Lefthand
przemekj23
wyskakuje mi cos takiego :
Teraz zostanie wykonany skrypt poinstalacyjny. W tym celu musisz podac haslo (_root'a_ → roota) ORT
su: error while loading shared libraries: /usr/lib/nvidia/libGLcore.so.1: cannot restore segment prot after reloc: Permission denied
Wykonanie skryptu zostalo zakonczone. Wcisnij dowolny klawisz.
pozdrawiam
A teraz przy wykonywaniu skryptu poinstalacyjnego w konsoli wypisuje mi to :
Password:
GSEC> Warning - maximum 8 significant bytes of password used
GSEC> assistant: Symbol `_ZTI7QWidget' has different size in shared object, consider re-linking
assistant: Symbol `_ZTI18QXmlDefaultHandler' has different size in shared object, consider re-linking
assistant: Symbol `_ZTI7QSocket' has different size in shared object, consider re-linking
Xlib: extension "GLX" missing on display ":0.0".
Unrecognized option 'backups'. Try -help to get help.
Unrecognized option 'create'. Try -help to get help.
Unrecognized option 'database.dat'. Try -help to get help.
Unrecognized option 'db'. Try -help to get help.
Unrecognized option 'FB'. Try -help to get help.
Unrecognized option 'fb_install.sh'. Try -help to get help.
Unrecognized option 'gbak'. Try -help to get help.
Unrecognized option 'help'. Try -help to get help.
Unrecognized option 'i18n'. Try -help to get help.
Unrecognized option 'icons'. Try -help to get help.
Unrecognized option 'install.sh'. Try -help to get help.
Unrecognized option 'ledger'. Try -help to get help.
Unrecognized option 'lhmk.sh'. Try -help to get help.
Unrecognized option 'lib'. Try -help to get help.
Unrecognized option 'logo.png'. Try -help to get help.
Unrecognized option 'main_install.sh'. Try -help to get help.
Unrecognized option 'menus'. Try -help to get help.
Unrecognized option 'tmp_script.sh'. Try -help to get help.
Unrecognized option 'ui'. Try -help to get help.
Unrecognized option 'uninstall'. Try -help to get help.
Unrecognized option 'Uninstall LeftHand FK.desktop'. Try -help to get help.
Unrecognized option 'units'. Try -help to get help.
Unrecognized option 'updates'. Try -help to get help.
Unrecognized option 'wizz'. Try -help to get help.
Unrecognized option 'wizz.sh'. Try -help to get help.
Unrecognized option 'Warning'. Try -help to get help.
Unrecognized option 'assistant'. Try -help to get help.
Unrecognized option 'Some'. Try -help to get help.
Unrecognized option 'existing'. Try -help to get help.
Unrecognized option 'files'. Try -help to get help.
Unrecognized option 'have'. Try -help to get help.
Unrecognized option 'been'. Try -help to get help.
Unrecognized option 'detected'. Try -help to get help.
Unrecognized option 'from'. Try -help to get help.
Unrecognized option 'a'. Try -help to get help.
Unrecognized option 'prior'. Try -help to get help.
Unrecognized option 'install'. Try -help to get help.
Unrecognized option 'of'. Try -help to get help.
Unrecognized option 'FirebirdSQL'. Try -help to get help.
Unrecognized option '(or'. Try -help to get help.
Unrecognized option 'InterBase).'. Try -help to get help.
Unrecognized option 'These'. Try -help to get help.
Unrecognized option 'will'. Try -help to get help.
Unrecognized option 'be'. Try -help to get help.
Unrecognized option 'archived'. Try -help to get help.
Unrecognized option 'in'. Try -help to get help.
Unrecognized option 'file'. Try -help to get help.
Unrecognized option ':'. Try -help to get help.
Unrecognized option '/opt/firebird_20060427_1141.tar.gz'. Try -help to get help.Unrecognized option 'and'. Try -help to get help.
Unrecognized option 'then'. Try -help to get help.
Unrecognized option 'deleted.'. Try -help to get help.
Unrecognized option 'Archiving...'. Try -help to get help.
Unrecognized option 'Done.'. Try -help to get help.
Unrecognized option 'Deleting...'. Try -help to get help.
Unrecognized option 'Install'. Try -help to get help.
Unrecognized option 'completed'. Try -help to get help.
The link is empty!
Sprawdzasz ta biblioteke przy ktorej wyrzuca Ci "cannot restore segment prot after reloc: Permission denied". Upewniasz sie czy nie jest to link symboliczny. Jesli jest symlink to ponizsza operacje robisz na pliku do, ktorego ten symlink wskazuje. Dalej wykonujesz kod:
chcon -t textrel_shlib_t nazwa_pliku
Zrobilem wydaje mi sie ze dobrze wprowadzielm ten kod ktory mi podales i nazwe pliku na ktory wskazuje skrot i oto efekt :
Password:
Unrecognized option '/opt/firebird_20060428_0907.tar.gz'. Try -help to get help.Unrecognized option 'and'. Try -help to get help.
The link is empty!
Tak sie dzieje na koncu instalacji
pozdrawiam
Rozumiem, ze nie grzebales nic w systemie z linkowaniem bibliotek??
Druga sprawa to poszukaj sobie wymagan odnosnie tego programu i porownaj z zainstalowana wersja qt.
Gość
