noident = enabled
#-- Charset token to return in replies
# result:charset = "US-ASCII"
#-- Opsys token to return in replies
result:opsys = "UNIX"
#-- Log all request replies to syslog (none == don't)
# result:syslog-level = none
#-- Enable encryption (only available if linked with a DES library)
#result:encrypt = yes
joe /etc/sysconfig/ident
#zmienic
IDENTDOPTS="-e"
I dziala :D
chyba,ze Wam nie dziala to popatrze co jeszcze namieszalem
Gość
